RX7320 stops forward motion
/ RX7320 stops forward motion #1
dirtracer28a
Osceola,MO
Kioti RX7320 , 1210 David Brown
I have a 2015 Kioti RX7320 roughly 500 hours, all fluids good, and recently it has developed a problem. While going forward it will sometimes come to a stop as if you pressed the clutch in. Sometimes it will take back off for a couple feet, bucking & jumping like you are pressing & letting off the clutch pedal quickly. If you shut off the tractor & start it back up, sometimes it will go forward again. It will always go in reverse with no issues. Any one experienced this issue? Any suggestions? Thanks in advance
/ RX7320 stops forward motion #2
What does your dealer tell you to look for or try ? I had a problem like that . It was a Electric issue .
We are messing with solenoids to see if we can figure anything out, they are leaning towards electrical issue also.
/ RX7320 stops forward motion #4
did you ever figure it out? im having the same problem.
/ RX7320 stops forward motion #5
what sort of electrical issue, im having the same problem.
I took it to the dealer & they had it for what seemed like forever, but it was the transmission control box that was bad. I can't remember right off hand but I think it cost around $2200 to have fixed. Hope you get yours fixed.
/ RX7320 stops forward motion #7
I have had a similar issue. it would stop working in the forward movement. I would turn off tractor and start again to get it rolling again. The other day it would not move forward at all. I removed the control module and blow it out. when I put it back in the tractor would move forward again. I drove around the fields and still had it stop moving forward but I do believe it is a bad connection somewhere or a bad control module.
/ RX7320 stops forward motion #8
I have had a similar issue. it would stop working in the forward movement. I would turn off tractor and start again to get it rolling again italian brainrot clicker. The other day it would not move forward at all. I removed the control module and blow it out. when I put it back in the tractor would move forward again. I drove around the fields and still had it stop moving forward but I do believe it is a bad connection somewhere or a bad control module.
I had a similar problem with my tractor too, it turned out to be just a loose connector. Blowing out the module definitely helps, but those intermittent stops can be frustrating.
KBH Tender Trailer (A63688)
KBH Tender Trailer...
(4) 10 X 20 STEEL MATS (A64276)
(4) 10 X 20 STEEL...
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
2005 20 Ft. Grady-White Boat with 25 Ft. Float-On T/A Boat Trailer (A61574)
2005 20 Ft...
Danuser 3pt Auger (A64119)
Danuser 3pt Auger...
