wanted 3TN84 injector shims
   / wanted 3TN84 injector shims #1
jgwhite
Arnprior, Ontario
John Deere 955
Hello All,
I am looking for injector shims for my JD 955 with a 3TN84 Yanmar. I am rebuilding some of the injectors and I just bought 150P244 nozzles but will need some shims to get the right pressure pop which I believe is around 2800.
Any help in locating some various thickness shims to help is greatly appreciated.
Thank-you
John
   / wanted 3TN84 injector shims #2
I dont think ur gonna find them on line.?? and they come in specific sizes.. AND they come in packs of that size..
With a new nozzle, the pressure is usually right on or within 200 psi of spec.. which is the allowable MAX tolerance..
U might get lucky & find some info on the Hoye website,??
Thank, someone has pointed me to the Hoyle website for Yanmar shim packs.
   / wanted 3TN84 injector shims #6
Hello All,
Thank-you
John
I'm curious....How are you measuring the pop pressure? Homebrew stand?
Any place there is big water there ought to be a dealer selling Yanmar marine engines. They use many of the same parts.
I bought a pop tester on Ebay for around 80 USD and it was quick delivery.
Diesel Injector Nozzle Tester Pop Pressure Tester Dual Scale BAR / PSI Gauge | eBay
The new injectors tests around 200 bar / 2850 Psi and the do the multiple rapid pops, the old injectors would most just squirt and would be from 1000 - 3000 psi and one had a clogged hole so only three of the 4 streams would come out. I suspect the nozzles are worn on the used ones so I bought some of ones on Aliexpress 12.90 USD + 5.85 shipping for a set 4.
you can buy the individual piece also here:
New high quality factory outlets diesel injector nozzle 15P224|diesel injector nozzles|injector nozzleinjector nozzle diesel - AliExpress
Now I just need the shims which I ordered 4 sets off of Hoyles.
cheers,
John
   / wanted 3TN84 injector shims #8
IF I'm reading this right.. the injectors are popping at 2850psi & the spec is 2800.??
If so.. leave them alone.. Spec is max. 200 psi difference on shim set injectors..
U can change that difference w the tightening of the nozzle nut.. did u TORQUE it.?? {50-55 ftlbs}
So the ones popping at 2850 are the new ones that I used as a baseline. The used ones which are not popping at all and squirt from 1000-3000 psi, I have 6 used ones. I ordered 4 new nozzles for about $20 USD and ordered new shims for about $10 for 4 sets.
cheers,
John
1751 (A58375)
1751 (A58375)
2019 Bomag BMP 8500 Trench Compactor (A57453)
2019 Bomag BMP...
2308 (A58376)
2308 (A58376)
2015 WESTERN STAR 4900EX (INOPERABLE) (A58214)
2015 WESTERN STAR...
1605 (A57192)
1605 (A57192)
2013 Freightliner 122SD Day Cab Truck, VIN # 1FUJGNDR7DDBZ7653 (A57453)
2013 Freightliner...
