inaccessible grease fitting
/ inaccessible grease fitting #21
Nobody has suggested drilling an access hole through the window. Can't see why it wouldn't work.
Easiest solution is to add a short extension and a 90 degree zerk as previously mentioned.
Most elegant solution would be to drill and tap the pin for a zerk. Also previously mentioned.
/ inaccessible grease fitting #23
On my tractor the Zerk is a 90%
Mine too - and that is what I would do, change the zerk to a 90. That is if it is a threaded zerk and not a push-in type.
gg
/ inaccessible grease fitting #24
/ inaccessible grease fitting #25
Yes, go buy a factory made pin with a zerk on the end. Easier all around and makes for less mess.
Probably about ten bucks.
/ inaccessible grease fitting #26
There is an adapter that will fit that I have have one it cost like 10 or 12 bucks at family and farm it just takes some finagling to get it on
E-Z TRAIL 3400 SEED TENDER (A63291)
E-Z TRAIL 3400...
Case skid steer wheels and tires (A63689)
Case skid steer...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
2020 DRAGON ESP 150BBL ALIMINUM (A60736)
2020 DRAGON ESP...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
