npalen
Elite Member
In installed my underground lawn sprinkler system back in about '76 when finances were tight. As a result, the system consists of a manual valve next to each of 21 popup sprinklers. It was initially set up with seven zones with three heads each but over the years I've changed a number of locations due to landscaping. There were some extremely dry years where all the well could muster was a couple sprinkler heads running at one time. I would guess the normal or "wet" years produce about 15 GPM.
I would like to retain the option of running any sprinkler separately or selection of sprinklers based on wind conditions, newly seeder areas, available pump output etc. I envision an indoor control station where any one or group can be turned on with a timer to shut the pump off. I currently have an inside timer to start and stop the pump.
My basic question is whether I should be looking at remote wjreless controlled battery powered solenoid at each sprinkler, running wires to a 24 volt solenoid valve at each sprinkler or a complete new system of some sort.
The lawn covers an area of about 20,000 sq ft in NC Kansas.
Any suggestions and sources of components is appreciated.
Edit: Here is an example of a battery powered solenoid valve but not remote controlled:
Amazon.com : Orbit Battery Operated Sprinkler Timer with Valve (5786) : Automatic Lawn Irrigation Controllers : Garden & Outdoor
Edit again: Forgot to mention that I'm getting up in years and while I currently don't mind going out to switch valves there will be a time where that will need to be done from the indoors.
