Terminating wire woven fence options
/ Terminating wire woven fence options #1
gsganzer
Elite Member
Sunset, TX
L3800 w/FEL and BH77, BX 2200 w/FEL and MMM
I'm replacing some woven equine wire on a pipe fence and I'm reminded how tedious it is to terminate the ends by wrapping each horizontal strand around the terminating pole and twisting it back on itself. I twist the wire using fencing pliers and another small mutihole twisting tool at the terminating pole but it's always a PITA and time consuming,
Has anyone had good success using any of the various crimp tool/fittings? What ones do you recommend? I'm getting too old to mess with the twisting crap.
/ Terminating wire woven fence options #3
I used T -Clips when I put up my woven wire and I can confirm they are great!
/ Terminating wire woven fence options #4
I just circle back upon itself and twist for a termination point, but I am pretty frugal and a minimalist by nature. For me, fence building is not that tedious because I know after spending 2-3 days fencing in a field, that field will have woven wire up for 30 years or more, so what is a few days of work compared to that?
But I have used crimps for woven wire repairs, and they work well. The cost is minimal, but the worst part is losing your crimping tool. That gets expensive, so but florescent pink paint as soon as you get one, and use it on all your fencing tools. Most tools are black, and when left somewhere, are easily lost.
/ Terminating wire woven fence options #5
I'm curious what others have to say. I've been looking at what's available at kencove.com but don't know what's good and whats not. I've gotten some fantastic deals there for electric fencing, so it's my go to online source.
/ Terminating wire woven fence options #6
I use a closed end 1/4" wrench to spin the wire around. Finish up with a short twist with pair of pliers. Fairly fast, but 13 wires to loop can be slightly annoying. I do that 26 times when tying a new roll to the already nailed up roll when installing new fence wire.
/ Terminating wire woven fence options #7
I wrap it around the post, stape it and twist it.
That said we have some high tensile wire and both of these crimps styles work great.
American FarmWorks High Tensile Wire 1-2 Gritted Crimping Sleeve, Pack of 25, HTCS12-AFW at Tractor Supply Co.
Farmstead Products Company 12-1/2 - 15-1/2 ga. Hi-Tensile Smooth Ferrules at Tractor Supply Co.
Crimping Tool
American FarmWorks 4-Slot Crimping Tool, HT4SCT-AFW at Tractor Supply Co.
Those T-clips appear to be the best option and run about $1.20/ea meaning it would cost about $16 for each end termination on a 13 wire equine fence. Not necessarily cheap, but no special tool required other than a cheap keychain type that allows you to undo them (if you ever needed to), so in a sense they're removable/reuseable. When you add that material cost together with the poles, concrete (if used), wire and other clips/wraps it's fairly insignificant. I'll probably try them on the next fence.
/ Terminating wire woven fence options #9
I hate woven wire fence with a passion. I told my son a few months ago when we were tearing some of it out that if he ever sees me putting the stuff up then he can know that I am getting paid well to do it. Recently figured a job with 300' of it and yes I bid it high.
But on the subject at hand I"ve always wrapped my post and stapled it on before I learned to twist and tie it off. I recently saw this ad for this tool and it might make it into my fence tool crib someday: S7 MODEL 6000
/ Terminating wire woven fence options #10
I find that undoing the knots on horse fence takes me forever, suspect I'm doing it wrong and probably undoing too many of them. I find that wrapping the wire isn't that much effort afterwards, but definitely the start post and end post (terminators) of the woven wire is definitely the time-killer of the job - I'd be willing to shell out a bit more to save that hour.
/ Terminating wire woven fence options #11
What t-clips are you referring to that cost $1.20 each? Can you post a picture. Thanks...
/ Terminating wire woven fence options #12
I terminate at wood posts, cut about 1" past the vertical strand, bend the horizontal 90 degrees so it lays alongside the vertical strand, and staple it. Have I been doing it wrong all these years :unsure:
/ Terminating wire woven fence options #13
If it's less trouble to replace the pipe at the terminations with wooden posts you can staple the terminations.
/ Terminating wire woven fence options #14
When I worked at the fence company we'd make gates for a vineyard that had us use their field fence wire for filler, that was some high tensile stuff. Rather than fighting it with pliers, we made up some twister tools from truss rod drop. That would wind a few turns, then trim and use the pliers to get the finger slicer laid flat.
/ Terminating wire woven fence options #15
I find wrapping the ends is quicker than crimping them. At least with the crimps I have I need a long stretch of unbent wire. Crimping also leaves ends that can jab if you don't deal with them.
For wrapping, I use this: Contact Us - Fence Pro T-Post Clip Tool . Of course, the website says they have halted production. It's just a piece of 1/4" rod with about a 1/8" hole in the end, about 8" long. I also have one bent into an L shape. Sometimes the end of the wire gets positioned just so and you need three different tools to get at it.
I'd like to find a better method. If I have to take fence down I find I just cut it, it's not worth unwrapping to save a foot of fence. I've thought about making some sort of clamp that just squeezes the wire between two pieces, and then the clamp gets attached to the post. Ideally it would be something where you could clamp, stretch and tie off all at once. But I haven't progressed beyond the ideating phase.
/ Terminating wire woven fence options #16
These are the t-clips I considered using. However, I ended up doing it the way I always have, by wrapping them using my little wrapping tool. Go with what you know.
Kencove Gripple T-clip
To one of the previous posts about stripping the knots off to get a nice bare 9- 12" section of wire to make your wrap. A really good quality set of diagonal cutters works well. I sit on a 5-gallon bucket and have another bucket next to me for the small pieces if wire as I prep the ends.
/ Terminating wire woven fence options #18
Previously I used pliers and a "quick" wrist twist to loosen the knots (and when the fence is under tension I could do this pretty effectively), but last time I did fence work I also cut them off.
Cutting was quicker, didn't bend the wire, I didn't have to pull knots off - definitely an improvement. I probably ended up with more knot pieces in the dirt, but I don't think it's much of an issue.
