Industrial Tires on YM2002d?
/ Industrial Tires on YM2002d? #22
Last coolant I put in was green though?
You will have to determine on sight. There is a pink coolant, just may not be in your system. I personally have not seen a pink hydraulic fluid. Where it is coming from will tell the tell.
/ Industrial Tires on YM2002d? #25
To help you to locate your hydraulic pump, as sitting in the seat, on the right side rear the frame of the tractor are 2 metal lines running below the fuel filter from the front to the rear of the tractor. These are your suction and pressure hydraulic lines. Both will run to your hydraulic pump on the front of the engine—opposite side from where your runoff appears in the video. Your fan is blowing it around so hard for me to tell much from the video as to source of leak. The fluid on the ground appears to be a combination of oil based fluid and coolant.
THanks Coy. So when you say oil based fluid, do you mean hydraulic fluid?
/ Industrial Tires on YM2002d? #27
I cannot make out where the leak is on the video but I would think with that amount coming out you should be able to identify the source. I do suspect it is hydraulic. Pull your transmission dip stick and see if that is the color of your hydraulic fluid. Your coolant or hydraulic fluid is bound to be low.
/ Industrial Tires on YM2002d? #28
Well that's definitely a leak. Engine sounds good though. Yep, there's only three choices, and as Winston says one is bound to be low.
Do as he says and look at all three to which one is pink. Someone might have put automatic transmission fluid in it. So pull up the transmission dip stick - the tranny and hydraulic use a common fluid sump.
/ Industrial Tires on YM2002d? #29
Well not in the traditional sense of hydraulic fluid. Hydraulic fluid is a dark tan to light brown color.
Engine oil in most any diesel is typically very dark brown to black usually described as black.
Coolant is either the translucent green or the translucent pink.
What was coming out of your tractor really does not look like any of the three.
My best guess is someone has put ATF into the hydraulic reservoir. ATF is a type of hydraulic fluid but not what is called for in these older Yanmars.
It is a common issue for Yanmars to get water into the hydraulic reservoir and steering box.
The standard was john deere JDM303 hydraulic fluid. This is basically no longer available. Most suggest to use JD Hy-Guard fluid or an oil that meets those standards.
A good cleaning of the suction filter would be in order. Unfortunately a simple draining of the various areas of the reservoir will not remove all of the fluid as some will remain in the suction and pressure lines as well as loader (if equipped) lines and cylinders.
My suggestion is find and repair the leak, pull the tractor if you need to relocate it for repairs. Then drain the reservoir. It has been a while since I have done mine. I will try to go check how many drain plugs tomorrow and post again afterward. First drain then remove the suction filter cover and remove it and clean it. You should also have a spin on filter near the fuel filter. You may want to do a cheaper oil as a flush (I have heard of people flushing with diesel, but I would not want to run my pump on diesel fuel—it will tend to remove any lube from the system). Then when the flush is completed, fill with a high quality hydraulic oil—even under heavy usage, this should be good for many many years baring water getting into the system. Water usually enters around the rubber gear shift boots.
/ Industrial Tires on YM2002d? #30
My manual says the transmission holds 16 qts (4 gallons)
/ Industrial Tires on YM2002d? #31
This is the only drain plug I located under my 2002D for the transmission. Strange my memory told me there was more than one.
Location of the suction filter cover. This is on the clutch side of the tractor. If you want a new filter on hand, they are available through hoye and fredricks.
This is the suction tube going into the transmission reservoir. You can trace it to the spin on filter housing and then from it to the pump if you have not located the pump yet.
Good luck on finding and repairing your leak.
/ Industrial Tires on YM2002d? #32
heres a video of the leak.
YouTube
I went back and rewatched your video of the leak several times. Having watched it several times in a row, I do not think your issue is is at the pump/front of your engine. While both your pressure and suction lines run in that area, I think you have a hole in one of those 2 lines near the filter housing. Most likely culprit is one of the rubber hoses on the suction line, although it could be any number of things in that area.
Start by removing that off white side cover so you can see. I would closely examine the rubber hoses. As these appear to be molded hoses, if they are not available from hoye or fredricks, you may have to get creative with replumbing with straight pieces of hose.
Next closely examine the metal lines to see if they are rubbing anywhere. And may have a pin hole. Then check the filter housing and filter itself for damage.
One big caution, injected (in this case I believe transmission fluid (but any oil/gas/diesel based fluid)) petroleum product through your skin could be deadly.
This is from Hoyetractor.com. While the diagram focuses on the molded hose going toward the pump, it appears the same hose is used toward the reservoir. Personally, if I found a hole/split in one, I would replace both! Also I noticed while looking under mine (see photos in earlier comment) there is about a 3” piece of hose between the suction adapter mounted on the transmission and the metal suction tube going to the filter housing. My guess is that on both our machines, these pieces of hose are original and pushing hard on 40 years old.
i unhooked the fan, then started it up for a few seconds, just long enough for it to start leaking, while recording with camera on tripod. I zoomed in and slowed the video down, and it seemed to be the bottom of the hydraulic pump. So i removed the bottom flange and it looks like the O ring is split where it was spraying out.
