AC question
/ AC question #21
As a dealer of commercial refrigeration units I can tell you that propane is used and is getting more popular. It will not be long and you will be hard pressed to find a commercial unit that is not propane.
The only issue I have seen so far is the misunderstanding of propane scares most technicians and they refuse to deal with it. The answer is becoming none field service units. Something goes wrong and the guts of the unit slides out and is replaced with a new charged unit. It's a plug and play that anyone can do without a refrigeration license. But of course I have to maintain a license to sell commercial refrigeration units.
/ AC question #22
Here's more info on TXV block valves. Keep us posted, Cougsfan.
Regarding ammonia, recall that liquid anhydrous ammonia is dumped all over farm fields as fertilizer with no mass casualties.
Regarding propane, recall that commercial propane is used for heating all over rural lands, with only the occasional mass casualty. It is transported by road, rail, pipeline, sea, and even air.
Both must be in the millions of tons per year, handled routinely and, for the most part, safely.
View attachment Refrigeration TXV valves.pdf
/ AC question #23
Those "block valves" are shown on page 194 and 195 as keys 5&6. they are called "Q/C 7/8" and Q/C 5/8" and do have a Branson part number. They could indeed be just bulkhead fittings and they have a bad translator. It is funny that the parts diagram doesn't show the expansion valve or the dryer receiver, yet I can buy them if I call the dealer. And my tractor definitely isn't exactly the same as all the things they show.
Bad translation should be Branson Tractor's middle name as far as the manuals go lol. Expansion valve, blower motors, resistors, and etc. have never been shown separate from the entire HVAC unit ever since the 6530 up until all present cab models but they did finally start carrying them about 2 years after they released the 6530. Just never illustrated in the parts manuals. On the dryer, I wonder if there wasn't an undocumented running change to having it built into the condenser. Does the condenser happen to be bigger on one side with plastic caps on top and bottom of the bigger side? Jaxs would be very surprised how easy it is to become a certified Mobile HVAC Technician. Literally an open book test. The hardest part is pulling the $25 out of your pocket.
/ AC question
This thread has morphed into a interesting discussion on refrigeration in general. I will not pull my tractor apart until the (hopefully correct) parts arrive and will let you all know what happens.
I have seen numerous places where a particular type of cubical looking type of expansion valve are called block valves, referring to their block-like shape. All along I was thinking of a block valve as a valve that "blocks" flow. No wonder the Koreans have trouble at times translating:).
I also see a lot of misconceptions about the dangers of refrigerants. Everyone seems to imagine and concentrate on the extreme and unlikely consequences of using various refrigerants. Ammonia is actually fairly safe to be around. It is used in commonly used in food processing freeze tunnels with no intermediary coolant. The coils used to cool or freeze the product are full of anhydrous ammonia. Even in the rare cases where it leaks, it really doesn't poison the food product (the food would likely be regulated to animal feed only because of the likelihood of minute amounts of a very pungent aqua ammonia being trapped within the food). Of course in extreme situations ammonia can be dangerous, even deadly, but so can any other refrigerant (including water). The simplest common sense precautions and practices minimize the risks with most any refrigerant. The main reason ammonia isn't be used in automobiles or homes is because of it's extreme odor, not because it is so deadly or hazardous. Propane is a fairly safe refrigerant too. I think all of you who use an outdoor grill are exposed to far greater "dangers" from propane than you would be with a propane refrigeration system. Not many people seem to freak out about using a grill. R12 was banned because of it's environmental impact on the ozone layer, not because it proposed a threat to the user. Varied other refrigerants present minimal risks if you use common sense. People saying you can't use ammonia or propane in a home refrigeration system because of the high chances that you might die in the middle of the night if they had a leak is preposterous. There may be other valid reasons we don't use them, but its not because of that.
/ AC question #26
I don't know if this helps, but when I took the top cover off of my cab, there were some A/C components under that in the rear of the roof. Sorry if this is more misleading than helpful.
/ AC question #27
Cougsfan, since your tractor doesn't have the receiver-dryer called out the the pdf diagram attached, the lower of the two "block valves" must be a strainer and, presumably, a dryer. The filter is always just upstream of the TXV because the TXV has the smallest opening in the system. The upper of the two "block valves" is just a bulkhead fitting. Ironically, it looks from the diagram that the TXV they use is a block valve. Those two items they're calling out as "block valves" can't be what they are because the whole idea of a block valve is that there's a control rod passing between the vapor side (the bigger tube on top in your photo) and liquid side. Those two components only share a bracket.
