Things I didn't consider when buying
/ Things I didn't consider when buying #21
That'd be a time saver. Part of my frustration is that the ROPS installation is such that the bolts don't _quiiiite_ fit cleanly. What works for ROPS position on one side doesn't quite work for the other side, some jiggling is required. I bet it's much less sensitive to position without having to thread the bolts through. (Because rops pinches the threads so one bolt is hard to turn until it gets that extra jiggle(s) after the first bolt is seated).
Did you worry about whether there are safety considerations relative to the threaded bolt? As you said, you have experience with other unthreaded bolt setups, I don't.
Previous thread on bolts vs pins:
https://www.tractorbynet.com/forums...ap-rops-bolt-pin-post5500460.html#post5500460
There are a lot of good solutions to this one, if you peruse the site. I haven't done it yet, but plan to build a box to slide into the tube on the bottom of the loader frame. I already carry a chain there.
I strongly advise not carrying things in the bucket, as it's too easy to forget it's there. It's a sickening feeling when you see your "newly modified" chainsaw appear between the front tires... and don't ask me how I know that.
Lol, er, I mean, my sympathies.
Yeah, I've been reading the various carryall and other topics. I haven't seen any ROPs mounted solutions I like though, and I'm not entirely sure I'd want to take off my favored rear implement just to carry some things anyway.
No idea what I'll do yet. Hanging chains from my grapple the other day was unsatisfying though, and even with a chainsaw in the bucket I felt the need to bungee it in place so it wouldn't be sliding from side to side (banging cutting bits on the bucket) as I traversed my hilly land. Since I'm definitely absent minded from time to time, your tale of chainsaws under tractors resonates with me.
Beam type torque wrenches are accurate and cheap. Probably better than a cheap HF clicker.
Yeah, I probably went overkill here. I bought a more expensive split-beam clicker instead of a micrometer clicker, mostly because I knew I would probably forget to reset the micrometer clicker setting after each use and would ruin the spring in short order. The micrometer clickers just screamed "you will ruin this quickly" to me. As I get older I have to ... attention proof ... my life.
/ Things I didn't consider when buying #24
Fascinating, captain! :)
That is why I replaced Kubota 5/8" bolt with 9/16" diameter clevis pin. 9/16" diameter clevis pin is probably not available in your local hardware store.
I do not discern any safety issues. The Kubota ROPS bolt is a pivot, not a support. Kubota loves to sell replacement proprietary ROPS bolts at absurd $60 per pair.
Btw, I understand a lot of people are content to leave their tractor and implements outside, so if that includes you then it frees you of a lot of worries. For me, my choice is to house my toys if possible. I have a fair bit of garage space, but it's poorly used so I'm trying to use it better. Come winter, I will (hopefully) not have anything out in the snow. Or such is my hope. If I have to leave something out, then there's a priority list, e.g. things with PTO shafts or hydraulics are garaged first.
Almost every vehicle I've owned in New England died of rust and general "no parts available" old age problems. Since I just spent more on a new tractor than I've ever spent on any vehicle, and since mother nature actively trying to mess with my health these days, I want to keep the tractor in good resale condition in case something happens. So the tractor is inside and the truck is outside until I can make them both fit. A majority (but not all) of my neighbors leave their equipment outside. To each their own. I'll use it hard, but I won't leave it outside to rust.
Meanwhile, I was just sharing my "oh, I didn't think of that" list FWIW for would-be buyers, though I greatly appreciate some of the suggestions today!
/ Things I didn't consider when buying #27
A couple of years ago I broke down and bought a 3/4 drive socket set in English and bought a second set of metric sockets. A cheaper set but by no means inexpensive. I only use them once in a while but when you need them. I have a pretty good torque wrench but I don’t use it very often.
/ Things I didn't consider when buying #28
Still, the (new) lights would be above the tractor, and I know I need light under the tractor, so they won't fix all my problems. Still thinking about this one.
Have you considered buying a light that fits around your head akin to a miner's light? I bought one at Lowe's for around $10. It frees both my hands for greasing and shines where I am looking. The only issue is when I use my creeper the back of the light can somethings slide off my head, so I know to be careful when laying my head down on the creeper.
