Comparison JD 1050 vs ... ?
/ JD 1050 vs ... ? #1
selkie
Member
North of Pittsburgh, PA
Hey all,
We are putting back into service a small (5 acre) farm that had long been disused, much of which is quite overgrown. I know some of the small farms here seem to be more horse-oriented, but what we have in mind is more of a homestead.
Currently I have a JD 112, which I keep because it had been Grandpa's, and a small Husky. We need to sell the Husky and get something a little bigger. We are looking for:
- Durability / mechanical simplicity -- we are able to do most mechanical jobs ourselves but I don't want to be constantly fighting with whiz-bang technology that fails after 5 or 10 years
- 4wd -- some hilly terrain here
- Diesel -- for torque and lower fuel consumption
- Enough oomph to drive a loader
Looking at what JD has made over the years, it looks like the old Yanmar powered machines had a good reputation but parts availability is starting to be questionable. We're used to tracking down parts for our old stuff and that's not a major problem to me. Many of the old 1050's seem to already have a 75 or 80 loader, and I've even seen a few with the 8 backhoe. Any comments on that setup? Any other older 4wd diesels that would compare well to it?
Also, I notice that a lot of the 1050's with loaders have damage to the front of their hoods, more than I've seen with other loaders. Is there something about how it's set up that makes it hard to see where you're going?
We would be using it for plowing, clearing land, moving manure (we don't have animals ourselves, but the horse folks in this area give it away), and mowing the area that I keep grass for the kids. I've double dug a couple large plots that the rototiller couldn't get through (this land hasn't been plowed in maybe 30+ years) and a machine to help break up soil would be welcome.
Thanks in advance for your time!
/ JD 1050 vs ... ? #2
Hood damage can occur from contact with the loader. You don't want to operate the loader on some tractors with the hood open. (Don't ask.) I don't know your budget but many subcompact tractors would probably fill the bill for you. I advise avoiding grey market tractors. They can be a challenge finding repair parts. Just having a name brand tractor does not mean it's not grey market. If instruction and warning stickers are not printed in English you've probably got a grey market tractor.
/ JD 1050 vs ... ? #3
Maybe positioning is less precise without a hydro. Usually just a careless operator. Or hired person, not my tractor and hey, it's just a tractor mentality.
Also, the smaller the tractor, the less reach you have. Less margin of error.
YANMAR:thumbsup:
/ JD 1050 vs ... ? #4
I have a 950 with a 75 loader. The 50 series are great little tractors. If you get one with a loader make sure you also have power steering and 4WD. These loader tractors all have hood damage from debris falling out of the back side of the bucket onto the hood. I had a 2WD without the loader and the hood was perfect. My loader tractor has a dinged up hood. Most of the parts you would ever need are readily available. Th e 50 series has good aftermarket support and many parts are still available from the dealer.
/ JD 1050 vs ... ?
Sure, makes sense about the loader.
Grey market doesn't really both me parts-wise, but JD kinda runs in my family, so I'd rather go with old and green.
How long does it take to detach and reattach the 75 or 80 loader? Is it realistic for me to put those on and off the tractor a few times a season? Or it's kinda "put it on and leave it there forever"?
Ditto for the 8 backhoe if I find one with it. Does the 3 point just fold out of the way to mount it? Or do people take that off to mount the backhoe, and then it's going to be a big headache if they lost it?
/ JD 1050 vs ... ? #6
Hood damage on these modesl is from the front weight bar being too close to the nose. I have a 1070. In order for the loader cross bar to clear the suitcase weight, the weight bracket sets VERY close to the grill. Bump the weights from specific loads use and your machine can get a black eye, or worse.
/ JD 1050 vs ... ? #7
75 takes 15 or 20 minutes. 80 should be faster. Hoe uses a subframe but never had one although I壇 like to find one.
/ JD 1050 vs ... ?
Good to know, thanks. 1070 is the newer version of the 1050, right? Better, worse, same and just newer, or what? Looks like the prices are actually pretty similar for it, from a quick look online.
/ JD 1050 vs ... ?
Sounds like it's realistic for me to put the loader on when I need it and take it off when I don't, then.
Do you know if the 3pt swings out of the way for the backhoe? Or do you have to remove it to make room for the hoe?
/ JD 1050 vs ... ? #10
I don’t know on the 3 point for the hoe. I’ve never mounted one. I believe someone on this forum had a difficult time finding a head gasket for a 70 series tractor. Many parts are readily available for the 50 series. I would look real close at parts availability before I would by a 70.
/ JD 1050 vs ... ? #11
I have a Yanmar 336. Basically the same tractor without a turbo. My hood got damaged once with the hood up as I recall and the bucket up and it leaked down and bent it as I recall. It seems some of the JD parts interchanged with the Yanmar but I forget which ones.
/ JD 1050 vs ... ?
I don稚 know on the 3 point for the hoe. I致e never mounted one. I believe someone on this forum had a difficult time finding a head gasket for a 70 series tractor. Many parts are readily available for the 50 series. I would look real close at parts availability before I would by a 70.
That's really interesting -- the 70 was newer, but I notice it's no more expensive (and perhaps cheaper, sometimes) than the 50. Was the 50 just a more popular tractor, such that there's more aftermarket support for it?
/ JD 1050 vs ... ? #13
I don’t know why the 70 doesn’t have better support. I assume many parts are available from the dealer but someone not long ago had a very difficult time coming up with a head gasket. Most of the parts you need are readily available, both from the dealer and many aftermarket places, for the 50 series. Exceptions would be internal gears, maybe the crank and major parts lije that. Might have to go to the salvage yard for that. I overhauled a 3T90J from a 950 and all the parts I needed were readily available.
/ JD 1050 vs ... ? #14
Anything I needed for my 1070 I looked up and ordered from JD website. Parts usually on my porch in 1-3 days. Engine is all yanmar so I can't picture shortage of engine or drivetrain parts. When I had the clutch replaced local tractor repair had parts in two days.
/ JD 1050 vs ... ? #16
/ JD 1050 vs ... ? #17
It's a storefront for Joe auto spare parts on Alibaba. I just used it as an example of parts availability for 1070 JD Yanmar
/ JD 1050 vs ... ?
I can’t seem to navigate that site. Do they sell parts for a JD950? It’s a Yanmar 3T90J. Those 1070 gaskets are a bunch cheaper than the prices I paid for my 950 parts. Just curious.
Aliexpress is a storefront for small to medium sized sellers in China. Quality varies widely. You will wait a long time for your stuff, especially now that international freight doesn't really move.
I'm not a huge fan of "made in China", to put it mildly, but for things where the only choices were made-in-China, I did try Aliexpress. Quality was very variable. Basically order it, and then forget that you ordered it, and get a nice surprise in a month =)
/ JD 1050 vs ... ? #20
2002 CATERPILLAR 963C CRAWLER LOADER (A65053)
2002 CATERPILLAR...
John Deere 1023E (A62177)
John Deere 1023E...
EZ Trail 3400 (A63688)
2022 EZ-GO ELITE...
2014 FORD F-350 SUPER DUTY (A65643)
2014 FORD F-350...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
