Septic drain field issue
/ Septic drain field issue #1
rangerfredbob
Dayton, Oregon
Kubota L260
I don't want this as a project yet so posted it here... I wasn't wanting to know about this issue, but here it goes...
I have a septic system for the house, one 1000 gallon tank with a 470 gallon "dosing" tank with a pump on the outlet with floats since the drain field is higher than the tanks. I was out on a gopher walk (with shotgun, too hot but gotta keep an eye on where they are at least, I've been lucky before... I spooked one with a trap so he's skiddish now) and walked over the drain field and inconveniently noticed a wet spot with water flowing that I could hear. From the rough hand drawn sketch I have of the drain field there are 3 rows of drain line and the area I saw water would be at one of the concrete junction boxes
So, how screwed am I? I saw that and my stomach dropped and saw dollar signs...
Aside from keeping it mowed I don't drive anything big over the drain field (or try not to), unfortunately before I moved in the people that were leasing the field next to me put wheat on that acre area, not sure what they used to work it up but could have been a chisel disc... it's leaking in a concentrated area though, I've never noticed it being overly wet there before.
If it is just a broken junction, is this a DIY project to fix the pipe?
On further inspection looking at the layout from the septic permit it is wet at both junction boxes which from my quick google search means the drain field is plugged probably from biomass? I saw a reference on an additive to hopefully help that, any experience?
/ Septic drain field issue #3
My experience has been with gravity systems, but you're talking drain field so there shouldn't be much difference there.
I'm a little surprised you can hear water running. I suppose that dosing tank must have been pumping at the time. At any rate, if it were my system I'd dig it up where the water is and look to see what's there. It very well may just be a broken pipe or junction box. Worst case, you're just out a couple hours of digging, best case you find something simple that you can fix yourself.
Several years ago we had an earthquake in WA and it caused the output pipe from my septic tank to sheer. I dug it up and replaced it myself, rather than have to go through an environmental permit and inspection, probably to more stringent requirements than those that were in place when the system was installed. My guess is that Oregon has some pretty tough requirements for septic systems, and you might be well to keep your own council if you can.
I imagine permits aren't cheap, but I've seen that a homeowner can do "emergency repairs" on plumbing, not sure on septic... I heard it flowing because of the pump, yes, I just happened to catch it on a cycle...
Been looking at stuff online and it's sounding like the drain field is plugged, there's high ratings on THIS bacteria treatment so I'll get a couple bottles... probably just put it in the dosing tank and let it go from there... If I can fix it for $50 instead of thousands I'd be happy :)
Before I moved in the house was vacant for about 2 years, the system is only 11 years old so "should" be fine but I've heard things about septic systems that aren't used being problematic...
/ Septic drain field issue #5
I have done several septic systems (all gravity feed) by just renting a backhoe and doing it all myself. It's not difficult, just pay attention to the slope to make sure you don't have any flat spots. I agree with defranks to dig up the spot with the leak and see what is going on. Maybe use the unclogging stuff first, but digging that one spot shouldn't be all that hard. On the other hand digging up a clogged septic system is ALWAYS terrible. If you have a teenager, make them help - it will convince them real fast that they need to go to college :D
I'll try the goo first, then if that doesn't help I'll dig up the junction box things, at least I know where they are now :)
/ Septic drain field issue #7
I wouldn’t be so quick to judge. I was ready to buy a pumper truck after I heard what they’re making. ( not really but i wouldn’t be above the idea either) The pumper trucks are netting over $1000 a day and probably dumping the contents on a field for free. And on a side note those 2 tank systems aren’t that nasty in the pump tank. I changed a check valve in one a while back. It’s mostly water with a slight odor.
/ Septic drain field issue #8
I fixed my septic system when a rock dislodged a rubber connection that went to old cast iron pipe. The frost worked the connection loose.
It is not that bad. Wear clothes you can throw away, cheap gloves, and take a shower afterwards. It is cheaper to do that then pay someone to fix it.
As for the right to fix. Here in Maine anyway, we can legally repair 2 lengths of pipe without any permit. But good gracious, what court is ever going to fine a homeowner for fixing their septic system? A fixed system is FAR BETTER than one that is flowing human manure out of it.
/ Septic drain field issue #9
Interesting comment on pumping into a field. Know animal waste can be but assume there are regulations on that also but is it legal to, with human waste? Had thought it was not legal at least here. Human waste is likely to also have items in it that will not dissolve which are not suppose to be flushed into septic systems.
/ Septic drain field issue #10
In one county in Florida, they were paying to dump sludge from the treatment plants on a farmer's field. There were a set of requirements that had to be met, like distance to drainage ditches, etc.
/ Septic drain field issue #11
In Washington, near where I lived, there was a large forest tract that was used specifically for dumping septic tank pump-out. You'd see pumper trucks roll in there all day long, day after day, and they were spraying that stuff out on the open ground within a few miles of salt-water Hood's Canal. I believe this is still on-going, and there were plans to expand it with some kind of "lagoon" before we moved away a year and a half ago. But government tells us that it's all fine and good, so it must be, right?
