Use 3rd Function for Rear Hydraulic Purposes?
/ Use 3rd Function for Rear Hydraulic Purposes? #1
BackRoad
Rural PA
Kubota MX6000, MF 35
MX6000 with a 3rd function hydraulic connection added for the front. No additional hydraulics currently installed for the rear.
Looking at a used traveling disc harrow with a hydraulic lift for limited use (and not while the grapple is attached!)
Though not ideal, could the 3rd Function setup be used for the rear for the disc lift, assuming disc hose length and connectors are addressed?
/ Use 3rd Function for Rear Hydraulic Purposes? #2
Sure, why not. Like you say - as long as you can manage the hoses. Which should be simple. Lots of people use the rear remotes for 3rd function why not the other way around. Might be a little awkward using the 3rd function switch while looking backwards but life is full of trade-offs.
gg
gg
Thanks Gordon...we'll see what can be done!
/ Use 3rd Function for Rear Hydraulic Purposes? #4
the function doesnt know if its work on the front or the rear. use it. They ran FEL's off rear remotes for many years
/ Use 3rd Function for Rear Hydraulic Purposes? #5
Yes, indeed and I've done this whilst helping during haying season.
Fortunately my 3rd function isn't a hard line to the FEL. With an open-station, I was able to detach the couplings (as a set) and 'snake' the lines to, just behind, the seat.
A couple of tie-wraps (zip ties) and I was able to raise/lower the arms of a towed hay rake.
/ Use 3rd Function for Rear Hydraulic Purposes? #6
I used the fel system for a boom mower, and used the rear remotes for two hyd cylinders on my hay grapple.
/ Use 3rd Function for Rear Hydraulic Purposes? #7
No problem;use this system for my couple days a year running a grain drill.Make the hoses a couple feet longer than you "think" you will need.
New/Unused ATS-ECP40 Plasma Cutter (A61166)
New/Unused...
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
2002 Kubota BX1800 Utility Tractor (A63116)
2002 Kubota BX1800...
2006 Genie Z45/25J Articulated Boom Lift (A64047)
2006 Genie Z45/25J...
(5) ROLL OF 9'X150' HOUSE WRAP (A62131)
(5) ROLL OF...
New/Unused Open Backing Plate (A61166)
New/Unused Open...