Yeah, I have one of those, that's a pretty good idea. Though mine doesn't fit very tightly so I mostly only use it for things where I'm upright (usually dealing with some fairly disgusting situation in my 230 year old basement). No doubt there's a more tightly fitting version somewhere.
While reading your post it occurred to me that if I get that set-of-6 eight-foot strips I linked, I could mount one strip on a 2x4 and just slide it under the tractor on the floor when I need it. That'd be a pretty serious amount of light distributed across the much of the length of the tractor. For the set-of-6 lights for $139 (assuming the rest on my ceiling), that's $23 and change for an 8-foot 8500 lumen light under the tractor (plus cost of a 2x4). Compare that to all more expensive, lower lumen tiny "cob" worklights Hmmm. I like this idea. Though I suppose it's a bit over the top and too big.
/ Things I didn't consider when buying #30
Everything I have is outside, and I will attest that isn't the best solution. My 5 YO tractor is going to need tires soon, as they are getting weather cracked. Moisture and sun are the worst enemies of iron and electrical connections; and no matter how tightly I tarp the wind always manages to get underneath.
RE: chains aren't long enough; consider a length of cable instead. It might save you some money, and cable doesn't bend the way that chain can.
I had hoped that it was, I'd read that others were adjustable. But it looks like it's one piece that has no adjustment capability. It could be that my eyes just are not seeing the line between rotating parts, and that it was assembled by gorillas as you state. I've already degraded the gnurled part trying to rotate it relative to the base.
Maybe I'll have another go at it today, as I have two fittings where the lock-n-lube won't fit due to its larger size. You know this from experience on the Kubota branded grease gun?
Wagtail was correct, the Kubota grease fitting _is_ adjustable, and it _was_ tightened by gorillas. A vice and a large set of pliers got it lose. Oh well, I still prefer the Lock-N-Lube, but it means I'm out another $30. Unfortunately the original grease fitting isn't fitting the hard-to-reach zerks any better than the Lock-N-Lube. I'll pester the dealer about how they reach those.
/ Things I didn't consider when buying #32
I have a Lock-N-Lube fitting and it DOES help where a third hand would be needed. However - there are many recessed zerks on the FEL. The diameter of the recessed hole is smaller than the diameter of the Lock-N-Lube. Bring on the DeWalt battery powered grease gun. I can now sling nasty, black grease with the best of them.
/ Things I didn't consider when buying #33
Chain can "bend" ??
Chain can elongate, or break,....but, "bend".
/ Things I didn't consider when buying #35
Good stuff... glad to be of assistance. :thumbsup:
/ Things I didn't consider when buying #36
They make 90 degree "grease couplers" that fit on the end of the grease gun and have a short fitting that connects to the zerk fitting. I have to use one for some fittings that are in dumb locations like the spindles on my lawn mower. Mine does not fit on a LockNLube and it has to be pried off the zerk when you're done using it, but when I need it, nothing else works.
/ Things I didn't consider when buying #37
Number 2: You did know that the original grease gun end/tip was adjustable, right?
Yes, it was originally assembled by a factory-trained 800 pound gorilla. Using a couple of vise-grips (in opposite directions), and a lot of force, will loosen it.
Important note: do NOT then fully unscrew the tip assembly to 'see how it works'... the tiny internal spring will shoot out across the workshop! (It will be found three years later in the most unimaginable place. Plus, you'll then wonder what it's for.)
+1. I think they should change the name from 'Lock-n-Lube' to lube for a boob. Totally worthless accessory.
/ Things I didn't consider when buying #38
Black grease is usually clay based and not very desirable
/ Things I didn't consider when buying #39
What? Lock in Lube is literally the best thing to happen to grease guns in my lifetime.
/ Things I didn't consider when buying #40
I must be missing something. I have 3 different grease guns, two manual and one battery and never had a problem with the tips on them. I snap them on and don’t have to hold them in place.
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
Wolverine Brush Cutter BC-13-72W Skid Steer Mount  (A62679)
Wolverine Brush...
JOHN DEERE 1705 - 6R30" VACUUM PLANTER (A64277)
JOHN DEERE 1705 -...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
2010 FREIGHTLINER M2 BUCKET TRUCK (A65643)
2010 FREIGHTLINER...
New/Unused 3 Point Receiver Hitch Attachment (A65583)
