B7800 removing and reinstalling engine panels
/ B7800 removing and reinstalling engine panels #1
Gto19
Member
Salinas ,ca
Kubota b7800
Hi guys
What痴 the trick to removing and reinstalling the front and side engine panels ? They use a spring like clip and arrowhead looking deals on the panels . I posted a couple of pics to show what I知 dealing with.
Thanks
/ B7800 removing and reinstalling engine panels #2
If you are taking them loose at the panel that is wrong. They come loose from the tractor. Just take a screwdriver between panel and tractor and pop them out from the tractor.
/ B7800 removing and reinstalling engine panels #3
I just give mine a yank and the panel or grill comes off and that clip stayed where it was. It does not come off.
Thanks guys
I now understand the spring clip stays in place . I just needed to give it a harder yank and the panels come off.
Thanks again
/ B7800 removing and reinstalling engine panels #5
Yank or pop them. I hate this setup. It's all worn out on my B7800. I made a fix for one clip/pin and I really need to do the same for others. My panels are always coming loose*: my B7800 is run hard.
* Common for me, as I'm operating, to stand up from the seat and lean forward to smack a panel back on.
/ B7800 removing and reinstalling engine panels #6
Thanks guys
Thanks again
On. the plus side, a battery change is a walk in the park.
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
Generator (A64553)
Generator (A64553)
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
2019 Ford F-550 4x4 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2019 Ford F-550...
Asphalt Roller Tire (A68134)
Asphalt Roller...
2016 CAT 299D2 SKIDSTEER W/MULCHER HEAD (A67714)
2016 CAT 299D2...
