Buying Advice On the Hunt
/ On the Hunt #1
BigNuge
Seacoast NH (Live Free or Die baby...)
Mahindra 1626 HST///Husqvarna M-ZT 52
Howdy folks, new member here from NH.
I have been researching a new FEL tractor for a while, lurking here on the forums, trying to come to a reasonably informed decision about brand/model/implements.
I can get super-wordy with forum posts, I’ll try to keep it concise....sort of.
I have property that I’m constantly working on. Grading lawn & dirt driveway, moving/removing plants, removing trees, moving heavy things (on pallets), moving/shuttling trailers around, clearing/stacking snow. Having considered that level of work (hobby for sure, not making money with it), as well as wanting to be able to move it on a car trailer myself, I was looking at a 25-30HP machine.
So, I started out looking at every brand I could find on the net. Culled the super cheapies (I’ve never been a fan of buying the cheapest thing when it comes to a machine), culled the most expensive (disappointing, I have a green tractor dealership only 2 miles away), had many-o-evening of thought about the remaining options. As of now, I have picked the Kubota L2501 MST w/quick attach loader bucket, box blade, forks. I’d like to have a back hoe w/thumb and a grapple too, but trying to keep the package reasonable.
I am calling my local Kubota dealer about putting a package together and pricing things out today...I’ll happily share those numbers here when I get them.
FYI, I’m not hung up on the Kubota if someone has solid information/input about another brand. Wide open to input/ideas!
Looking forward to the input from all you experienced folks!
/ On the Hunt #2
If I was looking for a tractor that size I would look at the Kubota you have picked out or a 25 hp 3 series John Deere. The E series JD is the basic model where the R is more deluxe. Do you have the need for a mid mount mower or front snow blower? If so make sure you get a model with a mid PTO.
/ On the Hunt
Thank you for the info!
No need for mower or front blower (I plow my driveway with my truck). Though, I will definitely be adding front remote for the eventual grapple. I don’t see a need at this point for mid PTO. I’ll never mow with this machine, my Husqy ZT is a beast, and the cut is awesome.
/ On the Hunt #4
For a lot of us a lower cost tractor does not mean cheap. Kubota is one of the more expensive around here. And John Deere here will match a lot of the Kubota prices. You will find that some of the lower price tractors also make some of the other tractors. Branson has made tractors for Deere for some time. LS makes tractors for New Holland. I have been told that Kubota make more of their own parts than anyone else. Check out the dealers, if they have parts and service. If you want resale, you will need to look at only the bigger names in your area. I didn't care about resale. Make sure when you compare prices, it is with the same features. Salesman have a way of leaving things out.
/ On the Hunt
Thanks for the info guys.
My lot at home is small (~ 1 care), and I care for an elderly aunts land down the road (8 acres 1/2 mile away). I also plan on purchasing land up north for a camp of some sort.
I don’t mean to put down budget machines, I am sure there are good qualities there. I am not looking to spend any more than I need to, but rather spend a little more for solid quality and durability.
/ On the Hunt #6
Based on your description of the work you want to do, it seems like loader performance and tractor weight might be important. Kubota loaders tend to lift higher than other brands, but that comes at the expense of capacity. The weight of the tractor can be increased with ballast and weights, but lift capacity cannot. Based on the research I did when choosing my tractor, TYM or LS seem to have the highest rated capacity in a given class. Of course, numbers can be manipulated, and there are intangible aspects like control feel, but my LS handily outlifts my neighbor痴 Kubota in the real world, and his has more horsepower than mine.
/ On the Hunt #7
1) My lot at home is small (~ 1 care), and I care for an elderly aunts land down the road (8 acres 1/2 mile away).
2)I plan on purchasing land up north for a camp of some sort.
1) Kubota L2501 will be ample for home and aunt's property.
2) If you will need to Bush Hog your potential camp, L2501 will be marginal in PTO power output. Consider an L3901.
If potential camp has hills you may wish a tractor with a wider rear wheel spread for stability. Power and real wheel spread may point you toward a Kubota MX but an MX may not be practical for you to trailer.
/ On the Hunt
Appreciate all the input guys, keep it coming!
I made some calls today for quotes from all the brands with dealerships around me. I built my research around the Kubota L 2501, and initially was going to go that road, but want to be sure I’m considering all the brands. I’m still waiting for local JD to get the quote back to me, but I have numbers from several others. All pricing before today was what I could find online.
Brands and models I’ve called for quotes on:
Kubota L 2501
JD 3025e
Mahindra 1626
Kioti CK 2610
Bobcat CT 2025
I asked them to price implements to try and save some $$ on them. Some were ok pricing, some were out to lunch (Mahindra dealer asking $2800 for the $1900 grapple). In the end, I think I’ll do my own 3rd valve (save $1k+), buy my own implements.
Anyway, I have done some digging into the brands above, found things I like and dislike about them all.
