String Trimmer Tricks?
/ String Trimmer Tricks? #61
I think i tossed the strap, have to dig around, butit doesnt bring the handle any closer, just supports the weight, which doesnt bother me.
I wouldn't have that 'Indestructible Trimmer' - in the video, the weeds grow back about as fast as he chops them off. :laughing:
I suppose there's no danger of the wire fragments on the cutting head breaking off and flying out? Must be made of some material quite different than the wire wheels on my grinder. I just don't quite think I'll be trying one out.
/ String Trimmer Tricks? #64
/ String Trimmer Tricks? #65
That's life in the fast lane. :laughing:
/ String Trimmer Tricks? #66
You have extended the adjustment on the harness or shoulder strap correct? I'll 5'11 but when my 5'9 spouse has used a shoulder strap, I need to readjust it for me. Does make a BIG difference in comfort.
I tried moving handle up, made it diff to turn the cutting head for certain angles, found the shoulder strap, it does help support and a lil easier on the lower back, Thanks for the refresh
/ String Trimmer Tricks? #67
Glad to see you got the adjustments mastered. Comfort of a tool is very important. We've been using these high powered whackers* for so many years and hours, its easy for us to forget that its not always obvious to everyone on how to adjust them.
* various makes as well.
/ String Trimmer Tricks? #68
heavy String cutting
Maybe someone would like to see how we cut and bring heavy strings with us. This is .155 thick variety. 1st one is how we carry it into the field. The bundles are held together with painters tape. Middle one is it being cut. The roll as seen here is not over costly when purchased bulk. The black sharpie marks in the table is the length I cut. This string is terribly hard to cut and the 6" side cutter seen here even struggles to do it. I have a larger ones that are better for the job.
/ String Trimmer Tricks? #71
I haven't used my weedeater for several years. Thank you glyphosate.
Glyphosate does work pretty well, but I hesitate to use it anywhere near my fish ponds. I do use it, however, out away from the ponds, but there's still lots of weed trimming to do in places where I can't take a chance on run-off killing the fish.
I did write a scathing report to Amazon about the Grass Gater 0.105. I didn't ask for a refund, but Amazon on their own did send me a full refund. I suppose they do actually read reviews. I did get some Titan .105 from them this week, and it works great! I haven't waded off in the the Bull Weed patch with it yet, but if the .108 proves too weak, I'll be getting one of those heads like ArylA uses with some .155.
I'm thinking, with the great suggestions above, my problem is near 'whupped'.
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63688)
PENDING SELLER...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
New/Unused AGT YSRT14 Mini Skid Steer (A65583)
New/Unused AGT...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
