Dump Trailer build
/ Dump Trailer build #31
Looking good, I have got to get back to work on mine, if this heat lets up..................
Figured out I suck at vertical welding with the stick welder. So I went and bought some new hardware. Gotta say I’m impressed with the harbor freight welder.
Lol. It was my excuse to buy the welder. The problem I ran into was my tractor and my mini hoe has been on a job site for 3 weeks. Other wise I would have done the same thing.
My other mig is a Hobart 140. It is a great machine and I’ve welded lots with it. I just wanted a 220 wire feed. All I can say is this titanium welds great so far. Holy cow does it burn hot. Totally different sound and heat when you weld with it. The dump box frame is 3/8 angle. I now have the ability to single pass weld it with this welder.
/ Dump Trailer build #36
I use a hole saw for that size hole. Sore wrist is less likley.
/ Dump Trailer build #38
Hole saws that I used are slow, sharp bit with Tap Magic and second handle should be ok.
Brought her out of the garage today. Going to haul some logs tomorrow to finish up a tree job. Then clean the garage up and figure out where the scissor needs to mount.
/ Dump Trailer build #40
In other words figure out the hard part and since the trailer is a female it might be even harder.
2020 Bobcat T76 R Series (A60462)
2020 Bobcat T76 R...
(INOP) 1991 GMC DUMP TRUCK (A59823)
(INOP) 1991 GMC...
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
2006 TerraGator 8104 (A61307)
2006 TerraGator...
2021 John Deere 835M (A60463)
2021 John Deere...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
