Tractor "bouncing" ?
/ Tractor "bouncing" ?
I expect this is due to small indentations created in the dirt/sand as you repeatedly travel over the same path. Sand is very impressionable as you know. The bouncing is accentuated because you have an unbalanced load (not unsafely unbalanced) but from a physics perspective you have more weight out front than out back. ... Some imbalance of weight coupled with a very small uneven motion that starts it all.
So, no track-tractor system is perfectly balanced to start with, thus uneven motion is inevitable. Uneven motion results in small-scale modification to the surface of the track. Subsequent trips with similar speeds/loads results in similar motions, and further similar modifications to the same parts of the track. As the modifications stack up (or compact down, as the case may be), eventually you get a series of indentations/ripples in the track. Driving over those ripples results in the bouncing. Or something like that?
Sounds like what happens on a particular unsealed road not far from my place`. Lots of cars with similar wheel-bases (and suspension systems) travelling at similar speeds (i.e. the speed limit) end up creating "corrugations" in the road surface, which then vibrates the heck out of similar cars as they pass over it.
Oh try it in another vehicle on the same path to see if you notice. Like a car or truck.
Any vehicle with a different wheelbase would logically experience something different. Maybe less bouncing, maybe rocking, maybe nothing at all. Hmmm...
Other than slowing down, no way I can think of to fix. Balance the load and slow down to minimize it. Find better dirt that doesnt keep reforming ;(
Yeah, not much can be done to the tractor itself whilst driving apart from adjusting speed. If flexible tyres are the only type of "suspension" that tractors have, then increasing pressure may make them stiffer, and change the dynamics. Not clear if that would be for the better or worse, though.
Modifying the track... Well, adding dirt and smoothing it out definitely helps. Just -- unfortunately -- not for long. It's not practical to back-blade the track every trip to keep it smooth. I could run with a box blade instead of the counterweight, and scrape regularly on return trips, but given my BB is only about 1/3rd the mass, that would make the tractor more front-heavy and other parts of the operation painful (e.g. harder to dig, smaller bucket loads). Given that the tracks themselves are temporary, spending large amounts of time/resources/money 'improving' them also doesn't make a whole lot of sense.
you could perform your own experiment by taking off the loader and removing the ballast on the 3 point hitch and traversing the same exact ground at the same exact ground speed and you will notice that the bare tractor has much less "bouncing" with those items removed.
Why would a lighter tractor bounce less? I was under the impression that ballasting the rear tyres/axle or putting more counterweight on the 3PH were pretty-much guaranteed/universal ways to make a tractor more stable.
/ Tractor "bouncing" ? #23
Because your torque arm is much less. You have weight sticking out in front of the tractor with the loader. You have weight sticking out back of the tractor with the ballast. Remove those torque arms, and you will bounce much less if at all. Try it at the exact same ground speed, with a fully loaded loader and the ballast, then try the bare tractor. There will be worlds of difference. Not that it helps anything as the tractor then would be useless for your purpose.
/ Tractor "bouncing" ? #24
It’s a mass-elastic system. Changing either the mass or the stiffness will change the response of the system.
Many cars have weights bolted to the drivetrain or bodies in strategic points to change the system natural frequency, mostly to improve nvh.
Going up or down with mass changes things, but adding mass is often easiest. A lot of computer modeling is done in designing cars to get the stiffest, lightest structure possible. Fifty years ago, they just added weight to get a smooth ride. Not an efficient method.
Try playing with tire pressure to change the “suspension” stiffness.
My CTL has what is called ride control to address this situation. I typically adjust the speed when driving my tractor on the paved county road to minimize the bouncing. The travel speed is advertised at a little over 14 mph, but I can only control it at about 10 mph with the heavy front snowblower mounted.
An empty bucket instead of the heavy snowblower helps.
It’s physics.
The various "soft ride" loader additions are designed to dampen the loader oscillations and will do so.
Are you saying that the bouncing phenomenon I am experiencing is actually called "loader oscillation"?
At the speeds you are traveling I'm surprised that you are in 4wd
No speedo on the MX5100 HST, so I can't say for sure, but TractorData says that in M gear the tractor will do a maximum of 11.7km/h (7.3mph) at 2700 RPM. Given that I do most loader work at about 1700 RPM that would suggest that even if I put the pedal to the metal I'd be lucky to break 10km/h (6.2mph).
I might have to do a test to get a real number, but 10km/h doesn't strike me as being particularly fast.
one item to be aware of is with the tractor bouncing and loading and unloading the tires is that every cycle will change the loaded radius of your tires which in turn will affect your front - rear tire balance.
:eek: I do actually hear accentuated HST/drive-train noise when the bouncing happens. Given that the 5100 has MFWD, and the front and rear are effectively coupled, then it makes sense that a changing radius would impact the balance and cause additional stress/load somewhere in the system.
Would increasing the pressure on the front tyres (from their current 32psi to the maximum 40psi) help resist the deformation, and thus preserve the loaded radius?
Would increasing the pressure on the back tyres make any difference at all?
That makes sense.
Since adding liquid ballast to tyres, or wheel weights to the rim, results in additional mass that does not "stick out" beyond an axle, does that effectively make the length of those "torque arms" zero (or, at least, minimal)? Would either of those approaches be a valid way to reduce the bouncing?
Or would additional mass (hypothetically) need to be added between the axles to be effective?
/ Tractor "bouncing" ? #27
Has to do with the frequency of the suspension-there is always a slight bounce and as you go further and further the frequency gets worse and worse. Nothing you can do about it because the tires are your only suspension minus the front axle sway. Its designed that way for many reasons.
I wonder if loaded tires or nitro filled tires can help but I doubt it. Key thing is to slow down or get a dump trailer if speed is a huge factor. Maybe smaller tires? Just best to slow down or get a dump trailer. Not worth redesigning something perfect for certain things in order to fix it for something it is not designed for.