Some early takeaways from my research today:
Kubota is expensive....lol. Good machine, ok loader control position, terrible foot room
JD already at disadvantage with me due to the non-quick detach loader, uncomfortable loader control position, and proprietary bucket mount
Mahindra is a decent option, much better loader control position, super nice seat with arm rests, lots of foot room, competitively priced
I hadn’t considered the Bobcat until today, I have to say....I like the machine on paper, and it looks **** sharp. Loader control is in the best position (right next to the seat), lots of foot room, convenient engine access for maintenance
You notice I mention loader control position a lot, and that’s because I have a rotator cuff that likes to get angry and make it difficult to suspend my arm at the shoulder. If I choose a machine without arm rests I will be adding them myself.
Anyway, just some thoughts and progress for today.
/ On the Hunt #9
Bobcat - Kioti are pretty much the same tractor - I've had two JD's one Kubota - all three were decent units - only have 70hrs on the Kioti, so far I'd take Kioti over the others - if you do consider one make sure you check out the SE (CK2610SE or CK3510SE) the SE adds a lot for the money......
/ On the Hunt #10
I would check if you have an LS. Good machines with good options. Pricing is good. I am not a big Mahindra fan, but that is due to the local dealer. I don't know anything about the Kioti except what is on this forum. No local dealer here. But most people like them.
/ On the Hunt #11
I have never bought from Chappell Tractor (Kubota), but they are big in your area (NH), and have a excellent reputation.
As I am sure you know, they sell Kubota. New Holland, and Mahindra.
I have much larger 14 year old Kubota.
If I were you, I would put my money on the Kubota.......for a lotta reasons!
/ On the Hunt
My FIL has had them do repair work on his old Ford Jubilee, expensive. They were the ones that have me the Mahindra quote, and the crazy high price on the grapple.
I like the Kubota for reputation and build, but they are the highest price so far (haven’t got the JD price yet though).
Honestly, I like that Bobcat more and more as I read about it (I’m learning it’s basically a Kioti).
/ On the Hunt #13
You can buy good grapples at reasonable prices online. I had a Wild Kat 48” grapple on a Mahindra for years and never had any problems with heavy use. I bought a new Kubota this past August and bought a 60” MTL for a third of what the dealer wanted for a Land Pride and have had no problems to date.
/ On the Hunt #14
I'm rather partial to Kubota when looking for new tractors, but if you have an LS dealer nearby it would be worth talking to them. Right now they're the new kid on the block and trying to build up market shares. However they make some nice looking, robust tractors and I predict that over the next few years as they grow you will see the prices go up.
I just ordered an MTL grapple for half what most are going for. I had it delivered to a local business to save money
and will be picking it up tomorrow. A relative has one which he really likes and several members have them so it should be a worthwhile investment.
/ On the Hunt #15
Sorry for the newbie filler post here guys, enjoying the thread and there's info pertinent to my needs... needed a few posts to add pics to my own thread. Carry on! :D
/ On the Hunt
Well, I’m going to throw a post up on the Kioti forum and see what folks are thinking about them. The Kioti dealer around here is completely out of the model I’d consider, says they can’t keep them on the lot. The Bobcat looks to be a rebadged Kioti, and I like the looks and function of it. Kind of zeroing in on it, but still open to info/input about all the brands!
I am also going to call the local LS dealer today (really small dealer).
/ On the Hunt #17
Newbie here as well interested in the outcome. Shopping the same models with firm quotes on LS MT225H and Deere 3025E. Roughly the same price with more bang and options on the LS. I feel like the dealer is offering the Deere for a fair price and resale would be better. The Yanmar SA 424 has my attention but none to be had locally at this time.
Haven't physically driven LS or Kioti. Watching with anticipation
/ On the Hunt
Guys, I meant to ask about tires earlier in the thread. I was going to go with R4’s until I spoke with the Kubota dealer. He said that if I plan on doing snow removal work with the machine then R4’s were not the way to go. He said turn tires were best for a machine that will see snow work, and will be plenty capable in the dirt for what I’m doing.
Any fellow snow belt folks care to comment on tire selection?
/ On the Hunt #19
If you plan to move much snow the best investment you can make is a set of tire chains. I have the simple modified ladder type, similar to what's used on trucks except the cross chains are connected to keep them out of the lugs. Many of the members here recommend the Euro style,https://www.ebay.com/i/164241263124...1291&msclkid=422335da68241cadf9476b31038b503a citing superior traction. Mine came with my tractor and I haven't come up with the $600+ asking price to upgrade.
Turf tires are good on turf because they won't tear up your lawn. For many of the other things you say you will be doing, I would want something with a tread.
/ On the Hunt
See, that is what I thought too. But the sales manager at my local Kubota dealership said that turf tires were going to be a "must have" for snow. And honestly, snow work is only sporadic, I plow my driveway with my pickup.
I think I'm going to stick with the R4's, add chains down the road if needed.
2025 Quick Hitch Skid Steer Attachment (A61572)
2025 Quick Hitch...
2017 INTERNATIONAL PROSTAR + 122 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 INTERNATIONAL...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
NOVA NMS-6835 HYD DOCK LOADING RAMP, 35000Ib CAP (A64281)
NOVA NMS-6835 HYD...
2017 Ford F-250 4x4 Crew Cab Medical Service Truck (A61573)
2017 Ford F-250...
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
