Kubota L4740 Engine "knock" Help?
/ Kubota L4740 Engine "knock" Help? #1
jshwhite
Gold Member
Missouri
Kubota L4740, Massey 65, Case 580C
Recently sold the L3710 and got a low-hours L4740. I love it - that extra 10 hp makes such a difference. It had 365 hrs on it when I bought it and I've put about 75 more on it.
It's making a sound that has me a bit scared. When I first got it, I thought it sounded like it had a knock. The guy that had it before me didn't use it much and it just sat a lot - outside. So my first thought was maybe bad fuel, sticky injector, or something like that. I flushed the fuel system, changed filter, and worked it hard. Still sounds the same. So...I need to do something about it.
Here's a video. Kubota L4740 knock - YouTube The sound doesn't come through perfectly, but hopefully those of you with trained ears will hear it.
Thoughts? Bad injector? Bad valve lash? Spun/worn rod bearing? (I sure hope not!! :eek:) I have a lot of mechanical experience, but not much with internal diesel engine work. Thanks.
/ Kubota L4740 Engine "knock" Help? #2
That doesn't sound too good, one thing you might check first is for an exhaust leak or a bad muffler.
I have a reel mower with a 4cyl kubota that I thought had a rod knock, finally figured out it was the muffler causing the sound. No leaks, just real tinny.
/ Kubota L4740 Engine "knock" Help? #3
I agree with the exhaust leak;let's hope that what it is.Definately sounds different than my L4240.
/ Kubota L4740 Engine "knock" Help? #4
I was also going to suggest exhaust/muffler leak/hole/etc. Kinda rusty in there so maybe the muffler perforated? Most likely at the bottom of muffler & pipes, I'd guess.
/ Kubota L4740 Engine "knock" Help? #5
OK. You mean the knock, right? Yes I hear it plainly. First of all I'd say it is from one cylinder... not the other three. Darn, I was hoping it would be something simple.
In fact, I was hoping it would be typical rocker/tappet noise, but no..... and it does not sound like any kind of exhaust leak to me. That's a metallic noise I'm hearing. You described it as a knock and I agree. It isn't a heavy knock, but it is one.
. Nor does it sound like a stuck EGR valve. Those sometimes have a very loud rattling knock, but but it's a lightweight higher pitched knock and more rapid.
That noise I'm hearing is definitely from the engine - probably the rear - but it doesn't sound like a knock you'd get from small end bushings (no double-knock sound) - and it is too light weight to be big end rod. Plus it didn't change much under load. So I don't think it is big end.
It is way too lightweight to be crankshaft.
And while that engine runs good at idle and lower RPM, the the whole engine sounds to me just a bit light and ratty when revved up....
I'm going to say what I'm hearing is diesel piston slap in one cylinder due to a faulty injector. It would be like having one weak cylinder. Diesel pistons make a knock quite unlike gassers which have a lighter ringing sound to their piston slap.
But I'm going to say that this is not a clearance or wear induced slap, it is slap brought on by that cylinder's injector. Maybe I'm all wet, but I think that cylinder's injector has either lost it's proper pop-off specification or is putting out a less efficient injector spray. Maybe both. Either or both of those will change a diesel's normal compression ignition timing and make just exactly that kind of knock.
Keep in mind it's just a guess, but it fits what I hear.
If yours is a common rail diesel (that engine changed to Tier IV interm about 2008) I'd first check all the electrical connectors to the injectors. And if you don't find anything wrong there, I'd pull that injector - and the one next to it - and get them tested.
New injectors can be expensive, but don't go there. If it works as well as it does in the video there is no need. Find a good old school local diesel shop to test and rebuild them. It doesn't have to be Kubota to do that work, it can be any brand. Here I'm assuming that the Kubota injectors are rebuildable although I don't actually know that. At any rate, lots of shops will check them while you wait. Do that first.
good luck,
rScotty
/ Kubota L4740 Engine "knock" Help? #6
good luck,
rScotty
You might be surprised at what noises a muffler can make, i spent some time tracking down a knock on a V1305 in a mower, sounded like someone was tapping the side of the block with a ball peen hammer!
Finally narrowed it down to the muffler, no leak, muffler seemed to be intact (I didn't cut it open), so possible a baffle finally rotted through.
I'm not saying that's the OP's case, but it's a simpler and less expensive avenue to explore first.