/ Tractor "bouncing" ? #28
I imagine that as the soil gets packed down, even if smooth and no ripples, that when in 4WD any difference where tire size ratio doesn’t perfectly match the 4wd gearing ratio could create a push-then-pull hopping effect as the tractor tries to unbind itself.
Similar to driving in 4WD on pavement.
Especially if the rear tires push more than the front pulls.
Does OP get bounce in 2WD?
...but even in 2WD and no FEL my tractor will hop sometimes at road speed for a variety of reasons:
Tires may have flat spots.
Or rough road initiate bounce, tractor bounces, causing seat to bounce, causing my leg on the throttle to bounce, which causes tractor to bounce again ...and the feedback loop continues...I can eliminate this by eliminating seat and leg component by speeding up (or slowing) with the hand throttle.
/ Tractor "bouncing" ? #29
Did you answer if it was in 4 wheel drive? I think all front wheels turn a little faster than the back.
/ Tractor "bouncing" ? #31
Low inflation pressure radial tractor tires ride much more smoothly than other tractor tires.
/ Tractor "bouncing" ? #32
That makes sense.
I am reasonably confident that remove the rear ballast and putting in liquid ballast in the tires will make some change. I am more confident that taking the FEL off will make a larger change. Again of no value for your application. I am also MOST confident that slowing down will effect the largest change. As far as 2WD and 4WD, I have notice the most effect of this "torque windup" caused by being in 4WD to have the largest effect when turning, causing tire scrubbing on hard surfaces. But I doubt you would notice this in soft dirt or sandy conditions.
/ Tractor "bouncing" ? #33
I feel like dodge man hit a solid point on the first reply in this thread, that didn't get answered: What are your tire pressures?
Drop to 10 psi and report back. It's ok to see your front tires squish a bit. You need to use your tire sidewalls as suspension.
Edit: 32psi... thats nuts. I run 10-12 psi.
/ Tractor "bouncing" ? #34
As mentioned before, this happens on large wheel loaders and backhoes as well. Most new models have a feature that dampens the main loader boom to help prevent this (Ride Control). Anyone who has taken them down the road at road speed knows how they will begin to teeter-totter. Anything can set it in motion (bumps, acceleration, braking, etc) and the oscillation becomes worse and worse. My fathers Cat 416 was so bad you would have to come to a complete stop regularly to control it.
Speed has everything to do with it. And if you are carrying a heavy bucket of sand with a heavy counterweight, you need to carry it low and slow. How fast are you going, IE which range, pedal pressure and throttle? If you need to move a considerable amount of sand fast, consider a dump trailer or truck.
Significant bouncing will probably go after your weakest links. I'm thinking the front axle, loader and loader mounts are taking a beating right now.
/ Tractor "bouncing" ? #35
Would consider comfort ride on the loader, reduced wear and more comfort.
/ Tractor "bouncing" ? #36
It does help, but its not a cure. I'll spear 2 4x5 round bales and drive down the road with them and the tractor ride quality is at least 50% better with KSR turned on. Takes the stiff pounding out.
timbrr....I have neighbors that have big end-loaders and also road crews use them, and they will get bouncing on a SMOOTH road surface. I have a feeling that off-road tires are not as round and consistent thickness as on-road tires. If they all start acting in unison, then you get bouncing. Just like them
Can I check tyre roundness/consistency by simply jacking up a wheel, spinning it, and just looking for "wobble"? Or is there more to it than that?
The bouncing you describe does seem to happen more on smooth surfaces more.
Yep. I rarely bounce on 'slightly rough' surfaces. Sometimes I deliberately put one side of the tractor off the track (into the rough) just to dampen the effect -- that seems to work well, but does end up ruining the vegetation in the area even more.
/ Tractor "bouncing" ? #38
My 2009 Kubota M6040 has a HD 820# grapple on the FEL, 1550# of RimGuard in the rear tires & a 1000+# Rhino rear blade on the 3-point. All tolled the tractor weighs - 10,000+ pounds. Unloaded or fully loaded - it will bounce traversing certain terrain.
This is a signal that I am going too fast. Slow down..........
I have max pressure in my front tires and 14# in the rear tires.
Bouncing is not only uncomfortable for the tractor operator - it puts undue strain on many tractor components.
I suspect this is exactly what is happening to the sand, the front wheels turn just a little faster so they tend to mound up the loose sand a bit with each pass and eventually this starts the harmonic "loping " so you end up bouncing up and down in the seat. Each time the tires run over the humps they react more and more so you end up with a big up and down, front to back hop. Back dragging to remove the humps results in a smooth ride for a couple trips till the front wheels throw up the humps again.
This sounds plausible.
Try travelling in 2WD if it is safe to do so, ie, not hills to traverse where you might loose rear wheel traction.
I'll try that, just to see if it helps, but I don't think constantly switching between 2WD and 4WD is really a practical solution especially when transit times are in the order of 30 seconds. The time lost changing drive mode would almost certainly be greater than the time lost just going slower. The 5100 does not have a way to quickly/easily switch between 2WD and 4WD, unfortunately.
NVH?
Try playing with tire pressure to change the suspension stiffness.
Will do.
2016 WESTERN STAR 5700 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 WESTERN STAR...
Vibratory Plate Compactor (A64553)
Vibratory Plate...
2019 HYDREMA MX14 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX14...
2025 iRanch IRTPL 10,000lbs. Two Post Automotive Lift (A64194)
2025 iRanch IRTPL...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A64556)
2016 Ford F-150...
2008 JCB TLT35D ROUGH TERRAIN TELESCOPIC FORKLIFT (A65053)
2008 JCB TLT35D...
