Ripper Claw
/ Ripper Claw #21
I bought my Frost tooth/Ripper from Showtime Fab. Showtime Home
I found them on eBay, but they turned out to be local to me in Minnesota. Price was lower by calling instead of ordering on eBay. Mine was $859 2.5 years ago shipped 75 miles by ups.
I use it on a 7500 lb Bobcat 331 and it doesn’t bat an eye at anything the mini-X can handle.
/ Ripper Claw
MIE is priced at $795 plus $60 shipping. I do not doubt the quality, but was hoping to stay under $500.
Not sure what I will do at this point.
/ Ripper Claw #23
Here is the one I am working on for my KB2485. I have to fab up the mount when I get home again.
/ Ripper Claw
Thought I would update this. BroTek still wont make one. Was holding off as the one they made cost a lot less. Looks like MIE is the only game in town.
/ Ripper Claw #26
I was hoping Bro-Tec would get with the program too. Their shipping was very reasonable.
/ Ripper Claw #27
The alternative to buying is making your own, if you have the tools and disposition. These particular attachments are for the BX23.
The quick attach for the backhoe is based on the one sold by BXpanded, took a lot of time but was well worth it.
The ripper is also based on the BXpanded version, again, a lot of time and grinding and abrasive sawing.
Thought a receiver for the backhoe would by handy as well for pulling light trailers etc around the yard
/ Ripper Claw #28
took an idea from the bxpanded company for my bigger backhoe. 3/4 inch plate cut with a plasma cutter on an angle to achieve a pretty sharp edge. Finished it with a grinder and stuffed it in my wood boiler to get it hot then dunked it in oil. I beat it to DEATH trying to break it. No luck, didn't even bend. Very pleased with the results.
/ Ripper Claw #30
View attachment 653991View attachment 653992View attachment 653993View attachment 653990
What's the fish hook on the back for? (Same question for 11B).
/ Ripper Claw #31
I suppose you could make an argument for grabbing a root on the in stroke and then on the out stroke, but really, it just looks uber cool. Its handy for grabbing smaller roots and yanking them out.
/ Ripper Claw #32
These DIYs are showing some impressive design and execution IMO. Without teeth my hook has to snap roots. It's quite over-built for my Terramite, but I don't have the raw power to make the most of that. I'm inspired to dream up a way of adding something similar. Such will give smaller BHs a lot of bite, and roots can be a bear when they're 'green' and like rope. :laughing: Thanks, guys! :thumbsup:
/ Ripper Claw #35
I built mine last year, may add teeth.
JW5875
/ Ripper Claw #36
What grade of steel are you using that you can heat it and dunk it in oil? I see you're using 3/4" for the toothm what about the rest of the implement? Are you heating the whole thing prior to welding?
/ Ripper Claw #37
How would a 6-8" backhoe bucket work as a trencher and stump root ripper?
/ Ripper Claw #38
In my experience, any bucket less than 12" wide clogs up too easily. I got rid of my 9" bkt. If you don't have a ripper claw, you CAN get similar effects with a regular bucket, but with only a center tooth. Most 12" bkts have 3 teeth, so remove the outer 2, and you have a poor man's ripper. That assumes bolt-on teeth, of course.
/ Ripper Claw #40
I used 3/4 for the tooth its self. Then 1/2 inch on the back plate with a 3/8 plate behind it attaching to the mounting brackets. I welded it all up and put it all in the fire then oil. I buy 99% of my steel as "throwaway" or scrap. Just mild steel stuff. I figured if it broke it broke. But surprisingly it is holding up quite well. Considering no steel company will actually tell you what steel can handle I am just finding out my own way. My plasma cutter only will cut up to 7/8 so this was about as big as I could do since I was cutting on an angle.
2003 INTERNATIONAL MA025 SERVICE TRUCK (A66091)
2003 INTERNATIONAL...
OK TRAILER  16 FOOT TRASH TRAILER (A68842)
OK TRAILER 16...
WHEEL LOADER FORK ATTACHMENT (A67714)
WHEEL LOADER FORK...
213090 (A64276)
213090 (A64276)
2025 Wolverine MSG-11-44W 44in Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A66734)
2025 Wolverine...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
