Tractor backhoe - homemade
/ Tractor backhoe - homemade #1,281
Good picture of the self leveling linkage on the loader arms :thumbsup::
Well, I will not build my own tractor, I'm happy with this one.
Yup, here you can see the whole geometry. FL is almost done, I hope to paint it in a few days...
/ Tractor backhoe - homemade #1,283
Almost seems like your FEL is closer to the front tires then most tractors with FEL, good for digging but will loose in reach.
You're right it's 25 cm closer then the previous one and also 12 cm lower main pivot point. This way I get lower center of gravity and better control of the bucket
Finally I found the time to clean up the loader and paint it...so here it is in primer.
/ Tractor backhoe - homemade #1,287
Good to see you have it nearly done. Looks heavy duty.
How have you been doing? Has the virus been horrible over there?
Arm profiles are high but not very thick, only 6 mm so it's not really heavy but has to withstand all the loads with no sweat.
I'm fine...too much other work, no time to relax...so my personal projects always have to wait...
Today they say we have 100 new positive patients, that's nation wide. We almost have no feeling it exists...when you go to a store etc, you gotta disinfect hands, few older people wear masks and that's it...
Painting is done, now I have to wait 2 days till it's dry enough for assembly
/ Tractor backhoe - homemade #1,290
Bet the front part was hard to paint near the floor.
/ Tractor backhoe - homemade #1,291
What color are you going to use to paint to highlight its name if any? The tractor color might be an option? You do awesome work.
Oldpath, there was no unreachable spot, that's why he's hanging on a crane 😁
It will have a name of my "one man company" and it will be red acc to RAL chart 3000
Final assembly...
/ Tractor backhoe - homemade #1,296
Looking good, that quick attachment mount seems to look different than most I've seen.
When it's done there will be videos. Which mount? You mean tractor console?
/ Tractor backhoe - homemade #1,299
New/Unused Quick Attach Hydraulic Rock Hammer (A65583)
New/Unused Quick...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A61573)
2016 Peterbilt 579...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Bucket Truck (A60352)
2018 Freightliner...
2018 International LT Automatic Day Cab (A62613)
2018 International...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
