wanted 3TN84 injector shims
/ wanted 3TN84 injector shims #1
jgwhite
Arnprior, Ontario
John Deere 955
Hello All,
I am looking for injector shims for my JD 955 with a 3TN84 Yanmar. I am rebuilding some of the injectors and I just bought 150P244 nozzles but will need some shims to get the right pressure pop which I believe is around 2800.
Any help in locating some various thickness shims to help is greatly appreciated.
Thank-you
John
/ wanted 3TN84 injector shims #2
I dont think ur gonna find them on line.?? and they come in specific sizes.. AND they come in packs of that size..
With a new nozzle, the pressure is usually right on or within 200 psi of spec.. which is the allowable MAX tolerance..
U might get lucky & find some info on the Hoye website,??
Thank, someone has pointed me to the Hoyle website for Yanmar shim packs.
/ wanted 3TN84 injector shims #6
Hello All,
Thank-you
John
I'm curious....How are you measuring the pop pressure? Homebrew stand?
Any place there is big water there ought to be a dealer selling Yanmar marine engines. They use many of the same parts.
I bought a pop tester on Ebay for around 80 USD and it was quick delivery.
Diesel Injector Nozzle Tester Pop Pressure Tester Dual Scale BAR / PSI Gauge | eBay
The new injectors tests around 200 bar / 2850 Psi and the do the multiple rapid pops, the old injectors would most just squirt and would be from 1000 - 3000 psi and one had a clogged hole so only three of the 4 streams would come out. I suspect the nozzles are worn on the used ones so I bought some of ones on Aliexpress 12.90 USD + 5.85 shipping for a set 4.
you can buy the individual piece also here:
New high quality factory outlets diesel injector nozzle 15P224|diesel injector nozzles|injector nozzleinjector nozzle diesel - AliExpress
Now I just need the shims which I ordered 4 sets off of Hoyles.
cheers,
John
/ wanted 3TN84 injector shims #8
IF I'm reading this right.. the injectors are popping at 2850psi & the spec is 2800.??
If so.. leave them alone.. Spec is max. 200 psi difference on shim set injectors..
U can change that difference w the tightening of the nozzle nut.. did u TORQUE it.?? {50-55 ftlbs}
So the ones popping at 2850 are the new ones that I used as a baseline. The used ones which are not popping at all and squirt from 1000-3000 psi, I have 6 used ones. I ordered 4 new nozzles for about $20 USD and ordered new shims for about $10 for 4 sets.
cheers,
John
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63118)
2019 Krause...
iDrive TDS-2010H...
30 Yard Roll Off Dumpster (A61166)
30 Yard Roll Off...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
INOP/NON-RUNNING 2000 Sterling L7500 Series Dump Truck, VIN # 2FZHAFBC2YAH48068 (A61165)
INOP/NON-RUNNING...
