Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #6,921
The hanger on the right end is partially dislodged and needs to be secured before running again. The mounting tab on the rotor appears to be bent already. Be very careful if bending back not to crack the weld.
I prefer the flail mounting method on my JD mowers. I.E. continuous axial rib with formed flat straps that secure D-ring blade hangers. The down side is that the corners of ther blades can hit the rotor, dullling them. But no individual tab welds to break.
The issues I've seen with the formed rib type of mounting is you can tear the bolt right through the metal. I had that (from a previous owner) on my old Ford 917.
/ Let's talk flail mowers #6,922
I'm not familiar with the JD mounting method -- got any pictures of that?
Pic of my JD390. The rib is 1/2" thick flat stock. My JD25A has a 1/8" thick hat section rib welded to the rotor. I have had the straps that hold the d-ring wear as well as the d- ring itself have a groove worn in it by the blades. 20200816_075031.jpg
/ Let's talk flail mowers #6,925
Yes. The strap is through bolted with anti-vibe nuts. This pic was taken before a full blade, strap, d-ring and bolt replacement.
/ Let's talk flail mowers #6,926
Interesting. My Alamo's design is per this picture
Some observations:
1) The Deere design is more of a pain when one breaks/loses knives. I had to replace knives twice in one day last week and there is only one cotter key to pull, no bolts. I'm glad mine is not bolted.
2) However, looking at the Deere design, the triangular knife support 'clevis' probably never comes out of the bolted strap even when the knives are beat all to heck. My Alamo clevis and pin with cotter key DOES sometimes come loose via breaking the cotter key apparently, leaving me with a dangling clevis and missing knives, so the Alamo design MAY come apart more often than the Deere design ??
3) Our knives (Deere and Alamo) look identical even to the oval shaped elongated holes in the knives. If the dimensions are close they are probably interchangeable. The oval shaped holes in the knives are required in the Alamo case to get the clevis ends thru the knives.
So how do you get the Deere triangular clevis's loose from the knives? Are they made as one unit and you have to replace the two knives and the clevis all at the same time OR is the Deere clevis made with a gap (hidden by the strap in your picture) ??
/ Let's talk flail mowers #6,927
Whelp, within half an hour of use my AGL165 is trash.
I'm not sure what exactly happened but I think it all occurred because the vertical extension pin broke off and the mower dropped hard into ground while I was driving. The end result is the assembly is torqued where the flails hit the housing and bent the mud scrapers and flails broke - all within a few seconds. I didn't hit anything, so assume just the weight of the mower broke the pin. I'm not even sure how the flails could hit the housing but it is what it is.
Disappointed. Hopefully the company will treat me right. I'm sad I sold my Ford 917 that I've used for years without issue. I'm ticked because I had been waiting to mow after I got better belts (bx39) and a few other things I learned from the research here. This came with bad hydraulic crimps too, so bought 4 new hoses on my own just to get it functional.
I sent an email, since calling they just told me to email them anyways about the hydraulic hoses. I'm going to keep my faith they'll treat me right. I'm kicking myself for buying something I knew was cheap from the get go.
In the picture you can see how it's been torqued about 5 inches between the end (top) and the base. I may be able to twist it back, but what else is damaged? 8 flails are just gone in the middle of the tube.
/ Let's talk flail mowers #6,928
I would ask for a refund of your money as that flail mower is no longer safe to use.
/ Let's talk flail mowers #6,929
Man this sucks. Where did you purchase this? I was looking at similar ditch mowers but now I think i will stick with hydraulic side shift. Weight for those heavy duty ditch mowers would have been an issue anyway.
/ Let's talk flail mowers #6,930
I'm not sure what exactly happened but I think it all occurred because the vertical extension pin broke off and the mower dropped hard into ground while I was driving. The end result is the assembly is torqued where the flails hit the housing and bent the mud scrapers and flails broke - all within a few seconds. I didn't hit anything, so assume just the weight of the mower broke the pin................Zip..........................In the picture you can see how it's been torqued about 5 inches between the end (top) and the base. I may be able to twist it back, but what else is damaged? 8 flails are just gone in the middle of the tube.
