coastal multitrac tractor fluid
/ coastal multitrac tractor fluid #1
Sam L Series
Florida
Kubota L3301 HST
I am doing my 200 hr hydralic oil change on my L3301 and found this by Coastal
it says that it is equivalent to Kubota UDT and Super UDT.
anyone else use this?
Thanks
Sam
/ coastal multitrac tractor fluid #2
First fluid change? I use nothing but Kubota branded fluids.How much are you really saving?
/ coastal multitrac tractor fluid #3
I read that the oil mfg folks right wherever they want and there is no way to know if it really meets spec. In my case I use Kubota hst fluid.
/ coastal multitrac tractor fluid #4
There was a lot of write-ups on UDT and Super UDT years ago. I don't recall specifics but there was a substantial difference between the two. How does Coastal meet both specs? For a 20 year old rag tag tractor, I'd probably use Coastal. But NOT for a 200 hour tractor. :rolleyes:
I called the below and tech support said equivalent.
also on Kubotas site and in the manual it states UDT or Super UDT to be used...
Super UDT II is a multipurpose for all weather... cold ad hot. I live in Florida and it should be thicker...
WARREN OIL COMPANY, LLC
P.O. Box 1507 Dunn, NC 28335
General Information:
(800) 779-6456
New Customer Sales:
(800) 779-6456
Customer Service:
(800) 779-6456
/ coastal multitrac tractor fluid #6
I see if you don't get a satisfactory answer on OTT, you mine this forum for an answer. The answer is still the same. Cheapo fluid isn't Kubota SUDT.
People amaze me...
People amaze me...
What makes you think Coastal is cheep quality?
Warren Oil Company makes oil for most other oils brands like STP etc...
Oh I get it, opinion, not fact.
Just saying Kubota is not the only quality brand out there in case you don't know.
Thanks for your opinion.
Do we know that? Has anyone seen an independent lab comparison?
That's exactly my point.
What makes anyone think Coastal is cheep quality?
Just saying Kubota is not the only quality brand out there in case you don't know. I printed there pdf which stated ubota UDT and Super UDT.
In Kubotas own manual it stated use UDT or Super UDTII
it is over an hour drive to a Kubota dealership, and other quality brands are sold locally. like Coastal by Warren Oil Company. Warren Oil Company also make the exact same multitrac tractor fluid being sold my STP.
Thanks for the response.
/ coastal multitrac tractor fluid #10
I wouldn't call STP as a non-cheap example brand. (Your referral) The additive isn't what it used to be. It failed miserably against straight synthetic oil. If they're peddling STP motor oil now, I'd take the name with a grain of salt. As far as Warren making claims, what did the Kubota dealer say? Is it the same? That's where you'll be getting warranty work done, now doubt. :ashamed:
/ coastal multitrac tractor fluid #11
Hey, no big deal. It's your tractor - use whatever you want. I use Kubota UDT. It's no more expensive than other premium brands and I know it's made for Kubota.
As far as any oil being equal or better. Hard to tell with all the "factual" advertising and claims.
I don't think I'm peddling anything just stating my findings. and Yes STP is sold in Autozone and coastal multitrac tractor fluid and STP multitrac tractor fluid are packages the same and Autozone rep said that they are the same made by the same company.
/ coastal multitrac tractor fluid #13
Oil is NOT just oil. There are many additives and base oil types. The engineers that designed your tractor used certain oil properties when specifying bearings, gears, friction plates and such. Only they know the specs. Industrial equipment usually recommends certain oils by name for that reason. Except for oils with the API mark and grading, and so specified by the machine manufacturer, I only use manufacture's oil. Deere, CAT, Kubota, et al. don't produce oil but they do specify oil properties and minimum requirements. The oil producer meets those specs or faces huge financial liabilities... not only loss of a customer.
Consider: when the oil container says "recommended for ..." Ask yourself, who made the recommendation ? Or when they say meets xxx specification, who verifies that it does ?
Oil is cheap compared to parts and labor for failed equipment.
and I suppose you know for sure which brand or company makes there oil and tat has the best quality product, it could be that others figured it out. and no one would know with researching which is what I'm doing, made phone called and spoke directly with the manufactures.... Thanks for your opinion.
/ coastal multitrac tractor fluid #15
Have you considered that an oil manufacturer just might embellish their equality claim when responding to a consumer call?
Does what they TELL you necessarily make it TRUE!
True, and that means them ALL even Orange.
/ coastal multitrac tractor fluid #17
Is K brand oil really better than all others or is K embellishing their oil claims to get people to buy theirs? Again, has anybody seen an INDEPENDENT lab comparison?
Who makes K brand oils? Does that plant also make others?
/ coastal multitrac tractor fluid #18
As stated before. It’s your tractor do what you want. My concerns were if the unit was still under warranty you give Kubota or whoever made the machine an easy out by using oil out of spec. I just bite the bullet and by Kubota oil and filters. Two weeks ago I changed my L3830HST and ZD326 hydro oil and filters. Total was around $500 for the 15 gallons of oil and filters. Oh well, easy come, easy go. Lol. The tractor is a 2006 with 800 hrs, the ZD is 2011 with 400hrs
/ coastal multitrac tractor fluid #20
Not sure if we will be speaking of the same oil, but I bought 2 buckets of Coastal synthetic from NAPA last year and got 400 hours out of it with no issues.
This time instead of waiting for the order got 2 buckets of UDT from local Kubota dealer at 86 a bucket versus 99 per bucket of NAPA's Coastal.
So both worked for me. I guess it's a matter of one's preference and like me, just depends on how is your day going....heh....
