Tell me what you see here?
Status
Not open for further replies.
/ Tell me what you see here? #61
Keep in mind that mesh and rebar do two separate and different jobs. At least according to the manufactures of each.
/ Tell me what you see here? #62
Mesh isn't going to provide much tensile strength for any distance. It's obviously limited in it's tensile strength as well, but what it lacks in diameter it makes up for in reduandancy.
/ Tell me what you see here? #63
From what I understand, rebar is to prevent cracking and the fibers are to prevent cracks from getting larger once they occur.
/ Tell me what you see here? #64
A rat wall is a trench dug around the perimeter of a structure usually to the depth of the frost line (here 4 feet) and it's required by building code. What we call it here.
We call that the foundation.
/ Tell me what you see here? #65
There is no requirement like that for a pole barn here. I had a pole barn built here about 10 years ago and it has a 6 inch floor with the edges about a foot thick. I have no rebar in the floor, just fiber in the concrete over compacted crushed cement. The only cracks are in the sawed control joints.
/ Tell me what you see here? #66
I don't expect rebar to prevent cracking. I expect it to prevent movement after the cracking.
/ Tell me what you see here? #67
Beyond the issues with the floor, that whole building looks pretty cheesy to me.
I don’t see a lick of diagonal bracing in the walls or roof structure. Forty by fifty and 12’ high is a lot of wind area..
B. John
/ Tell me what you see here? #68
What I don't understand about the argument that they don't need rebar; why then, did they show the attempt to use it?
/ Tell me what you see here? #69
Maybe, adds nicely to the cost.
/ Tell me what you see here? #70
If all you want is concrete under your feet, it does the job.
A little more work could have made a better pad, but it will do the basic job. I see it done like that a lot in pole barns here in Texas. Many pads are just wire mesh with concrete poured 4" over it.
I have even seen concrete poured right over grass when I was younger, and the concrete is still there and being used today. Of course concrete was way cheaper back then.
/ Tell me what you see here? #71
Yeah, I didn’t communicate correctly.
I got this from quite possibly the best concrete thread ever. This guy seems to really know his stuff... The Concrete Underground's Guide to Floor Slabs - The Garage Journal Board
Reinforcing - Concrete is stronger in compression than it is in tension i.e. it's harder to crush concrete than it is to pull it apart. Steel reinforcing is used to increase concrete's tensile strength. Many people apply this principle to slabs on grade and assume that steel reinforcing will prevent cracking and make the slab stronger. Unfortunately neither is really true.
The most common cause of cracking is tension from drying shrinkage. Reinforcing won't stop your slab from shrinking or prevent shrinkage cracks. In fact, reinforcing can actually increase the likelihood of cracks by restraining the slab from contracting inward as shrinkage occurs.
Reinforcing doesn't make your slab stronger because it's passive i.e. it doesn't come under load until the concrete has already cracked. Since a typical slab isn't thick enough to act like a beam, it simply 'bends' and transfers loads to the base below. If the base can't take the load, the concrete will crack.
What reinforcing will do is keep cracks - whether they are random shrinkage cracks, the cracks in the bottom of your control joints or God forbid, structural cracks - from opening up thereby maintaining the integrity of the slab. Think of steel reinforcing as crack restraint rather than crack prevention.
Is steel reinforcing absolutely necessary? Not really. For most residential slabs placed on a solid base, it's optional. If you limit shrinkage and cut timely, properly spaced control joints, the cracks below won't get very wide and aggregate interlock will keep them from displacing. Many, however will want the added insurance of reinforcing.
Slab reinforcing can be either rebar or welded wire fabric (WWF), often referred to as wire mesh. The primary advantage of rebar over WWF is that it is more rigid and thus easier to support. If using rebar, I’d suggest #3 bars at 18” o.c. supported every 3’ or #4’s at 24” o.c. supported every 4’.
If you decide to use WWF, buy sheets rather than rolls so it will lay flat. Use WWF with a heavier gauge wire such 6x6-W2.9xW2.9 that will span between supports better. Overlap the sheets 6" and stagger the runs to avoid building up too much thickness at the overlaps. You'll need to support mesh every 3' or so - don't let your finisher convince you he can pull the wire off the ground as he places.
Support your reinforcing in the middle third of the slab. There are many products available to do this such as concrete dobies, metal slab bolster or plastic chairs. Make sure your supports can stand up to finishers walking on them and that they don't poke through your vapor barrier.
If you are placing a load bearing monolithic slab, I'd recommend using rebar including a couple bars in the bottom of the thickened haunch. Floating slabs are subject to more movement and rebar will hold everything together.
Fibermesh These are fiberglass strands that are mixed in with the concrete and advertised to prevent cracking. It is often discussed as an alternative to steel reinforcing but it performs an entirely different function. Fiber minimizes early age shrinkage cracks and theoretically allows wider control joint spacing but it won't hold cracks together once they occur.
/ Tell me what you see here? #72
Thats a pretty good summary and how I was taught about different methods of reinforcing.
The way I look at it, its YOUR work on display. Will your concrete crack? Lets hope not, but maybe it will. Nobody really knows. When it does, can you give yourself or your customer the assurance that the crack wont expand and become really ugly or structurally unsound?
I install mesh mats and rebar and order fiber. Lot less costly than removing the slab and starting over. Of course, proper ground preparation and proper concrete mix is a given, but adding reinforcement lets the customer know you care and gave it your best and left nothing out.
/ Tell me what you see here? #73
Interesting read on the reinforcing. Not quite sure I agree. The building inspector for my driveshed was a real stickler for rebar. A lot of it, and in the right places. Particularly as the buidling was set into a hillside. I find it hard to believe that all this rebar does nothing, if the concrete has not cracked.
Corner of building into hillside. Paint cans are for various utility lines.
/ Tell me what you see here? #74
This is a wall not slab on grade. Two totally different structures
/ Tell me what you see here? #75
When it comes to concrete, tension is tension and compression is compression, regardless of orientation.
/ Tell me what you see here? #76
Beat to death but another opinion.
-no doubt too wet, then again if you subscribe to "water seeks its own level" that works, forget about strength, no need for screed bars that you have to pull up before floor sets and you have to pull and fill with excess material you have kept in wheel barrows- you get what you pay for.
-Sand with no compaction?????
-Rebar in sand? How about heavy wire mesh on chairs and then as you are pouring someone is pulling wire up selectively to get wire off base material where
it is too far from chairs.
-No control cuts at 10' centers max cut while concrete is setting and very green Slab like that will crack for sure.
/ Tell me what you see here? #77
The dude poured his own slab, for himself. He didn't break any laws of nature doing so and seemed quite happy with the outcome. More power to him.
/ Tell me what you see here? #78
No one said he broke any laws. I like to think the value of TBN is it is always a great learning experience.:thumbsup:
/ Tell me what you see here? #79
He hired a company to pour his concrete. Professionals. The discussion has been about their procedures.
/ Tell me what you see here? #80
I thought he hired a concrete contractor to do it? The only thing I saw him do is walk around taking a selfie videos about his wifes concrete curb he had to do for her. :confused:
Status
2024 Ford F-150 STX 4x4 Crew Cab Pickup Truck (A61573)
2024 Ford F-150...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
2017 Ford F-550 4x4 Ext. Cab Auto Crane 4004EH 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
2025 Dingo Ditch Bucket Skid Steer Attachment (A61572)
2025 Dingo Ditch...
Generator Motor & Wheel Spacers (A64119)
Generator Motor &...
2025 IRANCH IREAS Wood Grab Grapple Mini Excavator Attachment (A61572)
2025 IRANCH IREAS...