/ Septic drain field issue #12
OP states that there are wet spots at two junction boxes, and suspects a clogged drain field. If that's the case, I'm doubtful that a bacteria treatment is going to unclog it. And did I understand that the drain field was planted with wheat? I wonder if the leech pipes weren't damaged during all of that. I think, Rangerfredbob, that you're going to have to dig at least some of it up to see what condition it's in.
/ Septic drain field issue #13
rangerfredbob, talk to local person who pumps septic tanks and install tanks. Look for the true local person who runs basic equipment. Here the guy who comes to my mind runs all used trucks with much newer tanks and pumps on them. First no idea about right now or nor any where else but here, a year or so back think it was Federal Grants paying a good bit to replace or repair a nonfunctioning system. It was being done though maybe the US Dept of Agriculture. But the local guy who installs, pumps and repairs system will have ideas or recommendation that are best for your type of system and area. I make this an in person conversation and not a phone call.
It has been interesting to see how the pumped sewage is treated in different areas. In my area the local water and sewage company who serves the rural areas has thousand of acres of turf they pump the "clean" what ever it is called onto. They sell turf lower than anyone else can due to their source of fertilizer. Have been told "dumping" a pumper here is a fine. No idea the seriousness of it.
/ Septic drain field issue #14
"can legally repair 2 lengths of pipe without a permit"
So....does Belfast have an assigned pipe length checker, to make sure that no one exceeds that 2 length limitation?
I replaced my entire system without a permit, and I don't live in the country (when I was a kid it was country).
Of course, I have had a TLB for 34 years, so I didn't need to hire anybody.
/ Septic drain field issue #15
I work for a company here in Washington that designs, installs and maintains home septic systems (in the office but I've been on numerous calls with the owner/designer). First - one of those additives will not help. You have assessed the situation correctly. At least two of your three drainfield laterals are plugged. There should be a distribution box at the head of each lateral.
A clogged lateral can result from three things: 1) Your septic tank hasn't been pumped regularly (or the outlet baffle is broken) and some of the solids from the tank have been pumped down the drainfield laterals 2) Roots from trees and bushes have infiltrated and plugged your lateral lines (unlikely since you've said you only have grass near your drainfield) 3) The drainfield is very very old or was installed in marginal soils and the surround soils have become clogged with microorganisms.
Diagnosis and repair of a septic is really not a DIY job. I'm pretty handy and I might well have tried before I started working for the septic company. You should call a company that does septic system design, installation and repair. Not all septic pumping companies do that - some just pump. Having your system pumped will fix the problem - for as long as it takes you to use 1,000 gallons of water but as soon as the pump comes on it will be back. A good septic guy will be able to take a look at your system and tell you what you need to to so you don't waste time digging up stuff you don't need to.
Best of luck.
/ Septic drain field issue #16
rangerfredbob - When is the last time you had the tanks pumped out?
In our previous home, we had a septic system which was installed in the 1950s. 300 gallon tank to a distribution box (they are not called junction boxes here). Two pipes out of the distribution box to two drain fields.
The distribution box would overflow because; (1) Both drain fields were clogged because (2) The baffle to keep solids from leaving the 300 gallon tank was missing and (3) We had waited too long to have the 300 gallon tank pumped out which let solids build up.
We called a local septic tank business, not just a company who pumps tanks out. We were selling the house and a septic inspection was required.
They replaced the missing baffle and pumped out the tank - Not easy given the build up of solids. They also had a high pressure 'wand' they inserted into the exit pipes in the distribution box that was long enough to reach the drain fields. High pressure water with a solution to break up the clogged pipes out to and in the drain field. Fixed the problem. The high pressure treatment, which they said may not work (it did) cost $1,600. They also said to have our tank pumped out every 3 years, given its size.
It was my mistake not having the 300 gallon tank pumped out on a regular basis. If I had, the missing baffle would have been found and fixed and the solids would not have built up in the tank and in the drain field.
If your drain field is damaged or clogged no treatment you put in the toilet or the junction boxes will fix it.
P.S.
WVBill and I were typing at the same time. :) He described the situation we had. My advice...call a professional.
/ Septic drain field issue #17
Hey WV Bill. I grew up in Anacortes and spent a lot of time on Whidbey Island, where my dad was stationed.
/ Septic drain field issue #18
Here a homeowner can install the whole system but they’re still subject to the inspections. I don’t know what the rules on repair are. I guess if it works it’s all good.
/ Septic drain field issue #19
And that was just what I was saying...It is better for a homeowner to fix it themselves no matter the size of the break, then to just let it go. Who is going to stop you from fixing your own problem? What is the better of the two evils: letting it spew all over the ground, or a homeowner fixing it? I was just saying what the repair rules are here in Maine.
Myself, I put in my own leach field, which was not difficult, nor was it rocket science. I think I had $1500 in the entire system. Now contractors want $7,000 to put one in. That is stupid money for some plastic pipe and some screened rock.
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
ATTENTION PLEASE READ (A64127)
ATTENTION PLEASE...
Decorative Mermaid Light Post (A61574)
Decorative Mermaid...
KOHLER 275ROZD71 DIESEL GENERATOR (A64281)
KOHLER 275ROZD71...
2007 Loudo 24ft T/A Dovetail Gooseneck Flatbed Trailer (A61573)
2007 Loudo 24ft...
2015 Ford Explorer SUV (A61574)
2015 Ford Explorer...
