Installation of WR Long 3rd Function Valve on XG3037H
   / Installation of WR Long 3rd Function Valve on XG3037H #1
SFC
Hereford, AZ
LS XG3037H
Got my 3rd function valve kit from WR Long through Everything Attachments. Looks fairly straight forward and will start this tomorrow. The only thing that I think I will change is coming out of the Power Beyond to the 3rd function valve looks a little difficult. I think I will try to find a 90 degree elbow and put this in the power beyond port then connect the provided hose (with 90 degree bend in it) to the installed 90 degree elbow. Everything else appears to work like designed when I dry fit it on the tractor.
Got everything installed. Couple of things you might want to know. Check the length of the hoses from the 3rd function valve to the front on the tractor. Mine appear to be short and I've contacted EA about this. Hopefully will hear from them tomorrow. Also to make the connection from the T port on the valve to the connection below the seat you will have some problems. I tried to do this by just removing the seat but finally had to remove the rear tire to get a wrench on the hose to make the new connection. I used hook & loop (Velcro straps) to secure the hydraulic hoses. Can't upload photo's now so will try later.
   / Installation of WR Long 3rd Function Valve on XG3037H #3
what is the cost difference between buying from a LS dealer compared to where you purchased it ?
I want to add one on my 3025 .
Thanks Jake
   / Installation of WR Long 3rd Function Valve on XG3037H #4
That's quite similar to the way the Kubota dealer installed my WR Long valve. Except mine is on the inside of the FEL vertical member.
Thanks Jake
I purchased the kit through EA when I ordered my Wicked Grapple.
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2020 FREIGHTLINER...
2004 DCT PUMP TRAILER (A58216)
2004 DCT PUMP...
2017 Rogator RG1300B Dry Fertilizer Applicator (A56438)
2017 Rogator...
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
2018 Kubota RTV500 4x4 Diesel Utility Cart (A59228)
2018 Kubota RTV500...
