Tach sits at 600rpm with the key off - Branson
/ Tach sits at 600rpm with the key off - Branson #1
Outlawmoon
Member
Oak Harbor WA
Branson 4720h
Back to the forum I come.....
This is a new one for me...right now the tach on my Branson 4720h is sitting at 600rpm with the key off.... Of course as soon as I start it it goes to about 1200 rpm. If you subtract the 'at rest 600rpm' then the reading is about right at about 600rpm...
Has anyone had this happen on their Branson? Mine is a 2016 model with ~500 hours on it.
Thanks!!!
/ Tach sits at 600rpm with the key off - Branson #2
Thanks!!!
I'm going to take a totally wild stab at this. I'm assuming it's a physical gauge that shows RPM? It may be connected to the shaft of the engine like on older cars. Simply a cable that can spin within a housing.
I had a speedometer cable give out on an old car years ago. The speedometer gave all sorts of wonky readings before it finally just stopped working. It was a quick and cheap fix to replace the cable.
/ Tach sits at 600rpm with the key off - Branson #3
The tachometer gets signal from a Brown wire on the alternator. Not sure if it helps, but you can always wiggle the wire.
The idling speed should be around 1000 rpm.
Well the fire is out..... Thanks ptsg. I pulled the dash, popped out the two connectors, used some canned air (the wife was busy) got the dust out. Started it up, the tach went to zero and then to 1000rpm - just like it is supposed to. I had thought it was roughly 600rpm for idle but ptsg set me straight.
Must have been some dust or something in there because for the last couple of hours it's been just perfect! My 'old engineering professor would have said it was FM. Friggin Magic............ :)
/ Tach sits at 600rpm with the key off - Branson #5
We always called it PFM, pure f------ magic!
Glad you got it fixed, have had similar problems on aftermarket tachs for cars.
Case-IH 160 Puma (A57148)
Case-IH 160 Puma...
2013 Chevrolet Impala Sedan (A59231)
2013 Chevrolet...
2015 MACK CHU613 DAY CAB ROAD TRACTOR (A58375)
2015 MACK CHU613...
2013 Ford F-450 Mason Dump Truck (A59230)
2013 Ford F-450...
2017 Nissan Pathfinder SUV (A59231)
2017 Nissan...
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
