Stihl Kombi Vibration
/ Stihl Kombi Vibration #1
TimberXX
Bergen County, NJ
BCS 770 Italian 2 Wheel Tractor, Grillo 107d, BCS 853, Deere x350, Deere x730
I have a Stihl KM 131 that is 2 years old and has about 50 hours on it, but it is out of warranty.
It vibrates so bad that my hands hurt for days. 3 days later and the tips of my fingers are a little numb, even with the anti vibration gloves. I finally put the machine it down for good, until it is fixed.
All of the attachments vibrate bad. The blower is the worst, then the brush cutter, then the hedge trimmer, and the trimmer is just an annoyance.
Any idea what I should check first?
I brought it to the dealer, they used it and said it was normal... but they only held it for a few seconds, maybe a minute.
/ Stihl Kombi Vibration #2
I'd guess either a clutch issue or upper driveshaft
Any recommendations how to troubleshoot that?
/ Stihl Kombi Vibration #4
The clutch drum screws could be loose.
The plastic bushing at the end of the shaft missing maybe?
I just spent 6 hours on my km90r today without gloves and no vibration or tingle in my hands at all.
Does it do it with no attachment on it?
its still bad without an attachment.
/ Stihl Kombi Vibration #6
I think I'd remove the upper shaft and run it and see if the vib goes away. Obviously, once you crack open the housing, do look for those loose lost bolts.
/ Stihl Kombi Vibration #7
You might check to see if a fin has broken off the flywheel. I got a Stihl MS250 to fix once that had a broken fin from new. The owner used it until the vibration eventually took out one of the crank bearings.
Easy fix: new flywheel.
2011 Nissan Juke AWD SUV (A61574)
2011 Nissan Juke...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63118)
Dual Tailwheel...
20ft. Homemade Trailer (A64047)
20ft. Homemade...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
YARD MULE (INOPERABLE) (A63569)
YARD MULE...
2023 John Deere 8R 370 Tractor (A63109)
2023 John Deere 8R...
