Checking hydraulic level on ford 340A with front end loader
   / Checking hydraulic level on ford 340A with front end loader #1
Grey Mountain
Anadarko, Oklahoma
Ford 8N, Ford 340A
How do I check the fluid level on my 340A, and where do I add hydraulic fluid?
   / Checking hydraulic level on ford 340A with front end loader #2
my 540b has a vent on the left side of the loader upright. There is a dipstick below it and also where I add fluid
According to the specs, found the following:
Hydraulic system: 8.5 gal [32.2 L]
12.1 gal [45.8 L] (independent PTO)
What does "independent PTO mean?"
And more:
Rear PTO: transmission (optional)
independent (optional)
How do I determine if I have "transmission" or "independent?"
As you can see, I am a complete novice with this larger tractor. I understood my little 8N...
   / Checking hydraulic level on ford 340A with front end loader #4
You more than likely have independent PTO, every 340A I have ever seen did. Engage the PTO then push the clutch pedal fully down. If the PTO continues to turn you have IPTO.
The hydraulic system capacity you listed is for the tractor hydraulics / rear axle not the loader.
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
UNUSED LANDHERO LDHGAC40V AIR COMPRESSOR (A51248)
UNUSED LANDHERO...
2014 International DuraStar 4300 Street Sweeper Truck (A52377)
2014 International...
2020 JOHN DEERE 333G SKID STEER (A51246)
2020 JOHN DEERE...
2023 JOHN DEERE XUV590M LOT IDENTIFIER 27 (A53084)
2023 JOHN DEERE...
Hilti TE 2000-AVR Electric Jack Hammer (A52377)
Hilti TE 2000-AVR...