Sorry to hear about your problem.
It looks like the flail mower housing is twisted to sort of a propeller shape.
Few years ago I ended up replacing a 72" rotary finish mower fabricated deck due to somewhat similar twisting issue or problem.
No doubt a competent metal workshop could have straightened it, but due to other wear & rust it was decided instead to replace the deck shell.
You can see the problem here if you look closely:
/ Let's talk flail mowers #6,931
Relevance of rotor diameter?
I'm [back to] looking at flails [now concentrating on one for my NX5510 rather than the B7800]. Wondering if there's any significant quality and performance issues related to different rotor diameters. I realize that knife/cutter tip speed is, given same rotor RPMs, greater with a larger diameter rotor. I can understand rotor tube thickness being an issue as well (thicker being better). Just don't know that if there were two candidates of flail with their only difference being that of rotor diameter which would be preferable (why?).
/ Let's talk flail mowers #6,932
I'd rather not say, yet, depends on how they handle this.
It was shipped across country, so whatever happens I'm sure will be a headache.
/ Let's talk flail mowers #6,933
Shipping makes warrantee a pain for us west coast folks; hate that everything comes from the east, even if made in china! I had a bearing fail in my new flail and although the seller would warrantee the thing, he would not pay shipping so changed it out here. No biggie but had to dismantle the drum and such to change it out.. Not sure why it failed, bad bearing or, more likely because I over greased it. Really like this unit, no regrets.
/ Let's talk flail mowers #6,934
Re: Relevance of rotor diameter?
Bigger diameter will be stronger, not that it is a relevant measure in this situation. Driveshafts are hollow rather than solid because most (over 90% I think) of the torque transmitting strength of a shaft is the outside. So they make them hollow to safe weight & increase performance. For a flail though, you are more concerned with running into stuff & denying it than torque transmission. So all things being equal, thicker walls will be better than a bigger diameter.
Mower (not just flail) tip speed is reasonably optimized already. Much faster & the centrifugal force on the blades makes self destruct even without hitting the occasional rock. You can make longer knives to match a smaller rotor & maintain the proper tip speed.
/ Let's talk flail mowers #6,935
Great input Fallon. I know on rotary mowers blade tip speed is set by ANSI standards to 19,000 fpm. That might also be the flail standard, I don't know. If so, and as you suggested, the circumference of the actual cutting circle can be made the same despite differences in the rotor diameter buy using longer knives or hangers. It would seem that a larger cutting circle, by whatever method, would allow slower spindle and gearbox output speeds. That can't hurt the longevity of bearings and may reduce heat. A couple of the more expensive brands built on the west coast are Rears and Vrisimo. Both are mowers meant for every day, even all day, mowing in orchards. These mowers get hundreds of hours a year on them. Rears uses a much larger rotor, larger housing etc. Vrisimo uses a more conventional size. I've always wondered about that. Would there be more of a beneficial flywheel kinetic energy effect when hitting tall grass with the larger rotor? Would there be more space "under the hood" for chewing up thick or tall grass? I think these are other considerations that often come along with a larger rotor and bigger housing overall. I generally run a Vrisimo since we are a dealer for them, but in really tall or thick grass it can really consume the horsepower trying to cut up and eject the clippings and I have wondered if a larger rotor with more room under the hood would help in that regard.
/ Let's talk flail mowers #6,936
Fallon & Dave,
Yes, great input!
I was aware that tip speed can be altered based on knife/cutter length. It's hard to find info on actual knife/cutter length.
One flail that I'm closely scrutinizing has a 5" diameter rotor (on the lower end of diameter for the size I'm looking at) which is 8mm in thickness (a little on the thin side compared to other flails, though it's hard to get such specs from others).
Larger rotor might provide more energy, though I'd figure that heavy (and perhaps longer) flails on a smaller diameter rotor could be comparable. The unit I'm looking at has hammers that are about 3.3 lbs each (18 flails).
