/ Share Pics of People Hauling or Towing Something Wrong #13,181
I've always wondered how much use it was to chain down an excavator or other heavy tracked vehicle. Looking at this trailer rollover, I guess that I have my answer. (It helps)
Flipped trailer in Castine causes road closure
(No report of the condition of the drivers shorts.)
That happens EVERY TIME the excavator is chained at a 45 degree angle,, :confused:
I have had to tell several drivers,, DO NOT chain the machine at an angle greater than 30 degrees!! :(
:laughing: :thumbsup: :D
/ Share Pics of People Hauling or Towing Something Wrong #13,182
:laughing:
It looks to me like the back chains have broken free. How would 45 degrees or less make an difference? And that wasn’t a half bad job. It stayed mostly together in a rollover crash. The chains should be as close as possible to 45 degrees to best resist forward/backwards and sideways movement. I see people putting chains on close to 90 degrees which offers little means of support for forward movement. It would be better to increase the chains to more than 45 degrees vs less. I’ve been guilty of hooking chains straight off the back at 180 degrees or close to it which is the strongest way to resist a forward crash. Realistically if someone is actually using chains of adequate capacity most any hooking will be fine.
/ Share Pics of People Hauling or Towing Something Wrong #13,183
that wasn't a half bad job. It stayed mostly together in a rollover crash.
That's what I thought also, which was why I posted the link. Until now I always thought that chains might keep a heavy tracked machine from sliding, but would never hold in an accident.
/ Share Pics of People Hauling or Towing Something Wrong #13,184
Looks like a pintle hook trailer .. The hook on my dump truck will spin round and round . Bet he was going way to fast once it starts leaning there is nothing to stop it..
/ Share Pics of People Hauling or Towing Something Wrong #13,185
I always wondered why the chains, that are strong enough to hold the weight of a very heavy piece of equipment, can't hold a trailer in place in a rollover? I know the trailers are not as heavy as the load.
/ Share Pics of People Hauling or Towing Something Wrong #13,186
I guess I'm just confused. I thought you were supposed to chain at 45 degrees, a diagonal chain path gives the best compromise between forward and lateral support, besides being required by law. I guess it depends on the weight of what's being hauled also. I only haul less than 10k lbs so the rules are different. I heard you are supposed to crisscross the chains on anything heavier, but I also heard the chains aren't allowed to touch each other when tight. But if your machine and trailer are symmetrical, and you use the same mount points on each side, then it would seem that the chains would have to touch as both sides would be equal.
/ Share Pics of People Hauling or Towing Something Wrong #13,187
You’re supposed to use 4 chains vs 2 on machines over 10k but there’s no such law that I’m aware of on crossing the tie down chains.
/ Share Pics of People Hauling or Towing Something Wrong #13,188
That sucks.
I guess it matters what the deck was made of. Some guys find out the hard way how slippery, steel on steel is. You see videos of equipment attempting to drive on or off some trailers, just sliding off sideways!
/ Share Pics of People Hauling or Towing Something Wrong #13,189
Look at the landing gear. It's a semi trailer.
/ Share Pics of People Hauling or Towing Something Wrong #13,190
Chains holding a load are usually tight to start with. Under stress they do not get jerked on so to speak. Safety chains holding a trailor to a truck have slack in them so as to allow turning. During a accident the amount of force on the chains when they get jerked on and the slack is gone is incredible.
/ Share Pics of People Hauling or Towing Something Wrong #13,191
Looks like d rings on the back bumper area of the truck. Almost looks like something is in the d rings. The truck likely would not need the d rings for 5th wheel use only.
/ Share Pics of People Hauling or Towing Something Wrong #13,192
Our trucks at my job are semis, and we have a pintle on the rear also. Now our pintles aren't rated very high because we never use them except to pull a dolly to build sets. But I definitely see what looks like safety chain hooks. And the trailer looks like a straight frame instead of a typical low boy 5th wheel trailer...
/ Share Pics of People Hauling or Towing Something Wrong #13,193
Speaking of semis and trailers, why is it that they can get away with no safety chains on a normal 5th wheel trailer? Is the 5th wheel hitch connection so infalible that there is no way to disconnect? Obviously there don't seem to be many disconnects, but since I have never seen one of those hitches up close I'm curious.
Rob
/ Share Pics of People Hauling or Towing Something Wrong #13,194
Rob
Perhaps because with the modern trailers, if you disconnect the air lines (or they tear from a breakaway), the trailer brakes will spring lock and the trailer will stop itself?
/ Share Pics of People Hauling or Towing Something Wrong #13,195
Well, that's true with pretty much any trailer with trailer brakes. They have a breakaway cable that activates the brakes.
/ Share Pics of People Hauling or Towing Something Wrong #13,196
True fifth wheels are considered intrinsically safe by design and by law. That is why no chains are needed.
If you buy a fifth wheel travel trailer and do an Anderson Ultimate or Reese Goosebox conversion to a goose neck ball on your fifth wheel trailer, you are back to legally needing safety chains.
/ Share Pics of People Hauling or Towing Something Wrong #13,197
Rob
Oh they come off. Mostly right after hooking up though. But they are pretty solid if they are working right.
/ Share Pics of People Hauling or Towing Something Wrong #13,199
I saw one come off when a lowboy hauling an excavator took out a bridge. If the fifth wheel pin hadn't snapped it would have pulled the tractor 100 feet down on top of the trailer and load. Of course when the State got through with the driver he might of wished he'd gone down with his ship. He had taken a few shortcuts and was 4 axles shy of what he needed to be legal. Then he went back on a Sunday to try to haul the counter- weight away before it could get weighed and got caught.
/ Share Pics of People Hauling or Towing Something Wrong #13,200
He's the type of guy who makes it miserable for those who are just trying to make an honest living.
2011 Dodge Ram 4x4 Terex Hi Ranger LT40 40ft. Forestry Chipper Insulated Bucket Truck (A61568)
2011 Dodge Ram 4x4...
Mini rock grapples (A61567)
Mini rock grapples...
Toro z turn (A56859)
2012 HINO 268A 4X2  26FT NON CDL BOX TRUCK (A59906)
2012 HINO 268A 4X2...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
2013 Freightliner M2 106 Altec TA45M 44ft. Insulated Bucket Truck (A60352)
2013 Freightliner...
