Your towing rigs and trailers
/ Your towing rigs and trailers #3,521
Minor Axle leak.
Don’t like the jacks- not enough travel in the legs.
Tool box small
/ Your towing rigs and trailers #3,522
The oil leak might be the cover is loose , add a 3 or 4 foot box under the bed, How much are the legs to short?
/ Your towing rigs and trailers #3,523
My new trailer for my branson 5835r and whatever else I need to haul 20200727_132655.jpeg20200727_122845.jpeg20200721_143114.jpeg20200721_143102.jpeg20200721_143100.jpeg
/ Your towing rigs and trailers #3,524
The cover is loose, I’m just annoyed it’s leaking :laughing:
I have an aluminum box I can add, just didn’t expect this one to be so small.
The legs are not the kind with adjustable holes, they only have about 15” of travel, might get hung up over a hump off road when loaded down heavy. I extended the coupler, which helps, but then I need 6x6 blocks under jacks to be able to get truck out from under coupler.
I only had an hour to mess around with it today. Can’t believe jack legs are so short....maybe I wasn’t doing something right. I was kind of rushed.
/ Your towing rigs and trailers #3,525
Finally got trailer today. Its a monster, but theres a few things I dislike. Have a small axle seal leak I need to look into. Anyway, here it is
Look forward to further reports.
Looking back at the picture that tool box is small and there doesn’t appear to be any adjustment on the legs.
/ Your towing rigs and trailers #3,526
Minor Axle leak.
Tool box small
I wouldn’t like taking the time to crank them all the way down anyway. I’d throw some blocks under them and go on.
/ Your towing rigs and trailers #3,527
They are 2 speed jacks, which is nice, but yeah, now I have one more thing I have to carry-2 chunks of 6x6.
/ Your towing rigs and trailers #3,528
They look like the same kind as semi trailers have. They don't have much travel. And no they don't go high enough. I was out a while due to a hand injury. The guy who ran my route bent the right leg on my assigned trailer. Crossing track he should have known were too high. There is another entrance to the rail yard 100 feet away that is much better. Now they are hard to crank. I want to kick him down like a redheaded stepchild every time I hook or unhook.
/ Your towing rigs and trailers #3,529
I got a nice load of free Maple from someone who dosen't heat with wood. There's another load that I will get next weekend. It's been down over a year so it will be good this year. 20200809_142744.jpg
/ Your towing rigs and trailers #3,531
I got a nice load of free Maple from someone who dosen't heat with wood. There's another load that I will get next weekend. It's been down over a year so it will be good this year. View attachment 665961
My experience with hardwood logs is that they don't dry very well in log form. I recently cut (on my Woodmizer) some walnut and some oak, large logs, that have each been down for over 3 years. Surprisingly wet still.
/ Your towing rigs and trailers #3,532
^ yeah maybe if had already been cut and split. Left in long logs.... it'll still be wet inside. Get it cut and split ASAP if you need it this winter.
/ Your towing rigs and trailers #3,533
They are fairly dry judging by what they weigh. I have an old fiberglass greenhouse. I store my wood in there. I will get it split and in there. I still have a couple hot months. I open the top vents a little so air flows out the top. No rain on it. It gets over 100 degrees on warm sunny days. It will be good to go soon.
/ Your towing rigs and trailers #3,534
They are the same. Overkill is nice, but I'd rather have the kind with the 5 holes that slide up and down with spring loaded pin. Now I have to carry one more thing-blocks. I just hope fully loaded they will be high enough to get in and out of some of these rough hay fields. Should be ok, but I'd rather not add stress to hauling hay bales-theres enough of it even when everything goes just right.
/ Your towing rigs and trailers #3,535
2015 2500 Ram Laramie 4X4 6.4L with rear air suspension and 25' Sure Trac trailer. Taking the Kioti DK45 in for service.IMG_2879[1].JPG
Those green straps are only to keep the bucket from bouncing. Tractor is secured with 3/8" American made chain and Durabilt ratcheting binders. This has been a good trailer once I replaced the cheap tires (4 blowouts over several trips) with Carlisle Radial Trail HD's. Even though these are also made in China they seem to get good reviews and no complaints from me.
/ Your towing rigs and trailers #3,536
2015 2500 Ram Laramie 4X4 6.4L with rear air suspension and 25' Sure Trac trailer. Taking the Kioti DK45 in for service.View attachment 666198
Looks like bucket straightening should be added to the service work order.
/ Your towing rigs and trailers #3,537
My truck is a 2019 same setup as yours just tradesman. Your truck is sharp and looks beautiful.
/ Your towing rigs and trailers #3,538
My 2017 Ram 2500 4x4 with 6.4L gets used as a truck quite a bit:
Rob
/ Your towing rigs and trailers #3,540
Nice. I enjoy exercising mine. You put yours through it's paces. What was the plan with all of the salt ? Weed control? Lol
Just being the mule to haul the salt for a high school sports fundraiser. The kids sell salt in the community to make money for their sports teams. Being a parent with equipment I volunteered to drive around while they delivered it.
Rob
INGERSOLL RAND  G25 GENERATOR (A60736)
INGERSOLL RAND...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
2015 DODGE DURANGO RT SUV (A59575)
2015 DODGE DURANGO...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1997 Ford F-450 Dump Truck, VIN # 1FDLF47F6VEB26852 (A61165)
1997 Ford F-450...