Interestingly, the unit I'm looking at has a 7 3/4" dia roller. Large compared to a lot of comparable flails. Not sure if larger is better in all conditions, but for me I'd think it would be preferable because I have a lot of uneven ground (some ruts and such). Backing up would also likely be easier, not that backing up with a flail is encouraged.
I don't believe that there's any "optimal" as it really depends on one's use/environment. I'm just trying to figure out what is likely to work best for me: hard to part with a big chunk of money with fingers crossed! (I like to try and match up as best as possible so there's no surprises/disappointments). I don't plan on ever parting with my 6' rotary: it gets the job done no matter what I'm facing; just looking for something bigger that is more biased to cutting grass (as I open up to more grass areas).
/ Let's talk flail mowers #6,937
All things being equal, I'd rather have a larger rear roller to keep it from reacting as much to little dips and such. You can create a washboard effect if you mow a lot, mow real low and follow the same direction each time. The roller will drop into a dip which also lowers the cutters, then come out of a dip which raises them. The distance between your roller and cutter circle will be the distance between your original dip and the one you just created by scalping into the dirt. And it happens over and over again. I used to flail mow an area of our place down to about 1/2" and over the years created some areas of washboard. There are obvious ways to avoid that by mowing higher or going at a different angle. We recently switched to a Jacobsen HR5111 11' mower for this area (6'ish acres of irrigated "lawn") and find that I can mow a little quicker and get a little better finish, but obviously not as versatile as a flail.
/ Let's talk flail mowers #6,938
The d-ring (clevis) has a gap hidden under the strap. The gap is just wide enough for 1 blade.
The d-ring swings in the strap, thus the strap can wear and drop the d-ring and blade assembly. There were many missing scoop knives and d-rings on the 25A when i bought it. I changed to side slice knives for cleaning up my weedy hill pastures.
On the 390 I lose 1 or 2 blade stations/year mowing about 25 acres 6 times/year. I personally prefer the bolts over a cotter pinned pivot. Judging by the dings and nicks on the bolts and rotor rib, i can see the cotter pin getting broken fairly easily.
/ Let's talk flail mowers #6,939
[in response to Dave's last post]
I have a fair amount of trees. I'll be pushing it with a 7'+ flail; having hydraulic side shift is the mitigation.
I do mow in different patterns from time to time. Just a lot of uneven ground no matter how I look at it. I have done leveling on some really bad ruts (from skidders): those were dealt with earlier on with my B7800 and a 5' box blade - A LOT OF WORK! I'm pretty much making pasture as I go/can.
/ Let's talk flail mowers #6,940
I definitely concur. Bigger tires make for a smoother ride. A roller will be the same. It will ride over smaller rough patches smoother the larger it is.
No matter what, standard rotation flails wont cut for beans in reverse. Not sure if it's the roller pushing stuff down or the flails going the other way compared to the material feed. But on both my flails they only cut 30% or so in reverse.
I think worrying about rotor diameter & knife length might not be the most useful metric. They tend to go towards the top of the permissive range. If you have a smaller rotor you can get clevis mounts or longer knives to compensate. I'd assume the more room between the rotor & the hood the less HP it would take. But it would also decrease the mulching action a bit. The same goes for more knives. Even if it's only the vertical part not the cutter tip, the more there are the more mulching that would go on & the more HP required.
Hammers & duckfoots have a lot more surface area so should have more drag & eat more HP. Not sure how the relatively flat surfaces mulch compared to many smaller side slicers though. My Peruzzo with hammers eats noticeably more HP than my ancient 917 with side slicers, but it's an apples to oranges comparison. I dont notice that much of a difference in mulching though.
74 Gallon Delta Fuel Cell with Tool Box (A61166)
74 Gallon Delta...
Land honor Mini Skid Steer (A60352)
Land honor Mini...
2015 19ft. Yamaha SX190 Boat with 17ft. S/A Boat Trailer (A61569)
2015 19ft. Yamaha...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
2016 Nissan Sentra Passenger Car, VIN # 3N1AB7AP6GY307338 (A61165)
2016 Nissan Sentra...
2016 Ford F-650 18ft Rollback Truck (A61568)
2016 Ford F-650...
