Tractor backhoe - homemade
/ Tractor backhoe - homemade
That part is still not done, mount frame is missing, I left that as the last thing to do. It's gonna be like this one
bmw 640i 0 60
/ Tractor backhoe - homemade #1,302
From your YouTube video, frame with quick attach :
BFreaky's is the same style frame, there is no quick attach on it:
:thumbsup:Now I see the light, as usual I was missing something, and I'm not even going to ask how you got that picture off a youtube video cause if I did I wouldn't understand it............
/ Tractor backhoe - homemade #1,303
Well done ! The light is always at the end of the tunnel, it's just that the path sometimes is a head scratchier
Frame is done
/ Tractor backhoe - homemade #1,306
Frame is done
I can't quite figure out the linkage there in the front of the loader. Are those forward half/cylinders used for adjusting the bucket angle while the bucket is being used....or are they for latching the quick change to the bucket?
rScotty
Cylinders are used for angling of the bucket. I'm not sure what's puzzling here...paralell linkage?
/ Tractor backhoe - homemade #1,309
I cant quite put my finger on it but something tells me your going this direction at all.......
/ Tractor backhoe - homemade #1,310
BFreaky is using the Euro Style quick attach for the loader, instead of the Skidsteer quick attach. It's very common here. It's stronger and safer than the Skidsteer quick attach.
Basically, there is two hooks on top that engage on the top round bar. Then two eyes on the bottom, where two pins lock it in place. These pins are often moved by a single lever in the middle or on some commercial versions, it's spring loaded and locks automatically once the implement falls into place.
Here is the back of the bucket:
And the quick attach with the single lever in the middle and the linkage to the pins.
/ Tractor backhoe - homemade #1,311
Thanks that sheds a lot of light on how this QA works, it does look like a good design with just one lever, I'll save those pics just in case someday I change my pinned bucket someday.
/ Tractor backhoe - homemade #1,312
Thanks for doing that, ptsg. Very nice explanation with the pictures and captions.
The skidsteer system popular in the US is adequate, but not so bulletproof.
rScotty
/ Tractor backhoe - homemade #1,313
rScotty
Skidsteer system is popular among compact tractors, but on heavy loaders on farm tractors, Euro is standard, and skid steer qa isnt even an option.
/ Tractor backhoe - homemade #1,314
Can you take a quick look at this SSQA project and tell me if your Europe stile QA is or would be lighter? This guy on his blog did a lot of work, to much work for me and according to his figures added 120lb to the total bucket weight. I thought QA was to make thing lighter, whats your thoughts?>>> Shop Stuff - Quick Attach Bucket
/ Tractor backhoe - homemade #1,315
Now that I see how both QAs work, I can see a couple of differences between the SSQA and the European style QA. They are quite different in the tolerances required to make them fit and the way that they wear.
The SSQA uses hardened bevels fits on both the top and bottom connections to the bucket. Those bevels - always under compression by the over-center levers and large compresion springs means the SSQA continually tries to tighten up the bucket connection to the loader as you use it.
Instead of wear amplifying critical clearances, wear on the SSQA type QA actually makes it fit better.
The European style QA uses simpler parts to fabricate and can be easily be made to be very strong, but requires exact assembly and doesn't self-compensate for wear. I wonder if they begin to rattle when they get older?
There are probably other QA systems as well - each with it's own set of advantages. I know that JD uses a proprietary system but I haven't looked into it.
rScotty
/ Tractor backhoe - homemade #1,316
A quick attach will never be lighter than a direct mount to the loader, like the current setup you have, because you're adding extra stuff to make that attachment swap easier.
On the other hand, I can see that the SSQA can be a bit heavier than the European style because of the extra SSQA adapter plate that gets welded to the bucket.
The one I shown on those pictures, I built it myself and in my true fashion, I did overbuilt quite a bit. I believe it was around 100 lbs, but could be lighter and still work perfectly fine.
If this will make that much of a difference for you? Well, I don't think it'll be that noticeable. If your plan is to get a set of forks (which I fully recommend), you'll actually be able to lift heavier logs because you don't have the bucket pushing the load forward anymore.
/ Tractor backhoe - homemade #1,317
rScotty
Tolerances are not that critical unless you don't want to get any rattle at all but then, it can be a pain to put things on and take things off. You do want some play on this stuff.
As far as wear, I don't think it'll be a problem. The way it works, doesn't increase wear on anything like that.
I've never seen any cases of the attachment falling off on a Euro style but I've seen several with the SSQA.
/ Tractor backhoe - homemade #1,318
rScotty
Thats a couple could points right there that I never thought of..........
/ Tractor backhoe - homemade #1,319
More lift capability with QA is the main goal. I now use short and long clamp-on forks on bucket and loose a lot of lift but I most do bucket work and right now with bucket full of dirt it feels like the FEL is maxed out and feels like I'm lifting a mountain, that why now I dont if I want to add more weight to bucket on my small tractor, need more re-think, thanks for your input!!
This is the issue I have with bucket forks short or long, you might of already seen this before, but talk about the need for QA..........Heavy red oak slabs - YouTube
/ Tractor backhoe - homemade #1,320
Well, on the wear.... It needs to be loose enough to be easy to mount, and If that type of loose connection doesn't get grit in it and wear it would be surprising. But I agree that it would take a long time to wear so much that the strength was threatened. And it is very positive if you don't mind a bit of rattle when moving around with the bucket empty.
And the Euro style is a lot more positive. It's more like a 3pt quick hitch - nothing can fall off of those either. I'm with you on things falling off the SSQA, as I've seen it too.... more than once. And in falling off the hitch can be seriously damaged by twisting. But that's a failing of the operator rather than of the design of the hitch.
John Deere Green Star 3 2630 Display (A64119)
John Deere Green...
UNUSED WOLVERINE HYD GRAPPLE BUCKET (A64281)
UNUSED WOLVERINE...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
2021 Case IH 540 Steieger (A66285)
2021 Case IH 540...
2020 International HX620 Quint Dump (A62613)
2020 International...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
