Buying Advice Looking for a walnut orchard tractor
/ Looking for a walnut orchard tractor #1
Lorenzo Leach
mf 135
Hello!
I am looking to purchase a new tractor for my 100 acre walnut orchard. The trees are in a 22 x 16 spacing. I am not sure a specialty tractor is necessary as the rows are plenty wide. After some research I am between a MF 2607 or a JD 5075E both in their platform configuration as the ROPS can be folded and are relatively low. Does anybody have any other suggestions or advice? Thank you.
/ Looking for a walnut orchard tractor #2
What is your main working speed range? ie are you trying to do a stick shift, because the closest gears are to high and to low, or can you remain in one main gear and use the splitter. ( JD power quad, work in "c" range and use the quad shift button to change gears( 1-4), with out the need to use "b" or "d" range)
I am not familier with the gearbox in either tractor.
What is your hydraulic requirement? Machinery is going hydraulic instead of pto. Also if you get a front - end - loader, get 3rd service from factory as retro fit is expensive.
The tractor will be running a flail mower and a sprayer so everything will be PTO driven. Currently I use an old MF 135 and usually run it in either 3rd gear low range or 1st high range. I am not sure i will get a loader at first but would like to get one further down the road so I'll get the 3rd service form factory.
/ Looking for a walnut orchard tractor #4
I know that Kubota makes what they call an orchard tractor. It's low and wide. Called - M Low Profile.
I have looked into them but sadly I cannot get them where I live.
/ Looking for a walnut orchard tractor #6
A Loader not purchased with the tractor is very expensive as a stand alone option. You only need a third function remote if you will operate a grapple from the Loader. Third function is installed on the Loader.
/ Looking for a walnut orchard tractor #7
Agree, plan to buy loader with tractor. 3rd function for grapple can be added later. With the flail, I use a ditch bank flail, it requires 2 rear remotes. Great mower. With the offset on the ditch bank, I can mow about 4 foot to the side. Hst may be better for you. Think about getting ballast in the tires. Slope of land may made a difference.
Thanks for the advice! May I ask what mower you have?
/ Looking for a walnut orchard tractor #9
I have an AGL165. Made in China. So far it is ok. If I had to do it over again, I might look a little longer and change my mind, as I think some of the other mowers will go out to the side a lot farther than this one. But a good choice for me at the time. It was a good sale on it at the time. My wife does not want the lower limps on some of the trees cut and it allows me to mow around them. A lot of good videos on the internet on this one and others.
/ Looking for a walnut orchard tractor #10
Deere makes the 5100ML that is low profile
  • 5100ml_specialty_tractor_r4d074549_large_9a19e7b1cdd29af6917e7138a9d8fe9323fdddf7.jpg
Thank you,I will look into it!
UNUSED RAYTREE RMSC78 - 78" HYD SOIL CONDITIONER (A62131)
UNUSED RAYTREE...
FERGUSON 21 (2) ROW PLANTER (A62130)
FERGUSON 21 (2)...
2020 International MV607 Cab and Chassis Truck (A61568)
2020 International...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lift (A61568)
2010 Ari Hetra...
