Need help on finding the perfect tractor
/ Need help on finding the perfect tractor #1
GentlemanForester
Laverlochere, Quebec
None thus far...
Hello!
I been roaming on these forums for a while now, but only recently decided to join the community. English is not my main language, so excuse my french!
Before going into more details, keep in mind i want a 4x4 tractor with a cab.
I live up north, where it gors from +35C in summer to -45C in winter. I own 420 acres of land, 400 acres of mixted wood (white birch, aspen, white spruce, red maple, balsam fir and some ash trees and others here and there). The terrain is pretty good, mostly well drain sand and gravel with a couple wet spot, very manageable. Im aiming for 100 cords of firewood per year, a bit of lumber for my small sawmill (16 feet in length max), and selling a bit of veneer to the close by mill. So for forestry application, i would like to be able to have a good grapple and being able to pick up logs of around 1000 pounds. I would also like to have a winch in the PTO for those big aspen downslope.
For the 20 acres of field, i am forseeing a small orchard, berries and about 10 acres of a agroforestry system in parthnership with another party. So in short term its going to be keeping the land clear (was thinking a flail-mower so i can use it in my bush trails too). In a couple years i might want to do the field work myself, but i am not quite there yet, maybe just have that in mind for pto hp advices.
Let me try to summarize the applications and needs:
- grapple on the loader being able to handle 1000 pounds log safely.
- forestry PTO winch
- snowblower in the back
- flail mower
- back blade to maintaining my trails and all other uses
The list is going to get longer in the future, but that is my goal in the next maybe 5 years.
So i was looking for a compact tractor, mainly for the size and being able to get around with ease in the bush. And i was thinking that 30 PTO ho would be enough for my needs... Also, i am looking for a power shuttle transmission. My main trail is 2.5 km long so i will be moving alot and hauling things, so i thing the mechanical transmission would fit me more.
So compact tractors with a cab and power shuttle, there is a lot less choice. The Massey Fergusson 1840m with the regular cab (not the deluxe one) and power shuttle was looking to be one of the best fit for me. Then i asked for a quote, then i went to the bank, then i postpone the project.
After that, some dealers where telling me to get into more a utility size tractor. And they had good points. And then some farmer friend of mine was saying get an old 70+ hp tractor... so i have widen the search for information and now i am completly lost! Haha!
Anyway, i am not going to buy this winter, but i want to make a move next summer is every thing work as intended. For now i got my Suzuki Kingquad 750 with tracks that does the job... just takes more time to complete the job.
So i am looking forward for some tips and advices for which way to go. Oh, and let say my macanics skills are limited!
Thanks and have a bice day!
/ Need help on finding the perfect tractor #2
100 cords of firewood? Is that a misprint? That is a lot of firewood. I am not sure how much you want to spend but I would be looking at 40 to 50 hp. Also think about the cab. It would be nice for snow blowing but you have to be careful in the trees and not break the glass.
I am not sure what your budget is but a tractor and all the attachments you need $40,000 U.S. would be easy to spend.
/ Need help on finding the perfect tractor #3
Welcome to the forum! While I own a tractor in the size that you are considering, given the size of your land and future needs in your orchard you might consider going a bit bigger.
An older, bigger tractor would be fine if you didn't plan to use it much; but things get tired with time, and personally I would rather work with somethin than work on it.
100 cds is a fairly good amount of firewood, and on average I find that I can efficiently haul out 1/3 cd at a time. Is there a decent road through the property which you can at least drive a pickup?
Ideally you don't want to work more than 1/4 mile (400 meters) from where you are landing your wood.
/ Need help on finding the perfect tractor #4
100 cords of firewood is an insane amount of firewood. You’d be working for weeks just to cut and move that many logs.
/ Need help on finding the perfect tractor #5
I have no forestry experience, but 30hp seems to small for that kind of work. I have transported a few 1000 lb plus logs with my Kubota L4060, but I doubt it would last very long in that type of continuous duty.
/ Need help on finding the perfect tractor #6
Recommend the Kubota M6060 tractor.
60Hp and large wheels. This comes in both open station and factory cab. Just a comment, Cab tractors don't work good in forest areas, unless you work out a system of cleared trails.
/ Need help on finding the perfect tractor #7
If your logs are over 2' diameter they will weigh a lot more than 1000lbs.
Of course you need a loader with capacity for both the grapple and the log, and since the log will be out from the pins, you need more capacity than you think.
What country are you in? Different brands and models are available in different countries.
100 cords is a lot of firewood. You're not going to be stacking that by hand. How will you handle it? If you're going to put it in IBC tote cages you'll want a tractor that can pick those up.
I'd recommend an HST if you're both new to tractors and doing loader work.
/ Need help on finding the perfect tractor #8
My LS was purchased to be able to handle firewood processing. 40HP and lift capacity of 2700 lbs. I lift nearly 1/2 cord at a time in modified IBC cages.
I use a 74" inverted blower for heavy snow and a front mounted back blade on a SSQA adapter for light snow and back dragging:
I use an MTL grapple to handle logs and it works well. If I did not need to handle IBC totes I might go with a set of pallet forks with a thumb for logs (look at what Sawyer Rob uses on some of his posts...looks good and a bit cheaper than a dedicated grapple). In any case, you want a 3rd function.
My LS was $31k with dealer installed 3rd function last year. A lot of tractor for the $$$.
/ Need help on finding the perfect tractor #9
Have you previous experience operating a tractor?