  • Cougsfan AC TXV, smaller.pdf
/ AC question
You might be right about those bulkhead fittings they call a block valve being a screen, Bernard. They look to be too complicated to be a simple line connector. Claggstractor mentioned the receiver/dryer might be above the ceiling next to the TXV and evaporator, Right after they made my tractor, they made a modification that made the 4720ch's rather low ceiling much higher (A much needed improvement). Maybe they did that by moving the receiver/dryer from the roof area to the front of the tractor like all the diagrams show. It has to be somewhere, and that sounds like a good explanation. When I pull the ceiling I will find out.
/ AC question
The plot thickens....... I got the expansion valve and dryer/receiver from Branson. So I pulled the roof off my tractor to see what I could find. I do not have a dryer/receiver anywhere!!!! The books show one in front of the condenser. There isn't one. You can closely follow ever inch on the line out of the condenser up to the expansion valve (exept where it goes up through the cab frame tubing to the roof area, where it is too tight for the dryer/receiver), and there just isn't one! We looked at the places it shouldn't be. There still isn't one. That may be hard to believe, but that is indeed the case. I have a call into Branson and can hopefully get an explanation of how that could be.
I did get the correct expansion valve, so we changed it. (they coat the expansion valve with a sticky, gooey black plastic wrap which makes an easy job miserable) While we had the valve out, we disconnected the lines into an out of the compressor. We blew air through the condenser, evaporator and every single line looking for line restrictions. There were none. We put the system back together and pulled a vacuum for a couple hours (It holds a vacuum fine). We charged the system. It came up to the correct pressures (22 psi on the suction, 210 psi on the high side). The expansion valve got cold on one side and hot on the other, cool air was coming out of the ducts, just like you would expect.
But after 5 minutes of running, the pressures started rising. 300+ on the high side, 35 to 40 psi on the low side. The air out of the ducts stopped being cold and the expansion valve temperatures lost its temperature differential. The high pressure line out of the compressor got very very hot. Shut it down and let it set for a half hour and cool down.
Started it up again.... Same thing.
We decided to pull the evaporator apart to see if it was plugged on the air side. (Not an easy job!) The was some dirt on the fin inlets. We blew it off and put it back together and tried it again. I also re-cleaned he condenser for the umpteenth time (it was quite clean). No change in how things worked.
It appears to me the system is loosing flow through the evaporator somehow.
One thing I thought of is maybe there is some moisture in the system, and if there is, it would accumulate at the coldest point (The discharge of the expansion valve/ inlet of the evaporator area). Possibly that moisture is freezing into ice after ity runs a while, blocking the freon flow (??) I do know that evaporating moisture out of a refrigeration system is a temperature/pressure/ time relationship. Moisture vaporizes easier at higher temperatures and lower pressures, and it takes time for that to happen. In ammonia systems we held a vacuum for 24 hrs to fully purge the system of moisture. I am holding it at a vacuum overnight now and recharge it in the morning to see if it helps, but to be honest, I don't thing it will.
I can see how a system could "work" without a dryer receiver, but it seems like it would be a very troublesome system. A I understand it, its purpose is twofold 1) remove and hold any moisture in the system and 2) serve as an accumulator for extra freon needed as the system changes temperature states. I still can't believe one was never installed.
That brings up another point. According to the book, my system should hold 2.87 lb of freon. It holds more like half that, probably because there is no dryer receiver. I have charged it several times now and that's all it takes!
It has also occurred to me that I may have some sort of problem on the controls side, but as I think through it, I don't think so.
Another thing that worries me is that we lose a tad bit of oil every time we take the system down, I don't see any way of verifying there is too little or too much oil in the system.
Anybody have better ideas of what to do next.
/ AC question #30
Amazingly frustrating. A few questions:
1. What year is your 4720ch?
2. Did you figure out what the two "block valves" are? The ones in the photo you posted.
3. Can you upload a photo of the receiver-dryer and the expansion valve?
4. Can you upload the diagrams you mentioned?
/ AC question
It is a 2017, It has the low ceiling, right before they made it higher.
