Tie Rod End Internal Adjustment ??
/ Tie Rod End Internal Adjustment ?? #1
Arizona
2004 Workhorse 2840
This tie rod end pic that I stole from Aliexpress, shows cotter pins with several insertion positions. Does this imply that the tie rod end has end play adjustment built in? Mine sure are sloppy.
/ Tie Rod End Internal Adjustment ?? #2
/ Tie Rod End Internal Adjustment ?? #4
They used to offer rebuild kits. Some had a inner and outer cup you could replace.
Recently, the tie rod ends at each tire, were at their loosest settings. The slot across the top of the tie rod end would not hold any tool I have, except for a flat stamped steel wrench (spanner) from either a die grinder or an angle grinder. The fingers of these wrenches fit perfectly into the ends of the slot atop the tie rod end. Had to turn it clockwise from above with an adjustable wrench. Each 1/2 turn I pulled up on the tie rod end to check for slop. After around 2-3 turns, there was no slop left. The steering was greatly improved.
Mike
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
20x20 Car Port (A65640)
20x20 Car Port...
1990 Ford 3930 Tractor (A65579)
1990 Ford 3930...
HYDRAULIC AUXILIARY TRANSMISSION (A65643)
HYDRAULIC...
2013 Ram 4500 (A62679)
2017 Ford F-250 4x4 Ext. Cab Pickup Truck (A64556)
2017 Ford F-250...
