Tool Box Mounting options on a Kioti
   / Tool Box Mounting options on a Kioti #41
Since I had to replace my CK27 after a fire, The CK3510 has the fuel tank in the rear so I decided to place both toolboxes on the loader arms. The brackets fit snug enough on the arms with rubber underneath I don't need to bolt them on. The arms are well inside the width of the machine so I don't have to worry about scraping them off on something. One holds tools, the other has chain, lifting hooks and other hardware. The hardest thing is remembering which side has tools and which has chains. :)
First picture shows the front of the box.
Second one shows both boxes as they sit on the arms. The third shows a back view.
   / Tool Box Mounting options on a Kioti #42
Since I had to replace my CK27 after a fire, The CK3510 has the fuel tank in the rear so I decided to place both toolboxes on the loader arms. The brackets fit snug enough on the arms with rubber underneath I don't need to bolt them on. The arms are well inside the width of the machine so I don't have to worry about scraping them off on something. One holds tools, the other has chain, lifting hooks and other hardware. The hardest thing is remembering shich side has tools and which has chains. :)
Just remember ‘right tool’ for the job. And then make sure you put the chains on the driver’s side. Ha ha!
   / Tool Box Mounting options on a Kioti #43
I put the tools on the right side and should have put them on the left as that's the side I'm using to getting on & off the tractor on. :)
   / Tool Box Mounting options on a Kioti #44
Mike, or you can just add a step on the right side. :laughing:
I actually did that on my CK3510SE, and it's surprising how much more convenient it is if I'm up against a tree, or alongside a ditch or a deep puddle and need to get off on that side. The part's not cheap tho. I think it was a bit under $100.
   / Tool Box Mounting options on a Kioti #45
I try to avoid that side if I'm getting off or on while it's running. Always afraid I'll clumsily step on a go pedal by mistake. :)
   / Tool Box Mounting options on a Kioti #46
   / Tool Box Mounting options on a Kioti #47
Here's how I mounted an ammo box on my CK2610. Plenty of room to remove the fuel cap.
   / Tool Box Mounting options on a Kioti #48
Now that's a lot of tool storage, but I'm sure you have to make sure to latch the lids before raising your FEL all the way up! I have two ammo cans mounted on the FEL towers and two more mounted on the ROPS over the fenders.
   / Tool Box Mounting options on a Kioti #49
One box is for chain sling, shackles, hitch pins etc. The other is for tools. I use those fold over hitch pins to lock the lids down. After dumping out the chains & rigging stuff once I learned to latch the lids each time I open one. :)
   / Tool Box Mounting options on a Kioti #51
I mount it on the side, often on the back there is a conflict with an attachement.
2006 Freightliner M2 106 T/A Dump Truck (A59230)
2006 Freightliner...
2023 Ford Expedition SUV (A59231)
2023 Ford...
FUTURE MB27-27" HYD MIXING BUCKET (A60432)
FUTURE MB27-27"...
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
2023 CASE 580 SUPER N BACKHOE (A60429)
2023 CASE 580...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A61306)
2017 Yale GLC050VX...