Hills require a tractor with wider spaced wheels for stability under load. The requirement for a winch indicates pretty steep slopes. Tractors are inherently unstable operating on sloped ground. Tractor rear wheel/tire spread, sometimes adjustable, is a critical factor increasing compact tractor stability working sloped or uneven ground. Rear axle is the tractor component on which rear wheels/tires mount. A 6" to 10" wider rear axle substantially decreases tractor rollover potential. Tractor width is an approximation of rear axle width.
Larger wheels and tires permit heavier tractors to bridge holes, ruts and tree debris which is stability in the woods.
What is your approximate tractor budget in US Dollars? Everyone wants a big tractor until the reality of how expensive a big tractor is hits home.
/ Need help on finding the perfect tractor #10
Like Jeff said, need location and budget. A JD 4052 like my neighbor has is probably what you need, but you may need 2. Another might be like a PowerTrac or similar to get around on very uneven terrain and the trails.
Ralph
/ Need help on finding the perfect tractor #11
Ralph
I believe the OP may be in Canada (Quebec)
/ Need help on finding the perfect tractor #12
If he isn't going to buy until next summer he has time to study up.
Even if he was to cut his wood cutting plans by half, he would still need a lot more tractor than he has been looking at. Maybe a compact and a larger one as well. Going to need a good PU as well.
But at least he has the time to look into it.
rScotty
/ Need help on finding the perfect tractor #13
rScotty
Also a firewood processor... unless he doesn't want to have time left for his sawmill and orchard. if I had that much land and plans I would consider two tractors and a self loading trailer; one smaller, to run the winch. The other larger, to pull the trailer after loading it. The second one also could have a cab, which is especially handy when spraying in the orchard.
/ Need help on finding the perfect tractor #14
Your perfect tractor for what you do has to be bigger than you expect to use. Never go smaller. It just gets you and your tractor in trouble. 40-60 hp sounds like a good place to start. Find several dealers close to you and go look. You will know when you sit in it if it feels right.
Kioti, John Deere, New holland, Kubota, MAHINDRA, LS, RK.... They all are going to a decent tractor.
/ Need help on finding the perfect tractor #15
rScotty
Yes I fully agree. A second tractor should be considered. Might want to consider a midsized compact for getting in, around, between and under the trees to obtain the specific tree for harvest. A second larger tractor in the 60hp range for hauling and stacking wood cords. Good luck and give it alot of planning.
Hello!
Going to try later to update the profile, but i needed to clarify things.
Now for the cords of firewood. Either you guys consider me insane or we just do bot have the same units. A cord of firewood here is 8遅4遅16鋳.
Last season i did 43 of those cords with my atv, a snowmobile, one sled, chainsaw.
Split by axe (in winter birch is like butter), manully loaded into my 8 pick-up box and my 4遅8 tandam trailer to be delivered with love and a small ache!
So yes, i am talking avout 100 cords. I am buying a small firewood processor to manage that much.
You guys do not go walk the dog with your chainsaw?
Joking. I will give more info and feedback when i am back home.
Thanks for the feedback!
/ Need help on finding the perfect tractor #17
For stability on slopes and stability lifting 1,000 kg + trees with the Loader you need a tractor with at least 66" width and a minimum bare tractor weight of 3,700 pounds. This is a good weight for field work over 20 acres. Consider Three Point Hitch mounted Pallet Forks for moving occasional 1,500 kg trees.
A Kubota MX model is one example. With cab and loader about $50,000 Canadian.
The new MX models have two part rear wheel rims furnished with R1/ag and R4/industrial tires, so wheels can be spread wide to increase stability on sloped ground.
KUBOTA/CANADA WEB SITE: Tractors - Sub-compact, Utility, Agriculture, Compact Tractors | Kubota Canada
A 5,000 pound bare weight tractor one increment wider than a 3,700 pound bare weight tractor will keep you safer but be less agile working the twenty acres you wish to develop.
If you decide on an open station tractor consider loading the rear tires with liquid.
I live in Canada where it gors from +35C in summer to -45C in winter. I want a 4x4 tractor with a cab.
If you decide on a cab equipped tractor, the cab weight will place ample weight on the rear wheels and tires, therefore inflate rear tires with air. Cab will somewhat raise the tractor center-of-gravity.
/ Need help on finding the perfect tractor #18
Finding the perfect tractor is every bit as easy as finding the perfect carry pistol. Come to think of it, I've done that about 5 times too:)
If you wanted "adequate" in lieu of "perfect" you'd stand a better chance. With your tasks, it seems like too tall an order for a single tractor to fill.
/ Need help on finding the perfect tractor #19
Me thinks you have more experience than most us and know what you will need. Just check on the attachments you need and fit the tractor to them.
/ Need help on finding the perfect tractor #20
I don't think I've ever seen a firewood processor - maybe some larger outfits have them. But veryone I know just cuts and splits their firewood by hand with chainsaw and axe.
Hmm..... Is it common for the firwood processors to be run off a tractor PTO? Does that change anything about the size of tractor to get?
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
Ritchie Bestway Pull-Type Sprayer (A66285)
Ritchie Bestway...
KALMAR AC P50BX-PS WAREHOUSE FORKLIFT (A64276)
KALMAR AC P50BX-PS...
2007 Mack CV713 Granite T/A Pole Truck (A62679)
2007 Mack CV713...
2014 KENWORTH T370 ROAD TRACTOR (A65054)
2014 KENWORTH T370...
New/Unused ATS 13000 Pound Electric Winch (A65583)
New/Unused ATS...
