Float valves useful on top n tilt??
/ Float valves useful on top n tilt?? #21
A prime circumstance for using float mode with the side link is for final smoothing of a road. Now of course it makes a difference with the road. But if you have a crown on the road and have drives off of the road, going around those corners onto the drive becomes a breeze with the implement following the ground vs following the tractor and either leaving a pile of material or digging in and making a divot.
I have one area where we have a Y in the road. Well one side is a good size berm to control run off as well as simply staying with the lay of the land. Going up and over that berm would be a major ordeal to have the road smooth without using the float feature with my side link.
Only a couple of examples, but ones that would have me changing how I would do things if I did not have the float feature. ;)
/ Float valves useful on top n tilt?? #22
Something else to consider is a simple locking detent on one of the spools...this allows the use of something like a log splitter or hydraulic winch etc., etc...without having to use a bungee cord to hold the lever...
Why don't you use your power beyond instead of rear remote for log splitter?
I just set up one of my log splitters to run off my tractor after it sat under 5 feet of water in the flood, pulled the 13HP motor, hydraulic pump and tank and made a couple lines at a savings of about $600.00 and a ton of labor cleaning and flushing.
Unless you don't have power beyond and are improvising, then makes total sense, I just thought about that as I was typing this.
/ Float valves useful on top n tilt?? #23
When you say power beyond....are you simply talking about the two couplings that are for a backhoe....and get doubled back to themselves when backhoe is unhooked?
Usually dont see tractors with both remotes and that.
A remote with a detent....or a remote with a bungee cord holding it simply becomes a "power beyond"
/ Float valves useful on top n tilt?? #24
Ya. Power beyond just is a circuit with flow all the time. That flow gets diverted when you open a valve. If you plug into that valve & hold it open with a bungee cord or what not, there is no difference.
2023 Bobcat E88 Excavator (A65579)
2023 Bobcat E88...
POULAN 44" VINTAGE 2 MAN CHAINSAW (A64276)
POULAN 44" VINTAGE...
2016 Freightliner 108SD Truck (A64194)
2016 Freightliner...
2020 Pitts Chip Trailer P16316 (A62613)
2020 Pitts Chip...
2015 Chevrolet Express 2500 Cargo Van (A61573)
2015 Chevrolet...
Stand-On Mower (A64553)
Stand-On Mower...
