Renovating my house in the suburbs
/ Renovating my house in the suburbs
Congrats on the house, sounds like the previous owner took care of it?
I致e been all over and, speaking strictly and only of weather, I think you live in the best weather area I致e ever been to.
That is, if you stay close to the water, which you have done, good on ya!
Not everyone wants to live in SoCal but, a bunch do!
Yeah I would agree. It's a bit dry here but the temperatures are ideal almost all year round.
/ Renovating my house in the suburbs #102
Are you planning to put the fir and pine beams within visual range of each other? Douglas fir is tough when it comes to matching stains -- the pink always wants to bleed through. I had a project where we mixed fir and spruce on some porch furniture and I probably spent more time getting the finishes to come out even than the actual wood working. The trick was to stain the spruce with a diluted red stain first, to get it in the ballpark of the fir. Then proceed with the other stains and finishes. Came out fine in the end but I learned a lesson there.
They're in different rooms. We're going dark on the stain but I can see that it'll still look a bit red. Not a fan of staining oak or doug fir for this reason.
Happy with the results so far. This is with just the wood effect aging product. I'll stain after this. 20200925_175736.jpeg20200926_133115.jpeg20200926_133054.jpeg20200926_133130.jpeg20200926_133107.jpeg
These photos show the process step by step from plain wood through coating with the minwax wood effects. Let it dry overnight and then the final step is staining and polyurethane. 20200926_155411.jpeg20200926_155406.jpeg20200926_160809.jpeg20200926_160815.jpeg20200926_161611.jpeg20200926_162119.jpeg20200926_162647.jpeg20200926_162638.jpeg20200926_165106.jpeg20200926_165526.jpeg20200926_165657.jpeg20200926_171405.jpeg
/ Renovating my house in the suburbs #106
Muhammad, that looks really good from my knothole! :D :thumbsup:
I should just rename this thread "the beam thread" because that's all I'm doing.
This is a good side-by-side of the beams prepped with planing, crack cutting, hatchet chopping, and wire brushing, and in the right is after torching and the aging formula.
I picked up a $15 HVLP paint sprayer from HF and it made the minwax stage to much faster. With the wood being so rough, the sprayer is the way to go. It also stretched the formula 50% further as a quart lasted three beams with the sprayer versus two beams with a brush.
Did I already mention that destroying your planer blade by running it over some screw heads makes the planing texture look a lot more authentic? Well that's a tip if you don't mind ruining a blade for this type of thing.
Other tips... the $99 craftsman drum sander with wire brush is barely adequate for this project. Makita makes one that is about $450 but nobody local had one in stock. Normally I'd rent something like that for this project. I also started researching tabletop wire brush drum sanders and they are quite expensive. But that would make the wire brush stage a lot easier.
The worst part is probably the hatchet step. It's just tedious and like today, three 20' beams with three sides each = 180 linear feet of chopping an acreage of 20 cuts per foot = 3600 hatchet swings. That's 3600 swings to think about a better way to do this.
It took me four hours of solid work to treat three 20' beams today. It's exhausting work and a good portion was done while kneeling on the ground... even with knee pads, not fun. Oh and the amount of dust this produces is staggering. My sinuses are getting irritated even with the use of a carbon mask. I figure in inhaling the dust while taking breaks. But I'm more than half way done now. 20200927_165221.jpeg20200927_165228.jpeg
/ Renovating my house in the suburbs #108
I was thinking of Wax On Wax Off reading 3600 hatchet swings...
Love the arch under the staircase.
/ Renovating my house in the suburbs #109
I'm always amazed at how hard people will work to make something new look old and worn out!!!
There is a local guy here in Tyler that has started up a fake beam company. He has quite a few different techniques from what I've seen in some of the houses he's done. Clients have told me that they pay from a grand to twice that depending on how distressed he makes them look, and how long they are. Overall thickness doesn't seem to be as big a factor as length is.