I didn't tear them apart, but I think the block valves are just bulkhead fittings. They don't restrict flow in either direction.
I will work on your other two items. In fact I will take several pictures.
/ AC question #32
/ AC question
Here are some pictures:
First, where the service manual shows the receiver dryer:
This is what mine looks like. Not at all like they show. As I said, if you follow the line out of the condenser all the way to the expansion valve, no receiver dryer.
This is the new receiver dryer (still in the bag as I may have to return it) and the old expansion valve (My guess is there is nothing wrong with it.)
This shows the evaporator and newly installed expansion valve under the roof. I took the ducts out of the condenser off to remove the lid on the evaporator and haven't put them back on yet. I also need to re-insulate the expansion valve. I'm going to cut up some sponges and tape them around the valve (if I ever get things working). That sticky, rubbery tar the factory put on for insulation is the pits!
As a note, after setting 6 hours with a vacuum, the system did loose just a bit of the vacuum. So it is either moisture evaporating (hopefully) or a leaky quick disconnect on the vacuum pump hose connection (more likely).
/ AC question
The picture in the manual shows a electrical connection on the receiver/dryer. What would that be for?
Also thanks for the manual, Lou. I will read through it. I can't believe how much I have learned about automotive style ac systems in the last couple weeks (unfortunately, I haven't yet learned enough.)
/ AC question #35
On the pdf I attached on page 7 the New Hollands have "self sealing quick connects" I wonder if the Branson QC's you found are similar if so is it possible that some particles got into one of them from your failed hose.
/ AC question #36
That plug is most likely for a low pressure switch. You are doing a great job of working this problem. You will find a solution no doubt!
/ AC question
Lou, it is probably the same self sealing quick disconnect. It is one that is standard for automotive type systems. It is very much like a standard air hose quick disconnect except it has a rubber seal at the base of the female fitting. My friend says that in his experience they hold quite well but sometimes seep if held under vacuum for a long period of time. Probably from specs of dirt on the seal. He prefers the old threaded connections that are no longer used.
He has a set-up for flushing the system with some type of solvent made for refrigeration systems. He uses it when a compressor or a dryer fails. My oil is still quite clear so I am not sure we need to use it. No contaminates came out when we blew air through the lines.
/ AC question
Lou, I was reading through that PDF and found the "self sealing quick disconnects" you were talking about on page 7. Those look identical to the "Block valves" in the Branson we have been talking about and they are at similar points in the system. They don't look much like "quick disconnects" though 'cause it takes a handful of different wrenches to disconnect them.
/ AC question #39
I would try putting a big fan in front of the condenser and attempt to get the prescribed charge in the system.
/ AC question #40
This great nation was founded by people who didn't know what they were doing, and it grew mighty with the help of many more such people. We're scolded for it, but it's our indomitable, independent spirit coming through.
In looking at page K25W-201504 of the 20 series service manual which applies to the 4720, the "block valves" look like they're just bulkhead fittings, not valves. Here's a picture of the diagram to help envision the schematic of the pattern, and I've colored the "valves" red. The expansion valve is on the evaporator, and I've colored it blue:
My take on "block valves" is this: At some point in the assembly process the cab is married to the tractor chassis. The AC system components in the roof , aka evaporator and expansion valve can be filled with freon and checked for functionality including possibly the setting of the expansion valve release pressures. Meanwhile the tractor chassis can be filled and operated, checking functions on it's assy line ready to mate with the cab.
Both assemblies could have blocking valves incorporated in their interconnecting hose connectors to retain any refrigerant/oil that may be a result of production line testing, and to prevent proper processing and filling of the AC at final assy.
On the side of my engine my lines meet and one is supported by a clamp to hold it in place. I am assuming that the cab it placed on the chassis and interconnections are completed. For the AC system, it's a matter of mating the two connections and the AC system is ready for shipment.
You can buy pre charged lines for home AC systems that perform the same function.
2025 44in Single Cylinder Grapple Rock Bucket Skid Steer Attachment (A66734)
2025 44in Single...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2005 Ford F-450 Crane Service Truck (A66736)
2005 Ford F-450...
2022 East Manufacturing 48ft. T/A Walking Floor Trailer (A66736)
2022 East...
2018 CHEVROLET SILVERADO REGULAR CAB PICKUP TRUCK (A66091)
2018 CHEVROLET...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
