Help with a wire connection
/ Help with a wire connection #1
DDacey
Iseki TL2300
Feeling kinda foolish, I finished the rebuild on my Iseki tl230 and am almost done with the re-assembly. I labeled all my wire connections but failed to label a red wire that connects somewhere on the right side of the engine.The wire is in a bundle with the oil pressure sensor wire(yellow with black stripe) and the glow plug wire ( black with yellow stripe). From what little info I can find there's supposed to be a connection to the fuel pump but for the life of me I can't figure out where it is. Any help would be appreciated.
OK , I'm wondering now wether this wire might in fact go back up to the key switch. Contemplating the wireing diagram and there seems to be some indication that may be the case. So far nobody has chimed in so I'm guessing nobody has the answer?
/ Help with a wire connection #3
Hmmm, four hours from the request to the frustration. Please realize people will respond on a catch as catch can basis. If you're really in doubt as to what's going on hook up what you know to where you know is the right point. Tape that red wire off for now. Try some of the circuits to see what indicators work (oil pressure, glow plug, etc.) If nothing works then you may have now power to the ignition switch. If everything works leave the tape on the red wire and don't worry about it. No, I don't have an Iseki, just a thought.
Didn't mean to sound impatient. I've been deep into tearing this thing apart and putting it back together for a week now. The E3AE1 engine is fairly common but the Iseki TL2300 is a Japanese tractor. The only manuals for it are in Japanese. Makes it a little difficult to figure out.
So far the glow plugs seem to be glowing, the engine cranks but I'm getting no fuel. I'm going to peruse some old threads here about priming the pump, maybe that will work.
/ Help with a wire connection #5
Does it have a fuel shut off solenoid at the injection pump? The wire might be for it. I'm not familiar with that model either, so just guessing here.
On another note, if you have a smartphone, you can install Google Translator app, which have a feature that you can point the camera over a text and it will translate the text.
As far as I can tell the tractor does not have a shut off solenoid, at least not that I can locate. I've gone over the pump area and can find no connection point for any wires. I might have to try your idea about using a translator app and buy the Japanese repair manual, thanks for that.
This might sound stupid but have you ever heard of adding fuel to the intake supply to see if the engine will crank over? I know I've often sprayed starter fluid in gas intakes to get an initial start but don't have any idea if this would work with a Diesel engine.
/ Help with a wire connection #7
Do you have to pull or push something to shut engine down (manual fuel shut off)? If engine die's when key is turned off, there must be a solenoid to stop fuel flow. Keep looking,shut off is there,be it manual or electric.
Squirting fuel into manifold won't help a diesel. I do not reccomend starting fluid,esp when you don't have fuel at injectors. Temptation is too great to over dose and damage engine.
The engine shut off is manual, this is an older Iseki, probably early 80's. So I don't think it has a shut off solenoid. It has a pull shut off.
/ Help with a wire connection #9
Might help get an answer if you post your wiring diagram.
Re: starting fluid... I recently noticed in my Kioti warranty language that spraying starting fluid in the engine immediately voids your warranty.
Thanks John. I think my warranty is long past. I wasn't thinking starter fluid but maybe a capful of diesel. I havn't tried it yet. The closest wiring diagram I have found ( a tractor that is supposed to be very similar to the Iseki ) is for a Bolens TU 2100. wire diagram.png
The branch of wire that I'm trying to figure out is the 3 wires that include the oil pressure sensor ( connected) The glow plugs (connected) and working and the red wire that in this diagram says it goes to the fuel pump. There is no electrical connection to the fuel pump on this tractor. I believe the fuel pump is mechanical.
/ Help with a wire connection #12
Thanks John. I think my warranty is long past. I wasn't thinking starter fluid but maybe a capful of diesel. I havn't tried it yet. The closest wiring diagram I have found ( a tractor that is supposed to be very similar to the Iseki ) is for a Bolens TU 2100.View attachment 669311
I've heard of success using WD40 to start a tractor though!..
Thanks for the link JP, I think I'm one step closer as someone in this thread mentioned a wireing diagram on the inside of the hood, and there it was. It's in Japanese so all I have to do now is translate it and maybe that will clue me in..Stay tuned as
the mystery progresses.
Photo on 9-11-20 at 3.56 PM.jpgAny body out there read Japanese?
/ Help with a wire connection #15
Using the google translator I managed to get something like:
Key for solenoid
TL2700 only
/ Help with a wire connection #16
Key for solenoid
TL2700 only
I believe that answer's the question of where the wire connects on a different model than yours. Rods and wires often get bent or loose. Follow manual shut off rod or wire to lever on injection pump. Use you hands to push lever to max open/start position then try starting. You might only need to get fuel to injector pump then bleed lines between IJ pump and injectors. To recap. Does fuel squirt from fuel pump line while cranking engine? If it does,crack all lines at injectors then crank engine. If/when fuel flow's without spitting air,tighten lines and attempt to start engine. To save wear on starter,you can tow tractor to bleed and/or start. Still no joy? Disconnect glow plugs and give it some starting fluid while cranking. The reason diesel in manifold doesn't work is due to high flash point of diesel so thereby no vapors/fumes are drawn in while cranking.
Thank you all for the help. I guess the reason I didn't label the wire is because it wasn't hooked up to anything, at least that's my current thought and I'm sticking with it. After extensive bleeding of fuel lines The old Iseki cranked up and is running. I'll have to post a picture when I get it re-assembled.
/ Help with a wire connection #18
:thumbsup:
2006 MACK CHN613 6X4 T/A DAY CAB TRUCK TRACTOR (A67148)
2006 MACK CHN613...
2012 Freightliner FLD120 Ambulance (A64556)
2012 Freightliner...
JOHN DEERE 7420 TRACTOR (A64278)
JOHN DEERE 7420...
2011 UE Manufacturing Armada 1000HP Single Pump Tri Axle Acid Pumper Trailer (A64194)
2011 UE...
2018 Generac S/A Towable Light Tower (A64194)
2018 Generac S/A...
JOHN DEERE 4730 SPRAYER (A64278)
JOHN DEERE 4730...
