Rotary cutter
/ Rotary cutter #1
Glynnb
Alaska
2032R
Can someone tell me the nut size that holds the blades on a Frontier RC2048 Rotary Cutter. I bought it used and the blades are on backwards. Thanks..
/ Rotary cutter #2
That's interesting! They sure would be sitting high in the deck then. Pictures would really be interesting for the readers.
/ Rotary cutter #3
Just went out and checked. It's 42 mm. I use about a foot long 3/4" extension on 3/4" drive with 6 foot piece of pipe to torque it properly, e.g. about 80 # pushing on it to tighten.
The bolts have an extended nipple shoulder that keeps them from rotating. Try to get the nipple to go in straight and true; otherwise, you'll be tightening it longer because it'll bind.
You may have to rap the ends of the bolts with nuts on them (to keep from spreading the ends of the nut) to get the bolts off the nipple when loosening them. Just loosen the nuts a tad and give them a rap with the socket extension.
Ralph
/ Rotary cutter
Well I got the blades turned over and now it cuts like it should..but I noticed the blades have a little up and down movement to them when torqued to 425 ft lbs. grab end of blade and it will move up and down maybe 1/4". Is this normal? I know they need to be able to swing but seems they should be a little snugger. Bolts are lined up into non rotational slot.
/ Rotary cutter #6
I believe the blades will be fine.
/ Rotary cutter #7
Yep, that is normal.
2020 VERMEER LP873SD1 VAC-TRON VACUUM TRAILER (A63276)
2020 VERMEER...
2025 X-Pro Victor Mini Dirt Bike (A61574)
2025 X-Pro Victor...
(2) FIRESTONE 16.9-30 TIRES (A64276)
(2) FIRESTONE...
2004 CATERPILLAR 416D BACKHOE (A60429)
2004 CATERPILLAR...
2015 IC Corporation PB105 School Bus (A61568)
2015 IC...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