So, off to the auto parts store I go to get a new o ring tomorrow, and stock up on hydraulic fluid. I checked the dipstick on the floor between legs, and it also seems bone dry. (which im confused about... if thats the transmission, why would that be where the hydraulic fluid goes? Where does the transmission fluid go if so... ) I just bought this tractor from a tractor mechanic of over 30 years, and he rebuilds these old yanmars, so I'm assuming/and hoping, most all is well, and that its just an easy fix.
This is from Hoyetractor.com. While the diagram focuses on the molded hose going toward the pump, it appears the same hose is used toward the reservoir. Personally, if I found a hole/split in one, I would replace both! Also I noticed while looking under mine (see photos in earlier comment) there is about a 3 piece of hose between the suction adapter mounted on the transmission and the metal suction tube going to the filter housing. My guess is that on both our machines, these pieces of hose are original and pushing hard on 40 years old.
/ Industrial Tires on YM2002d? #34
...... if thats the transmission, why would that be where the hydraulic fluid goes? Where does the transmission fluid go if so... ) I just bought this tractor from a tractor mechanic of over 30 years, and he rebuilds these old yanmars, so I'm assuming/and hoping, most all is well, and that its just an easy fix.
As weird as it seems, every tractor I can think of uses a common sump for their transmission and hydraulic oil. It's the same oil and lives in the same housing....i.e. the transmission housing.
That's why you usually see it sold and labeled as: Trans/hydraulic fluid. Yep, it's the same oil and it all lives in the same house. Up top, the gears whirl around in that oil, while at the bottom the hydraulic pump sucks some out to run things hydraulic. The hydraulic lines route the return flow back into the transmission. Sometimes it goes through an oil cooler on the way home.
Hydraulic components use the same oil as the transmission does, but hydraulic pumps like their oil to be super clean & well-filtered. That's why there is a filter - and sometimes two filters - in the suction line that comes from the transmission sump and goes up to feed the hydraulic pump.
When trans/hydraulic oil looks foamy and milky rather than clear, that means it has water in it. If the shift lever boot is damaged or missing then water enters past the floor shift lever. Especially when the tractor is left outside in the rain. Then a cold night comes along, the water freezes, and things like oil seals and O rings are pushed to the breaking point. Probably the best thing you can do for an outside tractor is to tie a tarp over it.
rScotty
Thanks rscotty, some good advice and wisdom there, much appreciated. This is my first tractor and first Diesel engine, so I知 learning as I go. It can be frustrating when things stop working and I知 scratching my head, but it痴 a lot of fun when I can figure it out with some help from forums like this and fix my tractor and get back to work.
rScotty
/ Industrial Tires on YM2002d? #36
rScotty
well explained!
/ Industrial Tires on YM2002d? #37
RScotty provided a great explanation on the common transmission/ hydraulic reservoir.
One lesson for all of us is to encourage new to tractor owners weather it be Yanmars or other brands to ask questions. I for one forget that things such as that common reservoir may not be something others are not aware of, unless you express your lack of understanding!
In others words, unless you ask about what you do not understand, many of us will (wrongly) assume some knowledge.
Personally, since our base tractors are the same model, ask whatever you wish of me. I may not know the answer, but be glad to share whatever I can.
My tractor has a Koyker 110 loader (on it when I bought it).
As I had stated in a previous post, MI y opinion is someone put Automatic Transmission Fluid (ATF) in your. reservoir. The currently called for fluid would be the JD Hy-Gard fluid or comparable fluid (J20c). Again your transmission, differential and all hydraulic systems (loader, 3PH rear remotes if added) run off of this common source reservoir. I had also indicated that the manual states this reservoir holds 16qts. However, yours will hold more as there is the addition of the loader. Each line holds a bit and the cylinders also hold some. The loader cylinders hold fluid regardless of their position. The rods in the cylinders fully extended will hold a bit more fluid than when fully retracted as the rod takes up some space. All in all a 5 gal bucket of hydraulic fluid will most likely be more than enough even if by some while means you are able to get all the fluid out of the lines and cylinders. You hydraulic system should be self bleeding of air, but try to not rum your pump without and oil supply. You could experience a condition know as captivation which could damage your pump. Try to prime the pump and suction line at the pump end. Otherwise the system should self bleed air.
451 New Holland Sickle Bar Mower (A66408)
451 New Holland...
JOHN DEERE 300P EXCAVATOR (A65053)
JOHN DEERE 300P...
2012 International (A59230)
2012 International...
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
KOMATSU PC88MR-11 EXCAVATOR (A65053)
KOMATSU PC88MR-11...