Yep. That's the going rate here as well. Since I need five 19 footers, one 14 footer, and four eight footers, it would be nearly $20k to order these beams. I was hoping to find a product on the market that was close enough that I could just stain but since I couldn't find that, might as well go all out and get some blisters out of the deal.
/ Renovating my house in the suburbs #113
It took me four hours of solid work to treat three 20' beams today. It's exhausting work and a good portion was done while kneeling on the ground... even with knee pads, not fun. Oh and the amount of dust this produces is staggering. My sinuses are getting irritated even with the use of a carbon mask. I figure in inhaling the dust while taking breaks. But I'm more than half way done now. View attachment 671146View attachment 671147
You're using the wrong setup. Carbon cartridges are for organic vapor and solvents. You need a particulate filter for your mask. Or a particulate disposable mask.
I'll double check. Thanks for the reminder.
/ Renovating my house in the suburbs #115
Lookin gooder-un blue TU.gif.
Subscribed
I thought the day would never come... the countertop guys came back and fixed their mess ups and I'm happy with the results. Now I have the green light to replace my kitchen window and then start on the backsplash. I'm bringing in a helping hand for the backsplash because there are 1500 tiles to lay.
Finished the beams! I made 154 linear feet in total and will use 135 feet. Remember when I mentioned that the local places that make these charge $150 per linear foot? That would have been $20,250 for this pile.
The last update I had just finished the steps up to applying the minwax weathering agent. Let them sit in the sun for a couple days and the temps have been 95+... didn't realize how much kiln died lumber would cup. So I've got a bit of straightening to do when I install them, but nothing that will ruin the beams.
The final steps were staining and a coat of extreme flat polyurethane. I used a HVLP sprayer for both coats. I used almost a gallon of stain for all these beams but only a quart of polyurethane. I'm quite happy with the results... especially considering how much I saved (I didn't total everything up but I'm sure I'm under $1,500).
Started mounting the ceiling plates so hopefully tomorrow the project will be complete.
In other news, I'm expecting my kitchen window to arrive tomorrow, almost five weeks from order date from Millgard. Fingers crossed that there are no issues with that.
Last but not least, some bad news in regards to my electric panel. I have an old mid-80s FPE stab-lok panel and want to replace it. Scam Diego Gas & Electric came out and said I need to move the panel to at least 36" laterally from my gas meter (which is currently directly below my panel). The building code changed and they stopped grandfathering in panel replacements in early 2019. So they are requiring a new line from the street. That means cutting my driveway, trenching, and getting screwed by the electrical contractors who won't touch a new line for less than $9k including permits and trenching. Replacement panel would be about $2,500. I'm thinking I'll plead with them for an exception because everybody in my neighborhood has replaced their panels under the grandfathered terms. My argument is that I'm not going to trench so their point of a fire hazard existing due to insufficient clearance is not as bad as the fire hazard of keeping a FPE stab-lok panel that's also less than 36" laterally from the gas meter.
If they don't budge on the code exemption I'll just wait until I'm going forward with my backyard renovation or possibly adding a granny flat/ADU which I'd have to trench for anyway. 20201001_180248.jpeg20201001_180340.jpeg20201001_164729.jpeg
/ Renovating my house in the suburbs #119
All Federal Pacific here and no issues.... tens of thousands... many dating back to 1950's.
Not aware of any mandatory replacement requirements... at least not here.
Not mandatory but basically nobody here will work on them and everybody says they're a fire risk due to some issue with overloaded circuits not tripping and some falsified UL testing back in the day. Mine trips just fine. Maybe it's just a local racket to keep the electric contractors happy?
(2) BUNDLE OF MISC SIZE USED TIN UP TO 31' LONG (A62131)
(2) BUNDLE OF MISC...
2023 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2023 Peterbilt 567...
Dewalt 60 Gallon Air Compressor (A61166)
Dewalt 60 Gallon...
UNUSED KJ 11'X19' ALL-STEEL CARPORT (A62131)
UNUSED KJ 11'X19'...
iDrive TDS-2010H...
2015 PALMER MACHINE WORKS 24' DUMP TRAILER (A60430)
2015 PALMER...
