light for a small engine
/ light for a small engine #1
TimberXX
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
i have a honda gx 390 electric start engine, and would light to add a working light. i looked at the specs and cant figure out the largest led light that i can fit on that unit. any ideas?
/ light for a small engine #2
Google shows it as having an 18 amp alternator, so that gives you about 200 watts, which is a lot of light from modern LEDs.
/ light for a small engine #3
Agreed 18 amps is plenty of power for a 12v LED work light, but realize that as you run that wattage to operate the work light, there is very little going to charge the battery. That is up to you to decide how you want to use that power. I would plan to put a battery charger on if using half or more of the available wattage (216) in the work light.
/ light for a small engine #4
Depending on how many lights you're going to put on
your charging system will have more than enough to keep your battery charged up and run a few lights. No worry...
/ light for a small engine #5
/ light for a small engine #6
On my Mitsubishi CUT everything is LED now.
Even my interior lighting is a 12' LED strip.---- BRIGHT !
My DIY yellow strobe is hi power LED's and works great, mind U I could have purchased for much less but it was a challenge.
My turn indicator is a 3' yellow LED light bar
2 rear LED floods for snow duties
Front is a 12" light bar with center being spot and 2 side 4's flood---- just like daytime!
Also for snow duties I DIY'd the chute using a 2000 lb ATV winch for rotation. (more than 8 years and going strong)
LOL, my heated cab is also DIY.
Oh, and I installed a back up camera to save my neck when blowing snow.
Ask me if I like to DIY/tinker ? and do I like LED's ?
I use one of these on my BCS 853 with the 390 Honda. Amazon.com: Nilight LED Light Bar 4PCS 4 Inch 18W LED Bar 126?lm Flood Led Off Road Driving Lights Led Fog Lights Jeep Lighting LED Work Light for Van Camper SUV ATV ,2 Years Warranty: Automotive
I ordered 4, with 3 of them used on my DX55 tractor and the 4th used on my BCS. A single light is plenty for my use, and I've never had a battery issue but I don't use it for hours at a time.
I have a BCS 770, how did you install it?
/ light for a small engine #8
I used mine on my previous BCS, a 605, with a round welding magnet so it could be moved to the front of the engine or on the steel handle support. I used it primarily as a headlight while using my sulky and trailer, so the engine was out front. Now that I have a 853 with plastic covering the handle support, I need a new mounting point. I also intend to use it for snow plowing or blowing, so an engine mount won't work since it will be to the rear. I thought about mounting a piece of flat stock wood or metal between the handle bars close to the pivot point with pipe clamps holding the flat stock to the handles, and then mount the light to that. But I found these mounts Amazon.com: Nilight LED Light Bar Mounting Bracket Kit LED Off-Road Light Horizontal Bar Tube Clamp Roof Roll Cage Holder,2 years Warranty: Automotive under the same manufacturer as the lights I listed above. I think they will work perfect for a handle bar mount on my BCS.
/ light for a small engine #9
I forgot to add ^^ that I keep a ring terminal Batteryminder pigtail on my battery. That makes it easy to plug in my Batteryminder to refresh my battery occasionally so it isn't stored with a low charge and is always ready to start. With that pigtail on the battery, use that to connect my flood light. I do have a switch on my light, but it's easy to disconnect the circuit when not used or when I remove it.
/ light for a small engine #10
I ordered a pair of these tube clamp mounting brackets, so I'll post back when they arrive and I get a chance to try them on the BCS.
awesome thx
/ light for a small engine #12
TimberXX, I received these mounting brackets and temporarily added one to my BCS for a test fit. I used the medium rubber inserts and needed a clamp to squeeze it enough to get the screws started, but it worked great. I installed it on the right handle bar just below the plastic shield almost on the bend of the bar. I added the light I linked to above with a single bolt and fished the wire under the main handle support with the other cables, and out the side holes on the blue shield, finally connecting to the battery pigtail with a plug. The lights have a bracket that is adjustable left/right, and up/down.
The brackets come as a set of 2, and I plan on using the extra on on the left side to hold the support for my snow blower chute crank handle.
/ light for a small engine #13
I tightened down the brackets and light mount on this ^^ and I like how it turned out. One thing I didn't consider when mounting it on the handles is how the light angle changes when I raise or lower the handles. I haven't experimented with it enough to be sure, but I think a 'medium' handle and light adjustment will still give me plenty of light when I raise or lower the handles. Those light produce a fairly broad flood of light.
2003 McCormick XTX 185 XtraSpeed Tractor (A63118)
2003 McCormick XTX...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
NEW HOLLAND TS115A TRACTOR (A62130)
NEW HOLLAND TS115A...
2015 New Holland TS6.110 Tractor with Alamo Boom Mower (A64047)
2015 New Holland...
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
2017 Grand Design RV Toy Hauler Camper VIN # 573FS4334H1108024 (A61166)
2017 Grand Design...
