Filling Tires
/ Filling Tires #1
jdeilus
Prince George, VA
LS MT 125 (still waiting for delivery)
So I am still waiting for my LS MT125 and I enjoy reading all these posts since I cannot be working on my yard tasks yet. I see that some people have their tires filled. Would that be beneficial to a MT125 that is equipped with a FL and BH? Seems like that would be enough weight already. Just asking.
/ Filling Tires #2
I had all four filled with beet squeezin's. Cost me a few bucks to do the fronts, but they rears were 'free'. I have lots of slopes and I wanted as much weight as low as possible.
/ Filling Tires #3
Traction and stability. Get them filed, you wont regret it.
/ Filling Tires #4
My MT240 with FEL & BH has no problem with traction or stability (Not a lot of steep hills here or where I use it) and I use it across a lot of my back yard, so I have not filled the tires. You may not need it either, everyone's situation and use is different. If you still have haggling with the dealer to do, maybe go ahead and get them done in the price.
/ Filling Tires #5
I've always had filled rear tires. Unfortunately - first tractor had NaCl/CaCl in the rears. What a PITA. Current tractor has rimguard in the rears. Not a moments problems. I DEFINITELY would recommend against NaCl/CaCl. To the extent - if salt solution were the only choice - I'd go unfilled.
Filled rears - great help in traction, stability & overall weight. Also - windshield washer fluid & RV antifreeze is available.
I chose rimguard because it's what the dealer recommended, it's the heaviest per gallon & it's what the dealer was setup to instal.
/ Filling Tires #6
LS MT125 is a subcompact tractor with a bare tractor weight of 1,445 pounds.
You cannot add enough liquid to the dinky tires to accomplish anything constructive. The dinky tires mean the MT125 has a relatively low center of gravity, relative to heavier tractors with larger wheels and tires.
Let air suffice. The Backhoe is ample rear weight.
T-B-N ARCHIVE: https://www.tractorbynet.com/forums/tires/425678-ballasts-subcompact-tractors-loading-tires.html
https://www.tractorbynet.com/forums/kubota-buying-pricing/335037-loading-tires-kubota-bx.html
/ Filling Tires #7
Check your manual, many manufactures do not recommend liquid ballast when using a backhoe.
They may recommend rear ballast on it when using the loader without the backhoe.
/ Filling Tires #8
You will add about 700lbs of rear weight using beat juice with that tire size. I wouldn't say that is a a lot of weight, but since your machine only weighs 1,444 dry, that is fairly light. Anything would help. Adding BJ to your rear tires will add stability, remove much of the bounce (especially when using the FEL), add traction, assist with lifting... I really dont see a down side. I have MUCH more weight on a larger tractor that I drive on my yard. It doesnt leave ruts. But soil types, moisture, etc,.. everyone's situation is different. For me, filling a tire, any tire on any tractor, is worth it.
/ Filling Tires #9
What size tires are you using to get that kind of weight?
When I looked at a 26x12.00-12 I only see about 8 gallons and 89 pounds per tire per RimGuards charts.
/ Filling Tires #10
LS MT125 Dimensions
2016 -
MT1 Series
Sub-Compact Utility tractor
Series: MT122 ← MT125
LS MT125 Tires
Lawn/turf front: 18x8.5-10
Lawn/turf rear: 26x12.0-12
Industrial front: 18x8.5-10
Industrial rear: 26x12.0-12
Dimensions
Wheelbase: 56 inches
Length: 97 inches
Width: 47 inches
Height (ROPS): 87 inches
Weight: 1444 lbs
Page information
Last update: July 11, 2020
Copyright: Copyright 2020 TractorData LLC
Contact: Peter@TractorData.com
/ Filling Tires #11
LS MT125 Dimensions
2016 -
MT1 Series
LS MT125 Tires
Dimensions
Length: 97 inches
Width: 47 inches
Weight: 1444 lbs
Page information
/ Filling Tires #12
And your point of posting the specs? I am sure the new owner knows the specs. Is there an answer to his question buried in there somewhere?
/ Filling Tires #14
Agreed!
Any tractor, when a backhoe remains attached, does not need, and should not have, loaded tires!
/ Filling Tires #15
The whole point of these machines is the flexibility of not having to leave any one implement attached full time. My BH is off more than on. I did a week of tasks where I needed it, but took it off again today when I needed to do other things like mowing. Tomorrow the landscape rake will go on for a couple of days. Once it comes off there may not be anything on the rear for a while which is where the loaded tires come in.
/ Filling Tires #16
I just did this on my new tractor. I can feel the difference right away. It feels way more stable. I don't know what is recommended for the LS backhoe, but I have my rear tires loaded on my New Holland LB75B backhoe and it works great. Makes it more stable also.
As I always do, here is a video of it: Easy Way to Fill Your Tractor Tires with Water - YouTube
/ Filling Tires #17
Counterweight Blue is a new one to me but this is what the dealership uses.
/ Filling Tires #18
As stated before, stability, wieght and traction. With a backhoe or fel, its nice when those attachments are on the machine for stability and traction. Fluid in tires is having permanent ballast, better traction and the best stability short of duals for all the tires for the times a fel or backhoe are not an option.
In my years of owning smaller tractors, fluid in tires made a big difference. Smaller the tractor, bigger and better the difference seemed to be.
/ Filling Tires #19
I have an XR4140 and was carrying around an IBC tote to water my daughters horses (I had no ballast or tire fill etc...rookie move) I went for a bit of a ride when gravity took over, luckily it was only 3' off the ground and nothing broke and no one was injured. I had bio ballast added to my rear tires which gave me 490# per rear tire (980 total #'s) of ballast that the tractor doesn't have to lug around. Haven't had any issue since and other than having to have someone come fill the tires you wouldn't know anything is different with the tractor, other than it is about 1000% safer when using the loader LOL
/ Filling Tires #20
If the BH is left on, no need for tire fill - pointless.
Instead of spending money on filling the tires, IF you dont already have one - buy a box blade. Almost anyone can find a use for one and it can also function as rear ballast.
My grandpa hangs his tiller off the back for the same reason.
8" Mini Excavator Bucket (A66285)
8" Mini Excavator...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
1998 International 4700 Flatbed Dump (A62613)
1998 International...
2018 F-150 4WD (A63688)
2018 F-150 4WD...
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
