assemble pto drive shaft
/ assemble pto drive shaft #1
geoffleach
Member
mountain ranch, ca
Antonio Carraro TRH 9800, TTR 4400
This concerns a PTO drive shaft that has come apart. The shaft itself, not its PTO connection. The shaft connection is splined. The tractor side has a section where there are no splines - width of two or three splines. I would expect to find a matching section on the implement side, but no dice. The tractor side can be fitted to the implement side, but only slips in a half inch or so.
So, what am I missing? (FWIW, the implement is a Rears 750 mower)
/ assemble pto drive shaft #2
I always hated those fine splined ones, my Uncle had a tiller with a shaft like that, we found it easier to lay a straight edge on the shaft side yokes to be sure it was phased, then it can only go in one of two places 180 degrees apart
/ assemble pto drive shaft #3
Look real close at the male shaft , 1/2 " in where it stops there will be a tiny dot of weld between two of the splines. That has to line up with where the splines are missing on the female side. B
/ assemble pto drive shaft #4
Had one PTO shaft that had 2 splines that were "pinched" together in one spot. Those slipped into the female part where the gap was.
/ assemble pto drive shaft #5
Ditto 2 splines pinched together on male end is the way my splined shaft is. They can be a pain to get lined up.
Metal Sunflower Spinner (A65583)
Metal Sunflower...
JOHN DEERE 220 - 18' DISC HARROW (A64277)
JOHN DEERE 220 -...
New/Unused Electric Winch (A65583)
New/Unused...
100 Gal Fuel Tank (A65643)
100 Gal Fuel Tank...
2020 Chevrolet Traverse SUV (A64557)
2020 Chevrolet...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
