Cougsfan
- Joined
- Sep 10, 2008
- Messages
- 1,652
- Location
- Eastern Washington State
- Tractor
- Ferguson TO35, Branson 4720CH
The air conditioner on my 4720ch stopped working. I found the hose out of my compressor to the condenser had been leaking and replaced it. On charging the system we found it would not take nearly enough refrigerant and both the low end and high and pressures were way too high. (350 psi on the high end, which is probably why the hose started leaking.). All this seems to indicate a blocked flow somewhere, probably a faulty expansion valve (The shop service manual is really good at covering all this). So I have ordered an expansion valve and receiver/dryer (a good chance it may be the problem too). My first question is: where in the heck is my receiver/dryer? The manual shows it in the line out of the condenser mounted in front of the condenser. It definitively ain't there.
Also, as you follow the line out of the condenser along the chassis right below the engine there is what they call a block valve. What the heck is that? It isn't discussed at all in the service manual. The reason I ask is because when attempting to fill the system, the line before the block valve felt appreciably warmer than the line out of it. I am just wondering its function and might it be plugged.
