Branson 3725CH PTO Problem
/ Branson 3725CH PTO Problem #1
450
New Member
Fairbanks, Alaska
Branson 3725CH
Has anyone had any issues with the PTO blowing fuses? Mine is blowing the PTO fuse fairly regular and I知 not having any good luck with the dealer. They have been screwing around for 3-months now and the problem is still there. They are replacing the switch now as I type this but I will just about bet you that doesn稚 fix the problem. I think it is the PTO solenoid myself but looking for any help. Thanks 🙏
/ Branson 3725CH PTO Problem #2
Don't give up on your dealer. Tracking down a electrical problem like this can be difficult. You are correct that the coil may be the problem but it could be any number of other things.
Does it blow the fuse right away or does it last for a little while then blow?
/ Branson 3725CH PTO Problem #3
Dealer should be able to use an inductive style DC current meter and actually see how much current is flowing while the solenoid is activated.
Some times right away and others not. When it blows the fuses right away I can disconnect the solenoid and it will stop blowing the fuse and usually will work for awhile after plunging back up. I have looked for bare wire that might be shorting out but haven’t found anything. With the solenoid disconnected I have never been able to get it to blow a fuse no matter how many times I turn the switch off and on.
/ Branson 3725CH PTO Problem #5
The solenoid is the draw so it stands to reason that unplugging it would stop blowing the fuse. They probably could ohm the coil out and determine if it is in spec or not.
As sd445dan pointed out, I would want to know how many amps it is pulling. It would be interesting to see if the amps climb over time. Please let us know what they find out and I hope they get you back up and running soon!
/ Branson 3725CH PTO Problem #6
Would a semi stuck spool cause the spool to pull more amps? Let's say the spool is not travelling the entire stroke, can that cause a coil to pull more amps and heat up?
/ Branson 3725CH PTO Problem #7
Possibly, but unlikely. If I was trouble shooting this problem I would ohm the coil out and compare with a known good coil. I use to keep parts just for that reason. Sometimes it is easier to put a known good part on and see if that solves the problem.
I would also do voltage drop test to rule out any bad connection drawing more amps. The switch very well may be the problem but I like to confirm issues before guessing. Takes a little longer but keeps customers from coming back. I hated seeing a vehicle I just worked on show back with the same issue. No money in that. Most mechanics feel the same way.
/ Branson 3725CH PTO Problem #8
I never really messed much with solenoid valves my self. That's why I was asking that.
I agree with having extra parts around to switch and troubleshoot that way. Measuring the amps and ohms it's an easy and cheap way to troubleshoot this.
/ Branson 3725CH PTO Problem #9
Yes and I like comparing to a known good part far more then going off of what is typed in a book. Seen too many mistakes that cause headaches. This is a more difficult find because whatever the problem is it is just beyond the fuse rating.
I remember a customer complaint that his car would die every time he turns right. I test drove the car several times and never could duplicate the issue. Finally I told him to drive while I rode and turns out he thought he was a race car driver. He would take turns fast enough that the tires would squeal. Turned out to be the wiring harness would sling over and short a wire on a screw. That took a moment or two to locate.
/ Branson 3725CH PTO Problem #10
When it blows the fuses right away I can disconnect the solenoid and it will stop blowing the fuse and usually will work for awhile after plugging back up.
This makes it pretty clear that the solenoid has an intermittent short to ground. If it were the wiring between fuse and solenoid, unplugging the solenoid would not stop the blowing. I'd say replace the solenoid. A sly dealer may pirate one off a new tractor to get you going without waiting for one to ship. Not kosher, but it works.
I've had my solenoid and valve in and out while chasing a PTO problem. It's a 10-minute job.
/ Branson 3725CH PTO Problem #11
Any updates 450?
Well it has been a while and just got PTO fixed. It was a very frustrating process but it is now fixed. The problem was a wire shorting out under the cab. It was a wire that you really couldn’t see because it ran with some hydraulic lines/hoses but was trapped under them and on the head of a bolt. It took the mechanic 2 1/2 days tracing every wire before finding it. That’s what Branson finally told them to do.
One of the problems was it would stop working/blow fuse for me but after loading and unloading at dealer it would work fine.
/ Branson 3725CH PTO Problem #13
Wow, it has been a while. I am glad they found the problem! Hopefully that is the only issue you will ever see and will have many years of excellent service.
Did you just wait some time before taking it in or has it been at the dealer this long?
It has been back and forth to the dealer. I used it through the winter for plowing snow since I didn’t need the PTO. But it has been back and forth numerous times and couple of weeks each time because it takes forever to get parts up here. Hopefully it’s all good to go now.
/ Branson 3725CH PTO Problem #15
Wow, what an ordeal. I'm glad you got it fixed. I'll have to remember that wire if I ever have a similar problem.
/ Branson 3725CH PTO Problem #16
Intermittent problems like this short can be a real pain. I am glad they were able to fix it.
2005 FRAC TANK 500BBL WHEELED (A68842)
2005 FRAC TANK...
213088 (A64276)
213088 (A64276)
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
1994 WELD-IT COMPANY 130BBL FUEL PUP TRAILER (A67714)
1994 WELD-IT...
2013 5x8 Port City S/A Enclosed Cargo Trailer (A66738)
2013 5x8 Port City...
1999 INTERNATIONAL 2674 T/A DUMP TRUCK (A67714)
1999 INTERNATIONAL...
