Checking hydraulic level on ford 340A with front end loader
/ Checking hydraulic level on ford 340A with front end loader #1
Grey Mountain
Anadarko, Oklahoma
Ford 8N, Ford 340A
How do I check the fluid level on my 340A, and where do I add hydraulic fluid?
/ Checking hydraulic level on ford 340A with front end loader #2
my 540b has a vent on the left side of the loader upright. There is a dipstick below it and also where I add fluid
According to the specs, found the following:
Hydraulic system: 8.5 gal [32.2 L]
12.1 gal [45.8 L] (independent PTO)
What does "independent PTO mean?"
And more:
Rear PTO: transmission (optional)
independent (optional)
How do I determine if I have "transmission" or "independent?"
As you can see, I am a complete novice with this larger tractor. I understood my little 8N...
/ Checking hydraulic level on ford 340A with front end loader #4
You more than likely have independent PTO, every 340A I have ever seen did. Engage the PTO then push the clutch pedal fully down. If the PTO continues to turn you have IPTO.
The hydraulic system capacity you listed is for the tractor hydraulics / rear axle not the loader.
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
2008 Toyota Solara Convertible (A61569)
2008 Toyota Solara...
DURA-CAST PRO-LICK TANK (A62131)
DURA-CAST PRO-LICK...
2015 John Deere 8345RT Track Tractor (A63109)
2015 John Deere...
UNUSED RAYTREE RMRB72 - 72" POWER RAKE BUCKET (A62131)
UNUSED RAYTREE...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
