would you use this bush hog?
   / would you use this bush hog? #1
rush389
1949 Oliver 77
Previous owner of our property left this 5 bush hog behind. I can make out Kutter on the side, barely. I have never used one and I noticed this one has no bolt holes for safety chains or any obvious way to attach something to the front.
Should I try to use this thing, or just sell it and finance a new one with a new tractor purchase? I am looking at an L2501 or similar tractor.
another pic
   / would you use this bush hog? #3
I would, dig it out and check it out looks in good shape from the pic..
thanks guys. is there a way to attach a front guard to this thing, chains or rubber belting?
   / would you use this bush hog? #6
make sure the gearbox has oil. make sure the blades bolts are tight.
   / would you use this bush hog? #8
Looks to be in about as good condition as most. Most don't have any guarding on the front. See if you can raise it off the ground some, and then see if you can rotate the PTO shaft by hand. If the blades turn smoothly, you're good to go. Make sure there is oil in the gearbox.
i can rotate the shaft now. ok, i will try it out, if too much stuff gets thrown out i will rig something up.
   / would you use this bush hog? #10
I had a King Kutter, looked somewhat similar and also the color. Mine was a light duty unit but OK for grass etc. Not big saplings
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
1608 (A57192)
1608 (A57192)
2017 Ford Transit 350 Passenger Van (A55973)
2017 Ford Transit...
2025 BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
2021 CATERPILLAR 306 CR EXCAVATOR (A52709)
2021 CATERPILLAR...
New/Unused Quick Coupler (A57454)
New/Unused Quick...
