Your towing rigs and trailers
/ Your towing rigs and trailers #3,461
I hauled a MF150 and box scraper for a guy yesterday. The tractor hadn't been started in years so we used the winch to pull it and the scraper on the trailer. Went pretty smooth.
/ Your towing rigs and trailers #3,462
Picked up an 18ft + 2ft dovetail car hauler yesterday from a local N AL dealer. Loaded the BX for a test run to go get some fuel.
/ Your towing rigs and trailers #3,463
/ Your towing rigs and trailers #3,464
Nice trailer with plenty of room for your Kubota. And gas is cheap now.
Thanks man I got a very nice price. Wasn’t planning on a 20ft but it was too good to pass up. It’s only a 7k trailer but made with 4in C channel frame. This gives us wiggle room and extra space for other items.
Diesel is still about $2.40 here but gas is way down.
/ Your towing rigs and trailers #3,465
My main mover 1974 General tri axle. I haul my skidloaders, backhoes, and TD-9 bulldozers on it.
07 Sure-trac dump trailer that I use all of the time----kinda handy to have around, EXCEPT for the electric hyd unit on them are a joke! ---In the process of putting a real hydraulic pump and gas engine on mine.
/ Your towing rigs and trailers #3,466
Took the JD F725 to the farm to mow a couple days ago: HPIM4384.JPG
/ Your towing rigs and trailers #3,468
If you run 6 gauge to the truck battery through a forklift disconnect to the trailer battery the electric ones have way more power. 14 volts from the truck battery and alternator.
/ Your towing rigs and trailers #3,469
My trailer is too uninteresting to post, as it's just a single axle 5.5ラ10 landscape trailer, but I do like my truck. In 2015, I bought a brand new middle-of-the-road Silverado 1500, first time I ever bought a new vehicle after owning about 30 used ones. I had it for exactly one year, before I couldn't take it anymore and traded it in for a fancy 2016 3500 HD LTZ/Z71 Duramax. Every time I needed to haul something heavy, I regretted my 1500 (especially since I'd come off of an 04 2500), so I stepped back up. In this picture, I'm about to unload 2 tons of 2B stone into an area where I need to pour some concrete.
/ Your towing rigs and trailers #3,470
I'm sure I could get by with a half-ton but I had one for 7 years and wanted to run something that is a little more on the overkill side of things when I tow. Besides, we may end up with a 5th wheel camper at some point. This Ram 2500 has worked well for me for 3 years now.
Rob
/ Your towing rigs and trailers #3,471
Here’s one of mine. My ton truck would move it on a GN trailer but I don’t like the pintle behind a lighter truck plus I can’t load the ton truck and move the M59.IMG_8580.JPG
/ Your towing rigs and trailers #3,472
My trailer is too uninteresting to post, as it's just a single axle 5.5ï¾—10 landscape trailer, but I do like my truck. In 2015, I bought a brand new middle-of-the-road Silverado 1500, first time I ever bought a new vehicle after owning about 30 used ones. I had it for exactly one year, before I couldn't take it anymore and traded it in for a fancy 2016 3500 HD LTZ/Z71 Duramax. Every time I needed to haul something heavy, I regretted my 1500 (especially since I'd come off of an 04 2500), so I stepped back up. In this picture, I'm about to unload 2 tons of 2B stone into an area where I need to pour some concrete.
I hate half tons. I don’t even like towing my lawnmower with one. In its defense the lawnmower and trailer is about 4K. My 2500 is a much more secure ride over the 1500 when towing. I can’t say that l like unloading stone by hand either.
/ Your towing rigs and trailers #3,473
used my b2650 to clean up after taking down a tree. ran it across the scale along with the truck and trailer. does anyone want to guess on weight or should i tell you
94 f250 4x4, diesel, 40 gallons of fuel, 500ish lbs in the bed my 225 lbs in the driver seat
30ft wood decked 10K car trailer
b2650, loader, 48" single lid grapple, 60" woods RFM
/ Your towing rigs and trailers #3,474
That's a 30' trailer? Did you mean 20'?
If it is a 20' trailer as it looks in the pic, I'm going to say 14,500#.
Rob
/ Your towing rigs and trailers #3,475
I’m going to guess the truck is about 7500 including the bed load and driver, the trailer about 2000 maybe 2500 and the tractor and implements 3500.
/ Your towing rigs and trailers #3,476
I'll go with:
truck - 8000#
trailer (assuming it is 30') - 4000#
Tractor & implements - 4000#
Total is 16,000# or maybe a little more.
/ Your towing rigs and trailers #3,477
Depending on if the tractor has ballast and what kind, I say Approx 13,000lbs
6700 truck
3700 tractor/implements
2600 trailer
Lots of variables though.
/ Your towing rigs and trailers #3,478
trailer is 20 ft that is my bad. big fingers and small keys plus a lack of proofreading
Rob
I'll go with:
truck - 8000#
20 ft my mistake
6700 truck
2600 trailer
you are the closest slightly over
truck - 6980
trailer 2740
tractor 3040
combo 12760
i find it interesting that everyone over estimated the tractor and implements, under on the trailer and were close ish on the truck
/ Your towing rigs and trailers #3,479
Guessing the tires arent loaded then, that's 5-600lbs right there.
I usually round up, trailers are hard to estimate from pictures, I've seen 20ft 10k trailers anywhere from 2-3k lbs.
/ Your towing rigs and trailers #3,480
Picked up a new goose neck power tilt deck trailer last year and a new truck this spring. Had to Haul the tractor to the dealer to get the front cover resealed, so I finally got some picks.
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
Toyota RF1-SD1X45 4,500 LB Stand-On Electric Forklift (A59228)
Toyota RF1-SD1X45...
2008 New Holland B110 MFWD Loader Backhoe (A57024)
2008 New Holland...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
3015 (A56857)
3015 (A56857)
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
