Your towing rigs and trailers
   / Your towing rigs and trailers #3,471
Here’s one of mine. My ton truck would move it on a GN trailer but I don’t like the pintle behind a lighter truck plus I can’t load the ton truck and move the M59. IMG_8580.JPG
   / Your towing rigs and trailers #3,472
My trailer is too uninteresting to post, as it's just a single axle 5.5ï¾—10 landscape trailer, but I do like my truck. In 2015, I bought a brand new middle-of-the-road Silverado 1500, first time I ever bought a new vehicle after owning about 30 used ones. I had it for exactly one year, before I couldn't take it anymore and traded it in for a fancy 2016 3500 HD LTZ/Z71 Duramax. Every time I needed to haul something heavy, I regretted my 1500 (especially since I'd come off of an 04 2500), so I stepped back up. In this picture, I'm about to unload 2 tons of 2B stone into an area where I need to pour some concrete.
I hate half tons. I don’t even like towing my lawnmower with one. In its defense the lawnmower and trailer is about 4K. My 2500 is a much more secure ride over the 1500 when towing. I can’t say that l like unloading stone by hand either.
   / Your towing rigs and trailers #3,473
used my b2650 to clean up after taking down a tree. ran it across the scale along with the truck and trailer. does anyone want to guess on weight or should i tell you
94 f250 4x4, diesel, 40 gallons of fuel, 500ish lbs in the bed my 225 lbs in the driver seat
30ft wood decked 10K car trailer
b2650, loader, 48" single lid grapple, 60" woods RFM
   / Your towing rigs and trailers #3,474
That's a 30' trailer? Did you mean 20'?
If it is a 20' trailer as it looks in the pic, I'm going to say 14,500#.
Rob
   / Your towing rigs and trailers #3,475
I’m going to guess the truck is about 7500 including the bed load and driver, the trailer about 2000 maybe 2500 and the tractor and implements 3500.
   / Your towing rigs and trailers #3,476
I'll go with:
truck - 8000#
trailer (assuming it is 30') - 4000#
Tractor & implements - 4000#
Total is 16,000# or maybe a little more.
   / Your towing rigs and trailers #3,477
Depending on if the tractor has ballast and what kind, I say Approx 13,000lbs
6700 truck
3700 tractor/implements
2600 trailer
Lots of variables though.
   / Your towing rigs and trailers #3,478
trailer is 20 ft that is my bad. big fingers and small keys plus a lack of proofreading
Rob
I'll go with:
truck - 8000#
20 ft my mistake
6700 truck
2600 trailer
you are the closest slightly over
truck - 6980
trailer 2740
tractor 3040
combo 12760
i find it interesting that everyone over estimated the tractor and implements, under on the trailer and were close ish on the truck
   / Your towing rigs and trailers #3,479
Guessing the tires arent loaded then, that's 5-600lbs right there.
I usually round up, trailers are hard to estimate from pictures, I've seen 20ft 10k trailers anywhere from 2-3k lbs.
   / Your towing rigs and trailers #3,480
Picked up a new goose neck power tilt deck trailer last year and a new truck this spring. Had to Haul the tractor to the dealer to get the front cover resealed, so I finally got some picks.
Rotary SPOA9-200 Automotive Lift (A56857)
Rotary SPOA9-200...
LOT OF TIN (A58374)
LOT OF TIN (A58374)
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
1256 (A58374)
1256 (A58374)
Diamond C Trailers 26ft T/A Flatbed Tilt Trailer (A55787)
Diamond C Trailers...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2016 FREIGHTLINER...
