A Tracked Zero Turn????
/ A Tracked Zero Turn???? #1
Diggin It
Super Star Member
I'm thinking, I'm thinking!
LS MT125 TLBM
Altoz TRX Series | The World's First Tracked Zero Turn Mower
/ A Tracked Zero Turn???? #2
Probably the World's last too. I can't see how those tracks would NOT tear up a lawn. My dozer is "zero turn" but It'll dig a trench in soft soil or grass when turning. And it has street-cleats not those high traction bars. Rubber or not, you'll tear up the lawn.
/ A Tracked Zero Turn???? #3
I can see it successful. There is a niche market for lower cost lawnmowers that can handle slopes well. Bet you can put this together cheaper than a Ventrac.
/ A Tracked Zero Turn???? #4
Starting cost $13,600. Tracks and cheap don’t belong in the same sentence. The whole thing is pointless. If you can’t mow it with tractor tires on a regular ZT it doesn’t need mowed. I’ve sure it’s a rough cut mower only too. It would destroy grass.
/ A Tracked Zero Turn???? #5
Slope mowers are expensive and under $14k if it can handle difficult areas a bargain. Look at what Steiners and Ventracs cost. It's not meant for a flat manicured lawn. Great video showing capabilities.
Check out the deck.
/ A Tracked Zero Turn???? #6
And HOPFULLY more reliable than a ventrac too!!!
SR
/ A Tracked Zero Turn???? #7
Cool idea Id love to demo it. I wonder how much ground tear up there is on tight turns? The machine will be way lighter than a skidsteer.
/ A Tracked Zero Turn???? #8
The look on this guy's face is saying, "Oh crap, I tore-up the lawn on this $5 million dollar house". Look in the background along the walking path and behind the mower. Is that the look you want around a pond? :eek:
/ A Tracked Zero Turn???? #9
Looks like it would slide sideways easily
They also sell wheeled versions.
No diesel offered
/ A Tracked Zero Turn???? #11
Several videos from lawn maintenance professionals posted and they claim contrary to what many think tracks don't tear up grass. Looks like they can mow slopes even when wet. Try that with a wheeled zero turn.
Yeah, LOL... I was laughing the whole time. There own clip(s) show it tearing up the grass. I guess your eyes were closed. :laughing: Mowing slops when wet? They were traveling perpendicular to the steep slopes. I can do that with my wheeled ZTR. :rolleyes:
/ A Tracked Zero Turn???? #13
From my experience, tracked Skid steers do far less damage to the ground than any wheeled Skid steer with typical industrial tires. Likewise, tracked tractors do less damage than wheeled tractors.
I just don't think these observations ring truthful when comparing Zero Turns. I suspect the tracked ZTR are alot more aggressive on grass than any turf tire ZTR, and most likely will be a niche mower. Perhaps track tread design changes will evolve.
/ A Tracked Zero Turn???? #14
They already offer more and less aggressive tracks, for different conditions.
SR
/ A Tracked Zero Turn???? #15
I posted about these before. I didn't think they would work either. Just for fun I went and test-drove one.
I have no connections to Altoz, but the tracked ones are the smoothest zero-turns I have ever used. And the videos are true -- they don't slip on wet side slopes and you can go through wet ditches just like they show. For the short amount of trial I did on a finished lawn (about 2 acres fescue) it didn't tear up the sod like I thought it would. Sure if you do a true tank-style pivot steer (1 lever forward and 1 backward) you will tear up the lawn but if you turn "gradually" it actually performed very well (as somebody above said, similar to wheeled vs. tracked skid-steer).
I didn't end up buying one because the price was higher than I could justify for my flat, finished lawn. But they are definitely worth a look if you have side slopes or low, wet areas that you need to mow on a regular basis.
/ A Tracked Zero Turn???? #16
Interesting comments regarding tracked zero turns mowers. Perhaps they are less damaging to the grass than I thought. The commercial version for Altoz, the model 766 starts at $19,200.
Cool. I was hoping somebody had seen one. I didn't search because 'new', you know ....
/ A Tracked Zero Turn???? #19
Theres a dealer near me. I looked into them last year. Walked because then there was no diesel offered.
/ A Tracked Zero Turn???? #20
This setup handles hills very well and most manufactures have this option now
2000 INTERNATIONAL 4900 - 10 WHEELER GRAIN TRUCK (A64278)
2000 INTERNATIONAL...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
TROY-BILT GENERATOR (A64553)
TROY-BILT...
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
PACER 2" PUMP, BRIGGS & STRATTON ENGINE, HOSE (A64276)
PACER 2" PUMP...
2018 HARPER ATM 72LC MOWER (A66091)
2018 HARPER ATM...
