RX7320 stops forward motion
/ RX7320 stops forward motion #1
dirtracer28a
Osceola,MO
Kioti RX7320 , 1210 David Brown
I have a 2015 Kioti RX7320 roughly 500 hours, all fluids good, and recently it has developed a problem. While going forward it will sometimes come to a stop as if you pressed the clutch in. Sometimes it will take back off for a couple feet, bucking & jumping like you are pressing & letting off the clutch pedal quickly. If you shut off the tractor & start it back up, sometimes it will go forward again. It will always go in reverse with no issues. Any one experienced this issue? Any suggestions? Thanks in advance
/ RX7320 stops forward motion #2
What does your dealer tell you to look for or try ? I had a problem like that . It was a Electric issue .
We are messing with solenoids to see if we can figure anything out, they are leaning towards electrical issue also.
/ RX7320 stops forward motion #4
did you ever figure it out? im having the same problem.
/ RX7320 stops forward motion #5
what sort of electrical issue, im having the same problem.
I took it to the dealer & they had it for what seemed like forever, but it was the transmission control box that was bad. I can't remember right off hand but I think it cost around $2200 to have fixed. Hope you get yours fixed.
/ RX7320 stops forward motion #7
I have had a similar issue. it would stop working in the forward movement. I would turn off tractor and start again to get it rolling again. The other day it would not move forward at all. I removed the control module and blow it out. when I put it back in the tractor would move forward again. I drove around the fields and still had it stop moving forward but I do believe it is a bad connection somewhere or a bad control module.
/ RX7320 stops forward motion #8
I have had a similar issue. it would stop working in the forward movement. I would turn off tractor and start again to get it rolling again italian brainrot clicker. The other day it would not move forward at all. I removed the control module and blow it out. when I put it back in the tractor would move forward again. I drove around the fields and still had it stop moving forward but I do believe it is a bad connection somewhere or a bad control module.
I had a similar problem with my tractor too, it turned out to be just a loose connector. Blowing out the module definitely helps, but those intermittent stops can be frustrating.
2008 Detroit Diesel 200PJS6DT3 200kW Diesel Generator (A61572)
2008 Detroit...
2015 Isuzu NPR 16ft. Box Truck (A61573)
2015 Isuzu NPR...
2017 Mercury SeaPro 115HP Outboard Boat Motor (A61574)
2017 Mercury...
UNUSED CFG QK16R EXCAVATOR (A64280)
UNUSED CFG QK16R...
1993 International 4900 Utility Flatbed Truck (A64194)
1993 International...
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