/ Kubota L4740 Engine "knock" Help? #7
I'd take a walk down the exhaust leak path before getting too worried.
Wow, I go sleep and come back this morning to find lots of helpful ideas. Thanks everyone.
Re the exaust leak idea, when loading the engine I do hear the classic "ticking" sound of an exhaust leak. So it very well could have one. I'll give it a good looking over.
TMGT, interesting you mention a bad muffler. I talked to a buddy of mine and he said his D3 dozer was making a "knock", which turned out to be a bad muffler. Question is, how to test that? Take it off and run the engine? Seems that would create another sound altogether :)
rScotty, thanks for the idea/explanation. Hey, a bad injector would be better than a spun rod bearing! And actually, I kinda thought the knock was a separate sound from the exaust leak, so maybe I actually have 2 problems.
Too many projects going at the moment, but I'll try to get to this in a few days and report back...
/ Kubota L4740 Engine "knock" Help? #9
I have access to electronic devices designed to isolate sounds on a chassis, however taking the muffler off will work, it'll be louder but the noise should dissappear if its the muffler.
/ Kubota L4740 Engine "knock" Help? #11
I'll admit to having been fooled a few times on exhaust noises. Probably would have happened more, but we we don't see much rust of any kind out here in the arid West.
The best way I know of to diagnose exhaust noise is to attach a 25 foot extention to the tail pipe. My favorite extension is a piece of scrap flex-pipe that is just large enough to fit over most exhausts. I run it out the door and around to the side. That moves the exhaust note away and puts just enough restriction on the whole exhaust system to show up any leaks. I don't know of any good way to diagnose a loose baffle. Not something I run into.
rScotty
/ Kubota L4740 Engine "knock" Help? #12
Take the temp at each cyl exhaust outlet close to the head and see if one is running colder then the others.
Well, this sure didn't take a rocket scientist. I popped the side panel off where I could get a good look at the entire exhaust. Major blowby out the rear cylinder manifold gasket. And another spot at the front.
Maybe it has a knock, maybe not. I'm going to replace the gasket first and move from there. Any tips or tricks welcome. IMG_20200916_121425492.jpegIMG_20200916_121406277.jpeg
/ Kubota L4740 Engine "knock" Help? #14
Good chance thats the noise you heard. Nothing special, hit the nuts with penatrating oil and make sure the manifold and head surfaces are flat.
Not sure on that particular model engine, but I haven't seen at lot of manifold gasket failures on the smaller Kubota engines.
/ Kubota L4740 Engine "knock" Help? #15
Maybe it has a knock, maybe not. I'm going to replace the gasket first and move from there. Any tips or tricks welcome. View attachment 669818View attachment 669819
Good penetrating oil, small turns to loosen and then tighten back up. Do not remove any nuts or bolts until all have been loosened.
I like to work from center outward.
Another old old mechanic trick is candle wax. Heat the bolt/nut melt candle wax into threads
Ok, we're making progress, but I've still got a knock. Got the exhaust gasket replaced no problem. It sounds WAY better. But the knock almost sounds worse, now that it's not disguised by the exhaust leak sound. Here's a new video Kubota L4740 knock - take 2 - YouTube
rScotty, you mentioned piston slap due to a faulty injector. Is there a way to isolate which cylinder is the noisy one? Or should I just pull all the injectors out and take them to a shop to get them tested?
Thanks for the help.
/ Kubota L4740 Engine "knock" Help? #17
Do a cheap mechanic stethoscope and listen to each cylinder through a length of pipe. Place it against each high and low on the block. Where it is noisier, gives you more ideal of where it is coming from.
/ Kubota L4740 Engine "knock" Help? #20
It sounded like a rod at the end when you shut it down. Taking temp readings like post 12 is a good idea but I would use a hose or something to listen closely at the bottom end.
2017 Blue Bird 71 PAX School Bus (A66736)
2017 Blue Bird 71...
2011 MAGNUM TRAILER LIGHT PLANT (A67714)
2011 MAGNUM...
2014 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A65056)
2014 CATERPILLAR...
2015 Chevrolet Silverado 2500HD Crew Cab Knapheide Service Truck (A68183)
2015 Chevrolet...
Unused 2024 Land Pride PFL3048 48in. Forks and Frame Skid Steer Attachment (A66734)
Unused 2024 Land...
PALLET OF PRESSURE WASHER FUEL TANKS (A68842)
PALLET OF PRESSURE...
