Oil & Fuel JD2320 won't run after starter stops.
   / JD2320 won't run after starter stops. #1
jparkerri
JD 2320
I started my JD2320 this morning and it ran fine. Went away for a couple of hours and now it fires but won't run after I stop the starter. I've checked all fuses, hoses, fuel filter, etc. I have good fuel all the way to the fuel injection pump. If I shut off the fuel and keeping trying to start, it will finally run out of fuel and not fire. As soon as I turn on the fuel, after several tries, it again runs while the starter is turning but not after. There is a small spring-loaded lever on the side of the fuel injection pump. When I pull the hose off the pump outlet that normally goes to the injectors and press the lever, fuel is pushed out the outlet. Does anyone know the purpose of that lever? Is there anything else that could keep the engine from starting? In the parts catalog, there is a fuel solenoid. Not sure if it could cause this. Any suggestions would be appreciated.
   / JD2320 won't run after starter stops. #2
Hi, and welcome to TBN. The fuel solenoid could certainly cause your problem as could a defective ignition switch or a bad connection. On a Kubota the fuel solenoid is activated momentarily when the engine is shut down but otherwise is normally open to allow fuel flow. You need to find out how your Deere is configured.
Thanks for the reply. I pulled my fuel shutoff solenoid and checked the resistance against the specs in the tech manual and 2 of 3 were off but identical. However, with the solenoid out of the tractor, the tractor started up fine and ran until I manually shutoff the fuel. So I bought a new one and it solved the problem. I LAO tested the resistance of the new one and they matched my old one perfectly, I'm assuming the specs may have changed.
   / JD2320 won't run after starter stops. #4
The resistance check confirms the coil is of the correct value - not open or shorted. It does not guarantee the mechanical integrity of the valve itself.
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
1989 Miller Legend AEAD-200 LE Towable Welder Generator (A55851)
1989 Miller Legend...
2018 John Deere Z997R (A53317)
2018 John Deere...
2016 Ford F-150 Pickup Truck (A54814)
2016 Ford F-150...
UNUSED PAIR OF 76" SLIP ON FORK EXTENSIONS (A57193)
UNUSED PAIR OF 76"...
We do NOT accept credit cards as payment. (A56469)
We do NOT accept...
